apersson850 Posted January 29, 2021 Share Posted January 29, 2021 Correct. RESET and LOAD. 2 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted January 29, 2021 Share Posted January 29, 2021 If you can get it working again, you can test as follows: If the computer immediately resets on button press -> Reset If it locks up, restart, do a CALL LOAD(-4,131,224,0,36) and try again. If it resets -> Load interrupt 4 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted January 30, 2021 Author Share Posted January 30, 2021 My HFDC seems to be defect No reaction on anything.... it´s back to the shelf now As there was so much struggle today, I decided to test my floppydrives first. 1 4 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 7, 2021 Author Share Posted February 7, 2021 Here the theory about my airflow: just remember, the 2 additional fans in the front of the PEB: I mounted the external heatsink from the Myarc DDCC-1 sitting very tight on the backside of the PEB, 1.) right in the airstream of fan #3 and 2.) with full contact to the PEBs cold metal housing. This really works good. Before, this thing was so damn hot that I could not hold in my hands after 10 minutes or so, NOW, it´s just a little bit warm and that after half an hour of full business with 4 drives ?️♂️ When I touch the other cards, Geneve and Ramdisk, this is no more such hot as before. Much better. (But the top cover must be closed that this concept works) And it is not loud or so, with the 2+1 fans. They are not reduced in speed at this moment, this maybe will follow when I got the exact temperatures. (How do I get them ??? With some expensive toys ?) 1 Quote Link to comment Share on other sites More sharing options...
Sid1968 Posted February 10, 2021 Share Posted February 10, 2021 (edited) On 1/30/2021 at 7:22 PM, Schmitzi said: My HFDC seems to be defect No reaction on anything.... it´s back to the shelf now As there was so much struggle today, I decided to test my floppydrives first. I really dont know what a HFDC is. But, have you already tried another transformer / power supply? Edited February 10, 2021 by Sid1968 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 10, 2021 Author Share Posted February 10, 2021 30 minutes ago, Sid1968 said: I really dont know what a HFDC is. But, have you already tried another transformer / power supply? At the moment we think this may be the problem: (last pic in the post): https://atariage.com/forums/topic/316273-geneve-9640-configuration-questions-over-questions/?do=findComment&comment=4748242 Quote Link to comment Share on other sites More sharing options...
Ruggers Customs Posted February 10, 2021 Share Posted February 10, 2021 Here is a no cut F18a modded TI-99/4a I did for a customer a week ago. Module is bolted on so no adhesives were used to secure it. Non destructive so no damage was done to the shell and it 100% reversible. 10 1 Quote Link to comment Share on other sites More sharing options...
Sid1968 Posted February 10, 2021 Share Posted February 10, 2021 (edited) 1 hour ago, Schmitzi said: At the moment we think this may be the problem: (last pic in the post): https://atariage.com/forums/topic/316273-geneve-9640-configuration-questions-over-questions/?do=findComment&comment=4748242 So the first thing to do is to see if all cables are properly connected. Maybe change the power cord. Then use a different power supply / transformer. If you have a circuit diagram, you should measure whether the voltages are correctly applied everywhere. If you don't understand anything about measuring, I would have re-soldered the soldering points in your place. Just heat it up again. They don't look really fresh anymore. Maybe you have a cold solder joint somewhere on the board. I've already had that on one of my VIC-20s. I don't know the circuit diagram, but does the left capacitor leg touch the contact on the right? It would certainly not damage your board or the contacts if it was cleaned with isopropanol. Do everything at your own risk. Edited February 10, 2021 by Sid1968 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted February 10, 2021 Share Posted February 10, 2021 43 minutes ago, Ruggers Customs said: Here is a no cut F18a modded TI-99/4a I did for a customer a week ago. Module is bolted on so no adhesives were used to secure it. Non destructive so no damage was done to the shell and it 100% reversible. Damn! That's nice! Anymore pics... like of the interior? 2 Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 10, 2021 Share Posted February 10, 2021 50 minutes ago, Ruggers Customs said: Here is a no cut F18a modded TI-99/4a I did for a customer a week ago. Module is bolted on so no adhesives were used to secure it. Non destructive so no damage was done to the shell and it 100% reversible. Lovely!! But how'd you route the VGA cable without pinching it? That is a really nice shell 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 10, 2021 Share Posted February 10, 2021 I assume he removed that old connector on the back of the ti? 1 Quote Link to comment Share on other sites More sharing options...
