+Philsan Posted November 3, 2020 Share Posted November 3, 2020 Sorry for the noob question. I've plenty of loading devices but most of the times I use the SIO2PC-USB because I update files often and I like to have all files in one place, for emulator and real Atari. Is it possible to use FujiNet to access my files on my W10 PC? Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted November 3, 2020 Share Posted November 3, 2020 I think if you check out the TNFS functionality, it may serve your purposes. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted November 3, 2020 Author Share Posted November 3, 2020 7 minutes ago, 8bitguy1 said: I think if you check out the TNFS functionality, it may serve your purposes. Thanks! I already checked but if I am not wrong I would have to make a server where to put my files. I need all the files in one place, for Altirra and real Atari. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted November 3, 2020 Share Posted November 3, 2020 1 minute ago, Philsan said: Thanks! I already checked but if I am not wrong I would have to make a server where to put my files. I need all the files in one place, for Altirra and real Atari. You can run tnfsd on your PC and point it to a directory that contains all your files (tnfsd /path/to/folder). Windows binary for tnfsd is at https://fujinet.online/download 2 1 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted November 3, 2020 Author Share Posted November 3, 2020 23 minutes ago, mozzwald said: You can run tnfsd on your PC and point it to a directory that contains all your files (tnfsd /path/to/folder). Windows binary for tnfsd is at https://fujinet.online/download Thank you! Quote Link to comment Share on other sites More sharing options...
+Philsan Posted November 3, 2020 Author Share Posted November 3, 2020 I am sorry for another noob question. Intead of using prompt, would it be possible to double clic on an icon and start the server pointing it to my folder? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted November 3, 2020 Share Posted November 3, 2020 1 hour ago, Philsan said: I am sorry for the noob question. Intead of using prompt, would it be possible to double clic on an icon and start the server pointing it to my folder? Thanks in advance. nope, it requires the command line to add the folder path Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted November 4, 2020 Share Posted November 4, 2020 5 hours ago, Philsan said: I am sorry for the noob question. Intead of using prompt, would it be possible to double clic on an icon and start the server pointing it to my folder? Thanks in advance. 3 hours ago, mozzwald said: nope, it requires the command line to add the folder path Well, actually you can write a little Windows batch file in a text editor and save it as a .bat file. You can then just double-click the .bat file and it will run. Mine is dead simple: D:\tnfs-win32\tnfsd.exe D:\AtariStuff\TNFS In this case, I have the tnfsd.exe executable in a folder on my D drive, and I'm pointing it a folder that has all the stuff I want to share over FujiNet in another folder, also on my D drive. That's it. Save it as TNFSD.bat or whatever you want to name it. Then just double-click that icon to start your server. 3 1 Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted November 4, 2020 Share Posted November 4, 2020 9 hours ago, Philsan said: Sorry for the noob question. I've plenty of loading devices but most of the times I use the SIO2PC-USB because I update files often and I like to have all files in one place, for emulator and real Atari. Is it possible to use FujiNet to access my files on my W10 PC? I guess TNFSD will do the job, but for completeness, there is one more option. If your WIN10 PC has Bluetooth, you can use #Fujinet as SIO2BT (long press 'A' button) and run RespeQt on your PC. 3 1 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted November 6, 2020 Share Posted November 6, 2020 On 11/3/2020 at 4:24 PM, Philsan said: I am sorry for another noob question. Intead of using prompt, would it be possible to double clic on an icon and start the server pointing it to my folder? Thanks in advance. Right click on the tnfsd.exe and select create shortcut Right click on the shortcut and edit the line labeled target: to include your software path. Double click the icon to run your tnfsd 1 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 15, 2020 Share Posted November 15, 2020 (edited) Error. Edited November 15, 2020 by Kyle22 Nevermind. Error. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted November 15, 2020 Share Posted November 15, 2020 (edited) post deleted Edited November 15, 2020 by DjayBee wrong thread Quote Link to comment Share on other sites More sharing options...
