ericpskl Posted January 22, 2021 Share Posted January 22, 2021 Can anyone confirm whether or not they are able to program AMD AM2732B EPROMs on a TL866II + programmer? This model is in the supported EPROM list for the programmer, but I haven't been able to program any of the EPROMs that I purchased from eBay. They don't appear to be rebranded or painted (acetone test). Spec sheet shows VPP at 12.5 volts, so the TL866II+ should be able to handle them just fine. Programmer works fine on other EPROMS. Any ideas? Quote Link to comment Share on other sites More sharing options...
pcrock Posted February 1, 2021 Share Posted February 1, 2021 (edited) What is the error you got??? I tried to program some AM2732B using my willem programmer and all works fine. Edited February 1, 2021 by pcrock Quote Link to comment Share on other sites More sharing options...
ericpskl Posted February 1, 2021 Author Share Posted February 1, 2021 The error log out of Xgpro isn't very helpful: Quote ************************************************************** APP Version : 10.71 Device : AM2732B @DIP24 ************************************************************** Pins Detected Passed! Programming FLASH ... Programming ...Failed @pcrock, what are the voltage and timing settings that you used to program the AM2732B on your Willem? I've tried to increase the programming voltages and timeouts, but nothing worked. Thanks! Quote Link to comment Share on other sites More sharing options...
