Giles N Posted January 25, 2021 Share Posted January 25, 2021 I imported a japanese Sega Master. It’s powerplug seems ‘american’ and 100 v. (I’ve tested similar on a jap.Famicom) But the antenna seems really wierd with this switch-box, and plug-in to the TV seems like some old stereo-cables, with twisted metal/bronze-wiring and some plastic end. Anyone who knows what I need to comnect it to? A jap.TV? A particular way of plugging-wiring? And where? (On the back of the TV)? Thanks for inputs, if anyone knows anything. 1 Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/ Share on other sites More sharing options...
emerson Posted January 25, 2021 Share Posted January 25, 2021 That description unfortunately doesn't help much. Would you care to show some pictures? Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4735610 Share on other sites More sharing options...
Giles N Posted January 26, 2021 Author Share Posted January 26, 2021 5 hours ago, emerson said: That description unfortunately doesn't help much. Would you care to show some pictures? Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4735914 Share on other sites More sharing options...
Steven Pendleton Posted January 26, 2021 Share Posted January 26, 2021 If you have a Genesis 1/MD 1 cable, you can use that since it's the same thing. It does have native RGB output, as well, so you can use that if you want/can. Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4735925 Share on other sites More sharing options...
bluejay Posted January 26, 2021 Share Posted January 26, 2021 (edited) @Giles N First, cut the end off, just below where the black coating ends, so you'll have a nice clean cable. Then, strip some of the black coating off, be careful not to cut the metal mesh and plastic inside. Peel back the metal mesh but dont cut it off. Strip the plastic center but don't cut it; it contains a metal wire inside. Buy a coax f type connector; make sure it's just the outer metal bit with no wires. Stick it onto your cable. The metal mesh is the ground so make sure it makes contact with the ground of the f type connector. The central pin will be the coax pin. After that you can just plug it into the RF jack on the back of your TV. Or you could use an old Japanese TV that has the screws and clamp on the back to directly install the wire. You'll still need to do the stripping process though. Reading through what I just read and I dont think it's very easy to understand, at least, not with pictures... But it's what I did when I got my Famicom which had the exact same type of switchbox. I remember reading a tutorial online but can't find it anymore. By the way, if you are hooking this up to an NTSC television you must tune to channel 95 if your console is set to channel 1, or channel 96 if it's set to channel 2. Here's a reference pic; you want to make the end of your cable look like 3. Buy one of these, stick it onto the cable. Edited January 26, 2021 by bluejay 1 1 Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4735973 Share on other sites More sharing options...
Giles N Posted February 1, 2021 Author Share Posted February 1, 2021 On 1/26/2021 at 7:48 AM, bluejay said: @Giles N First, cut the end off, just below where the black coating ends, so you'll have a nice clean cable. Then, strip some of the black coating off, be careful not to cut the metal mesh and plastic inside. Peel back the metal mesh but dont cut it off. Strip the plastic center but don't cut it; it contains a metal wire inside. Buy a coax f type connector; make sure it's just the outer metal bit with no wires. Stick it onto your cable. The metal mesh is the ground so make sure it makes contact with the ground of the f type connector. The central pin will be the coax pin. After that you can just plug it into the RF jack on the back of your TV. Or you could use an old Japanese TV that has the screws and clamp on the back to directly install the wire. You'll still need to do the stripping process though. Reading through what I just read and I dont think it's very easy to understand, at least, not with pictures... But it's what I did when I got my Famicom which had the exact same type of switchbox. I remember reading a tutorial online but can't find it anymore. By the way, if you are hooking this up to an NTSC television you must tune to channel 95 if your console is set to channel 1, or channel 96 if it's set to channel 2. Here's a reference pic; you want to make the end of your cable look like 3. Buy one of these, stick it onto the cable. Thanks a lot for info! What are connection-pieces (of metal) called (if I want to search for it)? 1 Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4741544 Share on other sites More sharing options...
bluejay Posted February 1, 2021 Share Posted February 1, 2021 38 minutes ago, Giles N said: Thanks a lot for info! What are connection-pieces (of metal) called (if I want to search for it)? Try F-type screw on connector. Make sure to get one that's just the outer metal bit so you can stick the cable inside of it. Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4741551 Share on other sites More sharing options...
emerson Posted February 1, 2021 Share Posted February 1, 2021 If you check the electrical isle at your local big box hardware store they might have some as well. 1 Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4741846 Share on other sites More sharing options...
Giles N Posted February 1, 2021 Author Share Posted February 1, 2021 (edited) I bought these: Right, wrong? Edited February 1, 2021 by Giles N Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4741874 Share on other sites More sharing options...
bluejay Posted February 1, 2021 Share Posted February 1, 2021 (edited) 37 minutes ago, emerson said: If you check the electrical isle at your local big box hardware store they might have some as well. I actually bought a few from Home Depot for $5. So yeah, hardware stores do carry them. But he bought the correct kind off ebay so I hope that works out. By the way, I'd recommend you get some kind of aftermarket power supply that's designed for 110-120v. It's compatible with a Super Famicom one, if that helps. Edited February 1, 2021 by bluejay Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4741880 Share on other sites More sharing options...
Giles N Posted February 15, 2021 Author Share Posted February 15, 2021 Anyone here who knows whether a jap. sega master uses a particular frequency/TV channel? Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4754208 Share on other sites More sharing options...
emerson Posted February 15, 2021 Share Posted February 15, 2021 11 minutes ago, Giles N said: Anyone here who knows whether a jap. sega master uses a particular frequency/TV channel? Bluejay gives the channels at the end of post #5. You may have to rescan your channels with the console turned on and connected to the rf input. Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4754220 Share on other sites More sharing options...
Giles N Posted February 15, 2021 Author Share Posted February 15, 2021 Thanks all, but I just cannot get my NTSC TV to go beyond ch.69. There are menus saying ‘DTV’ and CATV’ Dunno what it means. Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4754361 Share on other sites More sharing options...
emerson Posted February 16, 2021 Share Posted February 16, 2021 DTV is Digital TeleVision and CATV is CAble TeleVision. You want CATV as this implies analog video. If there is an option for ANTenna you want that instead. If you haven't yet, you will need to rescan your channels with the console turned on and connected. If you tried that and still can't get past ch69 then I suggest trying the cables suggested by Steven in post #4. Also, double check that the center conductor of the coax cable is not shorted to the new connector and that the new connector is making good contact with the coax shield wires. 1 1 Quote Link to comment https://forums.atariage.com/topic/316312-got-japanese-sega-master-what-tv-do-i-need-the-antseems-pretty-wierd/#findComment-4755237 Share on other sites More sharing options...
