question about CRY
TXG/MNX
28 minutes ago, CyranoJ said:
jag_vidmode		equ			vidRGB16
jag_videnable	equ			vidENABLE
jag_varmod		equ			vidVARMOD_OFF
It's in _rapinit.s
All documented in the manual.
Hi,
In the manual I see these modes:
CRY16, RGB16, RGB24, DIRECT16
When using RGB16 only RGB values are supported right or can I still use CRY objects? What about DIRECT16 mode I cannot find the info on that in the manual.
10 minutes ago, TXG/MNX said:
Hi,
Use the "other" manual: JAG_V8.PDF
Why don't you post what you've done and what it's doing along with code and a binary, because random out of context questions are really annoying (and is why ggn probably quit)
(Thats a polite way of saying "put up or shut up"... for those who fail to grasp the art being not so subtle - I'm prepared to help if I can and there is a point, I'm not prepared to mind-read)
Hi,
I read the JAG_V8.PDF
Okay I turned VARMODE ON and now I can mix cry with RGB, and have a transulent color
in rapapp.s
raptor_video_VARMOD                equ                vidVARMOD_ON
In assets.txt I added this line:
and in rapinit.s
overlay
    dc.l    1        ; repeat
    dc.l    is_active                                                           ; active
    dc.w    100,0        ; x
    dc.w    90,0        ; y
    dc.w    0,0        ; xadd
    dc.w    0,0        ; yadd
    dc.l    160        ; width
    dc.l    80        ; height
    dc.l    is_normal                                                           ; flip
    dc.l    0        ; coffx
    dc.l    0        ; coffy
    dc.l    160                                                               ; hbox
    dc.l    80                                                               ; vbox
    dc.l    sprite_overlay                                                   ; gfxbase
    dc.l    16        ; gfxbits
    dc.l    is_cry                                                           ; gfxformat
    dc.l    is_trans                                                         ; gfxbacktype
jag_v8.pdf
