BydoEmpire Posted January 10, 2021 Share Posted January 10, 2021 in 7800 basic, the docs say $ to specify a hex value. I had previously been using 0x which seemed okay. Do both work in all situations? for example: temp1= temp2&0xf vs. temp1= temp2&$f They seem to, but I don't want to assume, because I've spent days debugging some tricky code and I'm looking for anything silly I may have overlooked. Quote Link to comment https://forums.atariage.com/topic/315670-7800-basic-hex-0x-vs/ Share on other sites More sharing options...
BydoEmpire Posted January 10, 2021 Author Share Posted January 10, 2021 FWIW, I seemed to have fixed the bug I was working on. One of those creepy ones where you're not exactly sure what you did to fix it. I had a bunch of compounded if then lines in my algorithm, and something didn't play nicely. I am curious if there are any limitations of $ vs. 0x , but I can verify now that the major issues seem fixed. 1 Quote Link to comment https://forums.atariage.com/topic/315670-7800-basic-hex-0x-vs/#findComment-4721589 Share on other sites More sharing options...
