+Cafeman Posted October 13, 2001 Share Posted October 13, 2001 HITCLR EQU $C01E ;Collision registers clear What is the purpose of this GTIA memory address? Also, after detecting a collision, is it necessary to reset registers in any way? My main character is Player0 and Player1, one of the lightning bolts is Player2. I detect if Player2 has collided with Player0 for a death routine, however, it seems that something happens sometimes where the check fails. I can only guess that perhaps Player2 Lighting might have collided with Player1 (part of Koffi character) and set the switch differently; or perhaps something else? [ 10-15-2001: Message edited by: Cafeman ] Quote Link to comment Share on other sites More sharing options...
DanBoris Posted October 13, 2001 Share Posted October 13, 2001 You second question answers your first Any collisions that occur in a frame will set the appropriate collision bit which will stay set until you write to HITCLR. Since collisions can occur anywhere in the frame it's a good idea to check for them during VBLANK, then write HITCLR before the end of VBLANK. Dan Quote Link to comment Share on other sites More sharing options...
+Cafeman Posted October 15, 2001 Author Share Posted October 15, 2001 Here is another color question. I recall in Atari BASIC, that I could use Setcolor to (for example) modify a color from Dark Red to Light Red. Is there some way to vary intensity in Antic E, a 4-color mode? Right now I load a #$xx value into a color register. I assume that modifying a certain bit might change the intensity / brightness put keep the same hue? Then again, I never used ANtic E in BASIC. Quote Link to comment Share on other sites More sharing options...
DEBRO Posted October 22, 2001 Share Posted October 22, 2001 To determine the color of a player use the chart: code: 0 - Grey 8 - Blue 1 - Gold 9 - Light blue 2 - Orange 10 - Turquoise 3 - Red-orange 11 - Green -blue 4 - Pink 12 - Green 5 - Purple 13 - Yellow-green 6 - Lavender (I think) 14 - Orange-green 7 - Blue 15 - Light orange and use the formula player color = color number * 16 + brightness (luminance) The brightness should be an even number from 0 to 14. The exact hue of the color may vary according to how the TV or monitor is adjusted. Quote Link to comment Share on other sites More sharing options...
