Room initialization pattern in multi-rooms game
Vincehood
Hi,
what is the recommendation for multiple-rooms game when drawing new rooms?
Should all the following commands be used in each room: CLS, MODE, DEFINE & SCREEN?
I am wondering since I got various results.
Do you need to reload the cards for each room with a DEFINE even if the rooms can be drawn based on a common set of cards?
Thanks!
/V
CLS and SCREEN should be enough if you're using the same cards for each different screen. You only need DEFINE if you're changing the graphic symbols, and only MODE if you're switching between CS and FGBG mode. Actually you might not even need CLS depending on if your screen fills the entire 20x12 or not.
Edited by carlsson
I identified the cause of the issue (graphics not displayed). I have a procedure per room & I was defining the screen card data elements in each procedure like shown further down.
I believe this an anti-pattern resulting in non sequential interpretation. I have now moved the DATA elements outside the PROCEDURE at the end of the program and it's working fine!
room3: PROCEDURE
 room = 3
 CLS
 WAIT
 SCREEN screen3_cards
 WAIT
 REM 20x12 cards
 screen3_cards:
 DATA $0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200,$0200
END
