+mizapf Posted February 8, 2022 Share Posted February 8, 2022 17 hours ago, Shift838 said: I have created diskettes in both TIIMAGETOOL and TI99DIR for 90k, 180k and 360k [...] if I select DS/SD or DS/DD within the tool it changes the disk to 90K SS/SD. Now tell me: Isn't that a kind of magic? Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 8, 2022 Author Share Posted February 8, 2022 1 hour ago, mizapf said: Now tell me: Isn't that a kind of magic? I was using the DFORMAT tool and even though it claims to doDouble sided but it does not. I have since found out I can create a disk image with TIIMAGETOOL or TI99DIR and mount it. Then go into the Filer and Zero it, select the appropriate block size for the size and it works. I created a DS/DD with TI99DIR and did the Zero option within Filer and set the size to 1440 and it all works. I have since put all the UCSD diskettes onto one. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted February 8, 2022 Share Posted February 8, 2022 3 hours ago, Shift838 said: Would you like to share your DFORMAT program ? I don't have it. Anders does. Quote Link to comment Share on other sites More sharing options...
dgrissom Posted February 15, 2022 Share Posted February 15, 2022 Question: Has anyone been able to run "OoeyGUI "with Raspberry PI OS running "Bullseye" (64-bit and/or 32-bit)? My current SD card got corrupted. Since I was using a PI 4, I thought I would try the new 64-bit version of PI OS Bullseye. I ran into a brick wall with it. ? Next, I decided to try the 32-bit version of Bullseye. I downloaded the latest OoeyGUI for RPi and was able to get it to run. I let it download and installed Mame (no real problems). Set up a "Fav1" machine (pretty stock 4A with TI peripherals and Extended BASIC. I clicked the "Launch Button" and nothing would happen. I reviewed the log file and it showed it accessed the "mame.ini" and then the "plug-ins". BTW, the "TI Image Tool" would run from OoeyGUI. I could start Mame using "./mame". and get the TI to boot with a cartridge. I played around with permissions, etc. with both Ooey and Mame with no success. Finally, I managed to find an archived SD card image of Buster that had everything on it and working. Everything is working. I would like to move to the newest OS at some point. Just wish I could figure out what went wrong? David G Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 15, 2022 Author Share Posted February 15, 2022 11 minutes ago, dgrissom said: Question: Has anyone been able to run "OoeyGUI "with Raspberry PI OS running "Bullseye" (64-bit and/or 32-bit)? My current SD card got corrupted. Since I was using a PI 4, I thought I would try the new 64-bit version of PI OS Bullseye. I ran into a brick wall with it. ? Next, I decided to try the 32-bit version of Bullseye. I downloaded the latest OoeyGUI for RPi and was able to get it to run. I let it download and installed Mame (no real problems). Set up a "Fav1" machine (pretty stock 4A with TI peripherals and Extended BASIC. I clicked the "Launch Button" and nothing would happen. I reviewed the log file and it showed it accessed the "mame.ini" and then the "plug-ins". BTW, the "TI Image Tool" would run from OoeyGUI. I could start Mame using "./mame". and get the TI to boot with a cartridge. I played around with permissions, etc. with both Ooey and Mame with no success. Finally, I managed to find an archived SD card image of Buster that had everything on it and working. Everything is working. I would like to move to the newest OS at some point. Just wish I could figure out what went wrong? David G I have not certified the OoeyGUI 4.x with bullseye yet. It may take a recompile to do that. I need to load up a Bullseye 32bit and 64biyt OS. Neither were available yet at the time of the compile. I know there are quite a few limitations with the 64bit, especially around supported software packages. I have not verified all the packages that are used within OoeyGUI are even available on the 64bit OS for RPi yet. Quote Link to comment Share on other sites More sharing options...
dgrissom Posted February 15, 2022 Share Posted February 15, 2022 Just now, Shift838 said: I have not certified the OoeyGUI 4.x with bullseye yet. It may take a recompile to do that. I need to load up a Bullseye 32bit and 64biyt OS. Neither were available yet at the time of the compile. I know there are quite a few limitations with the 64bit, especially around supported software packages. I have not verified all the packages that are used within OoeyGUI are even available on the 64bit OS for RPi yet. No problem. I've encountered a number of issues with Bullseye with other applications. It will take a while for the software to catch up. Meanwhile, Raspberry PI Org seems to be pushing hard for users to move to the latest version. ? Quote Link to comment Share on other sites More sharing options...
