Renaming SD card might cause issues for GD.
unoclay
I had a problem that I solved, posting here for reference.
I'd loaded some games onto an SD card and my GD was working fine.
However, after that first test, i put the SD card back in my computer to add more games.  At this point,  I renamed my SD card.  Then i added more games.
When i went back to the lynx, the new games (added AFTER SD name change) worked ok, but the games that i'd added before renaming the SD card didnt work.
So, i went back and re-flashed the older games (pre-renaming) and now they work.
Takeaway--dont rename your SD card, or the games loaded before renaming might not work, and you may need to re-load all the ROMs.
Not sure if anyone wants to try and replicate this--you may need to reflash all your ROMS--but thought i'd post it.
Worth noting if needed, for the error i noted above, am using a 64gb SD micro, in spite of instructions stating you must use 32gb or less.  I am also on a Macbook Pro, using this for formatting the card and loading games.  Not sure if either contributed to the issue.
