baybgrlus Posted August 7, 2003 Share Posted August 7, 2003 They each appear to complete except for the modulator(?) that attaches to the TV. I hooked each up with a modulator that I normally use with C64. The original plugs in to power and the II has an external power supply. I have a cartridge in the slot but nothing comes on the screen on either. I found a channel switch on the II but not on the original. Dont see a power light on the original but there is one on the II and it lights when I push it but will not turn off when I push it again. The monitor is an old Sears monitor combo that I use on my C64. Do I need a special modulator to hook these up? Should the VT connect box be attached to VHF or UHF? Quote Link to comment Share on other sites More sharing options...
tyranthraxus Posted August 9, 2003 Share Posted August 9, 2003 The TV/Game switch you use for your C=64 will work. I had a similar problem with the INTV. They are damn finicky machines. Make sure your system and carts are clean and firmly inserted. I bought 3 INTVs each one was dead or so I thought... now they all work! Anyone want to buy a INTV? Quote Link to comment Share on other sites More sharing options...
JB Posted August 12, 2003 Share Posted August 12, 2003 BTW, the INTV1's channel switch is on the bottom right above the legal boilerplate stickers. . Flip it upside down and it's plain as day. Quote Link to comment Share on other sites More sharing options...
