+InsaneMultitasker Posted May 13, 2022 Author Share Posted May 13, 2022 Are there any Geneve users who are wanting to and/or are ready to forgo using a floppy disk controller at CRU >1100 in favor of the TIPI DSK devices? The Geneve device powerup routine is now configured to test for TIPI and if present at >1100, the OS automatically maps DSK1-4 to the TIPI drives. We now working through the OS initialization code, cleaning up some old code and documenting some of the lesser-known internal code with comments. 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted May 15, 2022 Author Share Posted May 15, 2022 On 4/30/2022 at 3:40 PM, InsaneMultitasker said: This also means that many of the hard-coded CRU restrictions implemented since MDOS 2.50S will be removed, though a few are necessary due to their function e.g., RamHD devices will remain at >1400 and >1600. One caveat to removing CRU restrictions is that the HFDC and SCSI cards share the "WDS" names in their respective DSR EPROMs. After deep-diving the OS/XOP/DSR powerups, I no longer feel as strongly about removing the SCSI card's CRU >1200 requirement. The OS powerup routine skips >1200 to avoid incorrectly detecting a SCSI card as an HFDC. And for the detection to succeed without CRU restrictions, the SCSI card would need to be identified first and its CRU skipped during the HFDC detection. (This is how the Horizon Ramdisk CFG program operates). The IDE code incorporates a FIND routine, so maybe we can leverage it for the SCSI and HFDC powerups. I'll give this a bit more thought. Also, it seems that the OS does not validate the presence of a floppy controller so depending on what the OS thinks is at >1100, the IO routines will blindly attempt to use TI, CorComp, or Myarc routines when DSKx access is requested. We'll confirm this and attempt to block the routines if there is no card present. 3 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 18, 2022 Share Posted May 18, 2022 Is there a DIR ` that will only show directories? Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted May 18, 2022 Author Share Posted May 18, 2022 33 minutes ago, dhe said: Is there a DIR ` that will only show directories? try DIR `R 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 18, 2022 Share Posted May 18, 2022 Can someone explain to me how these file sizes are computed? Quote Link to comment Share on other sites More sharing options...
+9640News Posted May 18, 2022 Share Posted May 18, 2022 Dan, In CLI\GETCATS is where the code is: Here's some info: * * do a winchester catalog... * 1) read record zero of "WDSx." to get name, size, free * 2) read dir entries, move the name, creation date * 3) read file entries, * a) set flags * b) set sector count #1 * c) set eof offset if pgm image * d) set record length * e) set sector count #2 (used by pgm image) * f) compress creation date * g) compress update date The GETCATS source file is a very complex source file that got even more complex handling the TIPI since the TIPI could have more than 127 files and more than 114 directories. We had to limit the number of files and directories display for the TIPI, because it buffered that information in the buffer page of the CLI at >8000 to >9FFF, and the page maps at >A000 and up were used for other functions. 2 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 19, 2022 Share Posted May 19, 2022 Is there an unarchiver that runs on the GeneveOS command line? I noticed dm has a Y option that says dearchive a file. When I press it, DM returns - can't find BLOB? Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted May 19, 2022 Author Share Posted May 19, 2022 23 minutes ago, dhe said: Is there an unarchiver that runs on the GeneveOS command line? I noticed dm has a Y option that says dearchive a file. When I press it, DM returns - can't find BLOB? Yes. I released it either in this topic or the MDOS 7.3 topic, a few months ago along with a few other program updates. 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted May 19, 2022 Author Share Posted May 19, 2022 29 minutes ago, dhe said: Is there an unarchiver that runs on the GeneveOS command line? I noticed dm has a Y option that says dearchive a file. When I press it, DM returns - can't find BLOB? BLOB returns wayyyyy too many results, so I plodded through my posts. Here is message. I don't recall much if any feedback on these programs, then again we are a quiet bunch. gh m 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 19, 2022 Share Posted May 19, 2022 fwiw -- I've been updating Beery's HD image - when it's good, I'll let Beery and you look it over and then release it. It's got most if not all the updated software and also now has fixed genprog libs. Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 20, 2022 Share Posted May 20, 2022 blob was a big help. I was trying to read through lib-doc of tic (it's a fairly long file) and ran into some none GeneveOS issues. 1) dm does a great job of listing long files, the downsides are you can't page up and you can't search. 2) loading the file in to qde results in a truncated file. 3) Peter Muys Editor locked up when I tried to load the file. Does anyone have a prefered way to read large files, something along the lines of less for linux? Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted May 21, 2022 Author Share Posted May 21, 2022 Buffer capacity from least to most: QDE->EDIT->MyWord->Funnelweb (w/192k vram buffer) TI Image Tool and TI99Dir work well from the PC side. 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted May 21, 2022 Author Share Posted May 21, 2022 11 hours ago, dhe said: blob was a big help. 3) Peter Muys Editor locked up when I tried to load the file. Did you use blob from the command line or use the Directory Manager functionality to launch blob with the "Y" keypress? I thought that EDIT stopped loading (and ignored the rest of the file without warning!) if the buffer filled to capacity. Lockup might have been caused by the buffer or by control characters in the file. Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 21, 2022 Share Posted May 21, 2022 2 hours ago, InsaneMultitasker said: Did you use blob from the command line or use the Directory Manager functionality to launch blob with the "Y" keypress? I thought that EDIT stopped loading (and ignored the rest of the file without warning!) if the buffer filled to capacity. Lockup might have been caused by the buffer or by control characters in the file. Blob from the command line. A lot of the stuff we have from Client came via a file dump called GenSrc.Zip that 9640news got for us from Clint a while back. It appears all of his builds and docs at some point where done on the pc. There is a chance in the text file, a odd character might have creeped in - thanks for the info largest to smallest. Maybe writing a list routine would be a good exercise for me. 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 15, 2022 Author Share Posted June 15, 2022 Reference note for future review: Validate HFDC step rate routine, how it is stored, and whether the VIB-based value is correct. * * MFM HardDrive Step Rate * Nov02 2001 - Modified to original defaults TT (>E700) * LI R0,>E700 ;x7xx maximum head step rate; x0xx is buffered seek MOV *R2,*R2 HAVE WE HIT THE HD BEFORE? JEQ IOFDS4 NO ABS @ERRSMD ARE WE IN THE ERROR RESTORE MODE? JNE IOFDS4 YES, SO GO SLOWLY TO SECTOR 0 MOVB @2(R2),R0 GET STEP SPEED IF WINCHESTER ;the VIB parms may be incorrectly setting the step rate ORI R0,>E0A5 IOFDS4 MOVB R0,*R1 MOVB @CBHA5,*R1 * MOVB @CBH02,*R1 SET THE HEAD LOAD DELAY FOR 2 INCREMENTS 2 Quote Link to comment Share on other sites More sharing options...
Willsy Posted June 15, 2022 Share Posted June 15, 2022 Just an observation that line ORI R0,>E0A5 - that might want a comment to explain what the 'magic number' EA05 is 4 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 15, 2022 Author Share Posted June 15, 2022 6 hours ago, Willsy said: Just an observation that line ORI R0,>E0A5 - that might want a comment to explain what the 'magic number' EA05 is But won't that ruin the magic? <grin> The MSByte is helping to set the mode register value for the operation, in this case, it will be set to hard drive mode, internal ECC checking, density, and a step rate in the three least significant bits according to the table in the 9234 manual. The ORI of >E0 ensures that bits 7-3 are properly set when combined with the step rate in R0 (in bits 2-0). As for the LSByte >A5, that is almost certainly just 'placeholder' data, since as far as I could tell, only the MSByte of R0 is ever used in this low level routine. (Edit: whether the value is being set correctly via the VIB requires further analysis) 3 Quote Link to comment Share on other sites More sharing options...