Ruggers Customs Posted February 10, 2021 Share Posted February 10, 2021 6 minutes ago, Omega-TI said: Damn! That's nice! Anymore pics... like of the interior? Ty sir! I just have the pics of the power supply board and the mobo out of the case. There's not really anything else to show. The mounting brackets are covered up by the rf shield so no way to get a real good picture of that. Inside the signal box is just the flat cable for the vga, two red led light strips and wires for the audio. After I designed and printed the box, I remembered that composite no doesn't exist with the f18a. So the yellow jack is on there for looks haha. Recapped both boards and the f18a just plugged into the mobo. I had to replace that 9918 single wipe socket with a machined pin socket. 3 Quote Link to comment Share on other sites More sharing options...
Ruggers Customs Posted February 10, 2021 Share Posted February 10, 2021 7 minutes ago, Tursi said: Lovely!! But how'd you route the VGA cable without pinching it? That is a really nice shell The 5 pin din is removed since there's no need for it anymore. That will go back to the customer along with the tms9918 & heatsink. The flat cable had to be cut and folded over to fit through the hole. Then I just soldered all the wires back together inside the box and heat shrinked every wire. 1 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 11, 2021 Share Posted February 11, 2021 Right.. makes sense. I read "non-destructive" as "no changes that require a soldering iron". Definitely easy to reverse though 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted April 24, 2021 Author Share Posted April 24, 2021 Keyboard Mod "Readiness" Good Morning 2 Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted April 24, 2021 Share Posted April 24, 2021 This is my test end development system with in the background my Geneve system. The test end development system contains an RS232 card with HDX, SAMS memory card, IDE card, TI diskcontroller and a card with stuff I'm working on (usually a 10 years project). In the front the first version of the TiBus project (see my website ti99-geek.nl for some details of the first year ... still nine years to go). I'm using a switching power supply here ... all cards have their voltage regulators removed. 7 Quote Link to comment Share on other sites More sharing options...
Nick99 Posted April 30, 2021 Share Posted April 30, 2021 (edited) Here it is, probably the only pink TI-99/4A in the world! What if TI hade made computer in different colors, maybe that could have been a success? I had this computer laying around for no use, it had a lot of scratches on the plastic, so I decided to save it from not being used. It is my daughters computer for her to enjoy, it has an F18A (thanks @Hans23!), FinalGrom99, TIPI with a mouse and it works just fine, I noticed that the power led doesn't work. The color is called Hell Pink and I left the plastic shell to a professional paint shop to remove the scratches and paint it. Edited April 30, 2021 by Nick99 12 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted April 30, 2021 Share Posted April 30, 2021 fantastic! a lady TI99 ahah 1 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted October 9, 2021 Share Posted October 9, 2021 Just added an RS232 card and printer today. 3 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted October 9, 2021 Share Posted October 9, 2021 This is my heavily modified system. no TI keyboard. KB to USB adapter to KVM. F18a to HDMI. SAMS and TiPi Cartridge port extension cable. FinalGrom99. on a shelf between other computer components not related to my TI. 3 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 9, 2021 Share Posted October 9, 2021 2 minutes ago, Sinphaltimus said: This is my heavily modified system. no TI keyboard. KB to USB adapter to KVM. F18a to HDMI. SAMS and TiPi Cartridge port extension cable. FinalGrom99. on a shelf between other computer components not related to my TI. Speechless Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted October 9, 2021 Share Posted October 9, 2021 7 minutes ago, GDMike said: Speechless This is my daily keyboard. Also connected to the KVM. It is shared with all the system logo stickers on it. 5 Quote Link to comment Share on other sites More sharing options...
