+5-11under Posted October 28, 2022 Author Share Posted October 28, 2022 5 hours ago, atari2600land said: Any updates on this? Sadly, no... too many other things on the go at the moment... it's still in the forefront of my mind, though, and it's still part of the plan. 1 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted December 30, 2022 Author Share Posted December 30, 2022 It was over 10C outside today, so with the help of a heater pointing towards the 3D printer, I was able to print my first non-test piece (just the back cover, in gray). It fits fairly well; the design is pretty close. There are some major issues, related to the supports on the bottom, which I think were too close together, and too large (you can see some of that at the edge). It's also warped - I'll need to investigate, but it might just be the resin I have - I decided to start with just very basic (cheaper) resin to get accustomed to the whole process. The top surface is also not too smooth - maybe I just need to wipe it right away with alcohol, before putting it into the cleaner. No, the game will not be released in 2022. 1 1 Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted December 30, 2022 Share Posted December 30, 2022 So eventually you'll print whole cartridges, right? How would you get the computer used in one? 1 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted December 30, 2022 Author Share Posted December 30, 2022 13 minutes ago, atari2600land said: So eventually you'll print whole cartridges, right? How would you get the computer used in one? Yes, the plan is to print whole cartridges. The first post shows the board that goes into the shell. These are all new parts. It uses an ATMEGA328(P), programmed via the Arduino IDE. 1 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 6, 2023 Author Share Posted January 6, 2023 I spent some time over the past couple of weeks, with a heater pointing towards the 3D resin printer in the garage, learning the ropes. There were many failures and messes, but I'm getting there. I think I've got the method or at least plan mostly figured out as far as position and angle of the parts during printing. The other good news is that the printer still seems to work well, with heater, and as long as the temperature is at least a little bit above freezing. Only areas that are perfectly flat in the Z axis will print cleanly; all other faces/angles will have some level of stepping from layer to layer. Even if the stepping is minimal, scratching the surface with a fingernail will create visible marks. The cover below was printed vertically. Probably there's methods such as anti-aliasing and blurring and halving the Z stepping, but I'm still not sure how much that would improve things. Anyway, for the part below, I printed it "vertically" (such that it was about an inch tall). This resulted in minimal warping, and minimal stepping. I quickly sanded the surface with 600 grit wet sandpaper, and that got rid of imperfections. Probably in the future I should finish with a finer grit and/or polish. I'm investigating getting all the required parts 3D scanned, so I don't have to design them from scratch (and I don't think cheap scanning methods will be very effective for this application). If this was a simple enclosure, I could design the pieces myself, but this shell is fairly complex (for me), and it would take many many hours to create. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted January 6, 2023 Share Posted January 6, 2023 What 3D scanner do you prefer? I was considering getting one but got that sinking feeling Creality and Revopoint products are finicky and troublesome for the cost. Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 6, 2023 Author Share Posted January 6, 2023 50 minutes ago, Gemintronic said: What 3D scanner do you prefer? I was considering getting one but got that sinking feeling Creality and Revopoint products are finicky and troublesome for the cost. I'm going to take the parts to a company who can scan them in high enough resolution, and do some clean-up of the files. Hopefully the cost is reasonable. I'm not really familiar with consumer/prosumer solutions. 1 Quote Link to comment Share on other sites More sharing options...
+swlovinist Posted January 7, 2023 Share Posted January 7, 2023 Thanks for sharing the updates. Definitely want to purchase one when they are ready! 1 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 15, 2023 Author Share Posted January 15, 2023 I went to a couple of local companies, and didn't get very positive vibes on their 3D scanning capabilities, so I'm back to doing these in CAD. This will take more of my time, but on the other hand, it won't cost me any cash, and the designs will be easier to fix and update if required. I fixed a small problem with the back cover, and I've designed the PCB slider part. This second part went much better than the first part, so hopefully the remaining larger parts won't be too too difficult. 2 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 15, 2023 Author Share Posted January 15, 2023 Back completed. Just the largest and most complicated front piece to go. Now I'm glad I didn't pay to have it done. 1 1 Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted December 29, 2023 Share Posted December 29, 2023 I have been waiting patiently for about a year now. Is there a way to get Barrage? What about programming my own Microvision games and using an emulator? Whatever happened to this? Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 1 Author Share Posted January 1 I'm still working on the shells... whenever I have spare time and still want to work, that is. Hopefully Barrage 2024. I have no plans for emulator support - that's beyond my expertise. I still plan to have instructions and demo code to program your own games, to be tested and played on a Microvision. 1 1 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 7 Author Share Posted January 7 Top piece partially completed. I still need to do some work to the underside: 2 Quote Link to comment Share on other sites More sharing options...
thegoodwillgamer Posted January 8 Share Posted January 8 That's looking great! What else do you have beyond the shells? Just manufacturing? Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 8 Author Share Posted January 8 2 minutes ago, thegoodwillgamer said: That's looking great! What else do you have beyond the shells? Just manufacturing? Keyboard overlay: I think I can just use a thin lamination, similar to what I've used recently for Intellivision overlays. LCD overlay: I can get the material, in clear form. I should be able to get some paint around the edges, in single color. Box inserts: I've given up on the foam, and I'll be switching to some sort of cardboard insert to hold the cartridge. Everything else I think is ready to go - ready for manufacture (with some items already done). I'll need to review a few things, such as figure out if it's going to be Barrage 2024, or something else. 3 Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted January 15 Share Posted January 15 Really interested in that project Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 28 Author Share Posted January 28 The shell is ready for a prototype. No use working on the last couple of percent until I get a couple of samples printed: All printed assets were also finalized, including box, manual, label, keyboard overlay. Game renamed, again, to Barrage 2024. Here's part of the box: 2 1 Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted January 28 Share Posted January 28 I really am looking forward to this. I want one, I don't care about the price. I have a FOMO. 1 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted February 6 Author Share Posted February 6 Quick update: the initial shell prototypes arrived. I've got a lot of minor modifications to make to the design, and hopefully in a few weeks or so I'll have new pieces in hand that fit like a glove. All other assets are fully designed and figured out as far as production goes. Most recently the keyboard overlay, the screen overlay, and the cardboard insert that holds the game in the box (sorry, no foam at this point). I also designed the box bottom, which I didn't have prepared before. Barrage 2021, 2022, and 2023 are dead ... ... ... Long live Barrage 2024! 2 1 Quote Link to comment Share on other sites More sharing options...
+cvga Posted February 18 Share Posted February 18 I definitely want one (or two) of these. Simply amazing and I love that you've created a new Microvision game!!! 1 Quote Link to comment Share on other sites More sharing options...
the-topdog Posted March 14 Share Posted March 14 I'm interested if you do another run. 1 Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted March 14 Share Posted March 14 Did I miss out or something? Quote Link to comment Share on other sites More sharing options...
+5-11under Posted March 14 Author Share Posted March 14 4 hours ago, atari2600land said: Did I miss out or something? No, you haven't missed out. I'm working with the 3D supplier to make sure the parts are the correct size... . 3 Quote Link to comment Share on other sites More sharing options...
Spintatotale Posted March 27 Share Posted March 27 wowww! I've been following this fantastic project for 4 years or so... I really hope to be able to buy one! If I can be useful to the project in any way I'm available!! 1 Quote Link to comment Share on other sites More sharing options...
+stupus Posted March 27 Share Posted March 27 Awesome work! I definitely want 1!! Quote Link to comment Share on other sites More sharing options...
