marko1301 Posted October 27, 2020 Share Posted October 27, 2020 I'm using Altirra under VM (can't say it's any better than the real MacAtari800 emu) but anyway... As I was trying to get .asm files from a drive using 'ENTER d#: MYSOUCE.ASM' but I cannot enter the hash key with Parallels. Duh! Im missing a trick to get Altirra to recognise the ctrl-Alt-3 keypress. Can't seem to map it properly. Anyone help please? Quote Link to comment Share on other sites More sharing options...
+Stephen Posted October 28, 2020 Share Posted October 28, 2020 Can't answer your question about the # key on Mac, however that syntax should most likely be D1:FILE.ASM or D2:FILE.ASM, etc. The # key would represent the drive number. Sorry if I misunderstand your post. Quote Link to comment Share on other sites More sharing options...
phaeron Posted October 28, 2020 Share Posted October 28, 2020 Altirra author here -- this is due to an unfortunate conflict between the international keyboard layout you are using (presumably Spanish) and a default keyboard shortcut in the emulator. Specifically, the AltGr+3 or Ctrl+Alt+3 combination to produce a # sign on that keyboard layout conflicts with a preset command shortcut in the emulator to toggle audio channel 3. You can remove this conflicting shortcut in Tools > Keyboard Shortcuts by typing Ctrl+Alt+3 in the Shortcut box, then selecting the entry to Audio.ToggleChannel3 that shows up and clicking Remove. Alternatively, in System > Configure System > Keyboard you can switch the keyboard layout from Natural to Direct, which will then bind keys by position similarly to the original Atari keyboard layout. This will make Shift+3 give #, but Shift+2 will then produce " instead of @. As Stephen noted, though, you don't actually want to type a # sign for the ENTER command in BASIC, you want to specify the actual drive number. Quote Link to comment Share on other sites More sharing options...
marko1301 Posted October 28, 2020 Author Share Posted October 28, 2020 Thanks guys...Thanks phaeron -fixed- great product btw. Im looking forward to the MacOS version ;o) Cheers, Mark Quote Link to comment Share on other sites More sharing options...
drac030 Posted October 28, 2020 Share Posted October 28, 2020 13 hours ago, Stephen said: that syntax should most likely be D1:FILE.ASM or D2:FILE.ASM, etc. The # key would represent the drive number. I think he might have meant something like ENTER#D:MYSOURCE.ASM, this is the syntax MAC/65 uses and possibly some other assemblers too (EASMD, if I remember correctly, was pretty similar). 1 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted October 28, 2020 Share Posted October 28, 2020 2 hours ago, drac030 said: I think he might have meant something like ENTER#D:MYSOURCE.ASM, this is the syntax MAC/65 Yes and Atari Assembler Editor uses that syntax too 1 Quote Link to comment Share on other sites More sharing options...
marko1301 Posted October 29, 2020 Author Share Posted October 29, 2020 Thanks for the answers...phaeron sorted it. As Drac030 suggests " ENTER#D:MYSOURCE.ASM " is the only way that MAC/65 and Atari assembler will accept a disk access AFAIK. Quote Link to comment Share on other sites More sharing options...
