BydoEmpire Posted January 7, 2021 Share Posted January 7, 2021 I ran into a recent set of changes spamming tty with this: please report seeing this message. *** (497): WARNING, there seems to be a problem. your code may not run properly. please report seeing this message. ... *** (497): WARNING, there seems to be a problem. your code may not run properly. please report seeing this message. ^C^CTerminate batch job (Y/N)? y d:\dev\a7800\7800basic\fantasy\fantasy7800> Wondering what it means, but I suppose at the very least I'm reporting seeing it. I haven't narrowed down the cause, but I wrote a big chunk of code last night. I'm starting to selectively comment out chunks to track it down... Quote Link to comment Share on other sites More sharing options...
BydoEmpire Posted January 7, 2021 Author Share Posted January 7, 2021 (edited) Interesting Where I define all my other constants I have: const MAP_SIZE = 8 This is the offending line: z = y*MAP_SIZE + x but changing that to z = y*8 + x fixes the problem. Edited January 7, 2021 by BydoEmpire Quote Link to comment Share on other sites More sharing options...
RevEng Posted January 8, 2021 Share Posted January 8, 2021 The warning dates back to the bB codebase, but I understand why it's showing. You're multiplying a value by a constant, and the interpreter doesn't know if it's a multiply by a power-of-two or not, so it's missing the ability to optimise the multiply. For sure, just using "8" works. "def" should work too. It looks like I missed adding def to the 7800basic manual, so you can learn about it via the bB entry for it, for now. 1 Quote Link to comment Share on other sites More sharing options...
