fultonbot Posted December 9, 2020 Share Posted December 9, 2020 Quick question: I want to get a constant playback rate for pokey music, but when I put my gosub to my play code in topscreenroutine , it appear doesn't work. Is there an issue with psound in topscreenroutine, is there an issue with a gosub in topscreenroutine?, or did I imagine all this? Also, since I'm trying to make the playback independent of frame-rate (i.e no matter if I have drawscreen or doublebuffer 1,2,3, etc.) will this even work? Is here a better way to make sure music plays back at a constant regardless of display frame rate? Quote Link to comment Share on other sites More sharing options...
RevEng Posted December 9, 2020 Share Posted December 9, 2020 The interrupts (top screen, bottom screen, and user interrupt) should really be kept as simple as possible... I should underscore that in the manual. The problem with a bunch of complex code with 7800basic statements is they're likely to modify temp variables, which is problematic. Your gosub likely uses a temp variable here. I think psound might be ok for temps, so you might get away with that, if you avoid the gosub. 1 Quote Link to comment Share on other sites More sharing options...
fultonbot Posted December 9, 2020 Author Share Posted December 9, 2020 9 hours ago, RevEng said: The interrupts (top screen, bottom screen, and user interrupt) should really be kept as simple as possible... I should underscore that in the manual. The problem with a bunch of complex code with 7800basic statements is they're likely to modify temp variables, which is problematic. Your gosub likely uses a temp variable here. I think psound might be ok for temps, so you might get away with that, if you avoid the gosub. That's what I expected. Thanks! -Steve 1 Quote Link to comment Share on other sites More sharing options...
+bhall408 Posted December 12, 2020 Share Posted December 12, 2020 On 12/8/2020 at 7:29 PM, fultonbot said: Quick question: I want to get a constant playback rate for pokey music, but when I put my gosub to my play code in topscreenroutine , it appear doesn't work. Is there an issue with psound in topscreenroutine, is there an issue with a gosub in topscreenroutine?, or did I imagine all this? Also, since I'm trying to make the playback independent of frame-rate (i.e no matter if I have drawscreen or doublebuffer 1,2,3, etc.) will this even work? Is here a better way to make sure music plays back at a constant regardless of display frame rate? On the Atari 8 bit line, it was common to have music playing handled in a vertical blank routine. I haven't tried 7800 programming (yet), but I do have a macro assembler library adapted from an old issue of Compute you are welcome to try adapting if you want. It is in ca65 syntax, but it probably wouldn't be too much work to change it for DASM (which is what the studio you are using uses?). I've used it in all my Atari 800 games. The way this library works is you point it at a data table of the music (or sound effect), which supports commands for setting tone and volume (pokey), and sets of duration+note data (for 1-4 voices, and you can switch as needed to save memory). For example, here is a "Whoosh" sound effect Whoosh: .BYTE ST,NU,1 .BYTE TV,14,1,14 .BYTE TV,12,1,12 .BYTE TV,10,1,10 .BYTE TV,8,1,8 .BYTE TV,6,1,6 .BYTE TV,2,1,2 .BYTE TV,0,3,0 .BYTE ST,EN Quote Link to comment Share on other sites More sharing options...
+bhall408 Posted December 12, 2020 Share Posted December 12, 2020 Since the music is handled at v-blank, then the timing is consistent no matter how much else is going on in the main loop. You just tell it to start playing, and forget about it. Quote Link to comment Share on other sites More sharing options...
fultonbot Posted December 12, 2020 Author Share Posted December 12, 2020 18 hours ago, bhall408 said: On the Atari 8 bit line, it was common to have music playing handled in a vertical blank routine. I haven't tried 7800 programming (yet), but I do have a macro assembler library adapted from an old issue of Compute you are welcome to try adapting if you want. It is in ca65 syntax, but it probably wouldn't be too much work to change it for DASM (which is what the studio you are using uses?). I've used it in all my Atari 800 games. The way this library works is you point it at a data table of the music (or sound effect), which supports commands for setting tone and volume (pokey), and sets of duration+note data (for 1-4 voices, and you can switch as needed to save memory). For example, here is a "Whoosh" sound effect Whoosh: .BYTE ST,NU,1 .BYTE TV,14,1,14 .BYTE TV,12,1,12 .BYTE TV,10,1,10 .BYTE TV,8,1,8 .BYTE TV,6,1,6 .BYTE TV,2,1,2 .BYTE TV,0,3,0 .BYTE ST,EN This is cool! Yeah, I've already kind of made my own version of this in 7800 basic now: sdata song_rudolph = a 2,0,A4,10,0,15,DFRAMES,P_ATTACK,1,100,4,12,3,2,P_CONSTANT, 1,0,B4,10,0,15,DFRAMES,P_ATTACK, 2,0,B4,0,0,0,DFRAMES,P_CONSTANT,1,100,4,12,3,2,P_CONSTANT, 1,0,A4,10,0,15,DFRAMES,P_ATTACK, 2,0,FS4,10,0,15,DFRAMES,P_ATTACK,1,100,4,12,3,2,P_CONSTANT, 1,0,0,0,0,0,DFRAMES,P_CONSTANT, You can specify number of channels to read, Note (freq), beginning and ending volume, duration, and and attack/decay/constant for the tone. Here is what my current work sounds like: (4) Atari 7800 Xmas Demo #1: Title Screen With Transcribed Pokey Music. - YouTube 1 Quote Link to comment Share on other sites More sharing options...