+dhe Posted June 15, 2022 Share Posted June 15, 2022 Geneve OS development discussion this can be taken two ways: a discussion on development of the Geneve OS, or a discussion of developing under the geneve OS. Since it's convenient - I'll be taking it to mean the latter, I have a problem or something I don't understand when trying to link with genprog... Yet... LIBR Maint lib_4a symtab shows: And yes, I've discovered when loading files with the linker, you don't get errors, if the files not found or wrong. And yes, I've discovered all commands to the linker, need to be up case! ? 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 15, 2022 Share Posted June 15, 2022 Dan, To date, I do not know of anyone actually using the LIBR capabilities of GenLink. The only thing I can suggest is rebuilding the library from scratch to see if it is a problem with the library file itself, or a bug with the use of the LIBR command. Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 15, 2022 Author Share Posted June 15, 2022 13 minutes ago, dhe said: a discussion on development of the Geneve OS, See post #1. (We do stray from time to time but the OS is the primary topic) Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 16, 2022 Author Share Posted June 16, 2022 11 hours ago, InsaneMultitasker said: As for the LSByte >A5, that is almost certainly just 'placeholder' data, since as far as I could tell, only the MSByte of R0 is ever used in this low level routine. @Willsy the answer was staring me/us in the face. Programming intent divination for 30+ year old code is always interesting. Instead of moving R0Lsbyte, the code moves the value @CBHA5, since R0 may or may not be properly manipulated due to the error/test logic. ORI R0,>E0A5 IOFDS4 MOVB R0,*R1 MOVB @CBHA5,*R1 <<<-- A5 * MOVB @CBH02,*R1 SET THE HEAD LOAD DELAY FOR 2 INCREMENTS 4 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 16, 2022 Author Share Posted June 16, 2022 20 hours ago, dhe said: And yes, I've discovered when loading files with the linker, you don't get errors, if the files not found or wrong. Do you have an example of this? When I run LINK, it generates an error if the object file is not found. The distributed version of $MAKE has some trouble with missing date/time stamps, though that issue has been mostly (completely?) resolved with a disassembly and update to the code. @9640News we'll have to remember to release the updated program file with the next update. Quote Link to comment Share on other sites More sharing options...
+dhe Posted June 16, 2022 Share Posted June 16, 2022 The ADD command will throw an error, if the file is not found. It's the LIBREF command that doesn't really care what you type! ? I thought I'd be clever and just ADD the whole LIB_4A - and that is accept - but it doesn't work. (I don't care that I had all the routines listed) I think most of my playing can be found below, the LIST command is also very helpful. I also tried renaming LIB_4A to LIB4A - because list inserted a + after _ - maybe that's ok. I don't think libref was implemented in the version of link I have = GenLINK V1.03 ie.. LIBREF = NOP ]DEBUG DDEBUG ]BLOCK >A---000,>FFD8 ]ADD STATUS Block status: Start Current End A000 A000 FFD8 Total Free: >5FD8, >5FD8 in largest section.. 0 unresolved REF entries.. 0 DEF entries in table.. ]ADD NEOO ]STATUS Block status: Start Current End A000 A1AA FFD8 Total Free: >5E2E, >5E2E in largest section.. 3 unresolved REF entries.. 4 DEF entries in table.. ]LIBREF LIB_+4A ]STATUS Block status: Start Current End A000 A1AA FFD8 Total Free: >5E2E, >5E2E in largest section.. 3 unresolved REF entries.. 4 DEF entries in table.. ]ADD LIBR_+4A ]LSTATUS Block status: Start Current End A000 A1AA FFD8 Total Free: >5E2E, >5E2E in largest section.. 3 unresolved REF entries.. 4 DEF entries in table.. ]HELP HELP gives useful information EXIT Returns to MDOS ADD "tagged object file" PAGES define address space to load COPY <src>,<dst>,<cnt> SYMTAB list all REF/DEF entries UNDEF list all undefined REFS BLOCK <start address>,<end address> STATUS list status for defined blocks LIBREF "library name" SAVEALL "file"[,type] PSAVE "file",<type>,<start>,<stop> DEBUG "debugger output file" LIST "list file" RESET clear all tables CLEAR clear block definitions EVAL <expr>, displays value MDOS <cmdstr> executes MDOS commands * indicates comment line ]SYMTAB DEF table listing: A000 SFIRST A1AA SLAST A004 START A000 SLOAD ]UNDEF Undefined REF listing: A01C VSBW A14A VWTR A070 VMBW ]LIBREF MDOS ]STATUS Block status: Start Current End A000 A1AA FFD8 Total Free: >5E2E, >5E2E in largest section.. 3 unresolved REF entries.. 4 DEF entries in table.. ]EXIT Quote Link to comment Share on other sites More sharing options...
+dhe Posted June 16, 2022 Share Posted June 16, 2022 Trying to bring tipi online in mame, I ran in to - what I think is an oddity. But it will take letters A-J: It's very important to remember to add a : at the end of assign and dir commands! ? Quote Link to comment Share on other sites More sharing options...
+dhe Posted June 16, 2022 Share Posted June 16, 2022 ps... I read the MDOS730 documentation - it seemed to indicate you can assign drive letters up to the letter P: Quote Link to comment Share on other sites More sharing options...
