Randy Posted December 12, 2020 Share Posted December 12, 2020 Someone mentioned that there may be jumpers that allow the sound circuit to function, is that true? Sounds strange but if there is a jumper for sound, can someone tell what and where it is? Thanks Quote Link to comment Share on other sites More sharing options...
mdivancic Posted December 13, 2020 Share Posted December 13, 2020 TT page from Zogging Hell!!! ...and to quote: Quote DIP Switches on TT motherboard As far as I'm aware only switch 7 has any useful effect on the TT, allowing you to select whether either a high density or double density disk drive is in use. Switch 8 can be used to turn off the DMA sound hardware (though why you'd want to do this is beyond me!). Switch 5 is used by the CaTTermaran to activate it. Switches 1 - 4 and 6 have effects which are so far undocumented. If you have a clue what these do then please get in touch. Quote Link to comment Share on other sites More sharing options...
lp060 Posted December 13, 2020 Share Posted December 13, 2020 (edited) Switch 8 -> on = Disables the DMA sound hardware My TT arrived with this switch set wrong by the dealer. Not sure where his switch 5 info came from, but Cattamaran manual states: Set DIP switch # 1 to ON (as shown). This informs the system that you have installed a CyReL CaTTamaran 48 MHz accelerator module in your Atari TT030. Edited December 13, 2020 by lp060 Quote Link to comment Share on other sites More sharing options...
Cyprian Posted December 13, 2020 Share Posted December 13, 2020 (edited) 22 hours ago, Randy said: Someone mentioned that there may be jumpers that allow the sound circuit to function, is that true? Sounds strange but if there is a jumper for sound, can someone tell what and where it is? Thanks There is no dedicated jumper which can turn sound off on the hardware level. TT and Mega STE dip switches just inform the TOS whether your would like to 'disable' DMA sound or switch from HD to DD floppy density. Based on dip switches the TOS sets appropriate variables "_SWI" and "_SND". And then, based on those cookies, the TOS will not use DMA sound or HD floppy density. Third-party applications (lice Catamaran) can also use "_SWI" variable to its own purposes. Edited December 13, 2020 by Cyprian_K Quote Link to comment Share on other sites More sharing options...
