+stephena Posted January 13, 2021 Share Posted January 13, 2021 Then the problem must be elsewhere. The only thing that option in Stella does is randomize RAM, or zero it. Quote Link to comment Share on other sites More sharing options...
TheMajorHavoc Posted January 14, 2021 Share Posted January 14, 2021 On 1/12/2021 at 10:46 PM, chewy said: is it okay if i rename my cart file: NeXion2- alienVpredator.bin? There are enough code changes that it's own name is warranted. ? 1 Quote Link to comment Share on other sites More sharing options...
chewy Posted January 14, 2021 Share Posted January 14, 2021 so far i visually am having trouble w/ it all but i aboustely have it loaded up and i do recknoize the efforts you put in. i cant seem to see the bullets of the gun or when to shoot or really anything much- light sixer here- and yes its way better than the stella.....but can you plz help me play it better, Quote Link to comment Share on other sites More sharing options...
TheMajorHavoc Posted January 15, 2021 Share Posted January 15, 2021 (edited) Oh, I better post some better directions for those who haven't played NeXion. up - walk in the direction you are facing back - walk backwards Left and right - rotate (change direction) fire button+ down to shoot fire button+ Left or right to walk sideways top of screen is the compass - it will blink in the direction you are facing (N-S-E-W) bottom of screen is the map - your position is indicated by the white square. When you kill enough Xenos, a skull will drop on the level. it will blink on the map when you get near. touch it a press fire button to pick it up It will allow you to exit to the next level.....when you find the door middle of screen is the 3d view. shoot xenos when they are in front of you. Xenomorphs make a lot of noise when they see you. If you hear them. change directions because it's headed for you! They like to hunt in packs! PLAY HINTS : Xenos spawn in the 4 corners of the level. They will respawn there also, so don't try to make a last stand in those areas! If you a getting eaten alive by a pack of aliens, run backwards Best hint is to find the door on each level 1st. Edited January 15, 2021 by TheMajorHavoc added to download post 1 1 Quote Link to comment Share on other sites More sharing options...
sn8k Posted January 15, 2021 Author Share Posted January 15, 2021 Man this is some next level shit. What a game. Still can't get over how good the aliens look. The end result definitely exceeded my expectations. Just don't stumble on a nest. 1 Quote Link to comment Share on other sites More sharing options...
