GPU interrupt & GPU Object
swapd0
This is driving me crazy.
I have the GPU running into a tight loop waiting, here is the code:
.wait_list:
    load (list_ptr),events
    cmpq #0,events
    jr EQ,.wait_list
    moveq #0,r0             ; don't f*ck parameters address at first iteration
After that code I've inserted an infinite loop that changes the BG register.
When I run the program it works ok because I'm not writing anything into list_ptr (== 0 always), but when I put a GPUOB the GPU interrupt is executed and I leave it with this code (same as docs). And then the background color start to change (returns after the tight loop), this means that the last addqt (???) it's not needed? It's a must because without it, some times it hangs.
; rte
    bclr #3,flags					; serviced
    bset #12,flags					; clear interrupt flag
	load (stack),rts
	addqt #4,stack
	addqt #2,rts					; ???
	jump (rts)
	store flags,(flagsAddr)			; restore interrupt
I don't know why this doesn't work, I've changed the way I was creating the OP list, and now I've a lot of problems when I've a GPU Object and some GPU code running.
Memory dump for the OP list without GPUOB.
Quote
OP list 240 bytes, start at 0000eb10
0000eb00 : 00000000 00000004   STOP
0000eb08 : 55555555 55555555
0000eb10 : 0000001d 600041c3   Jump if VC < top_line
0000eb18 : 0000001d 60008f33.   Jump if VC > bottom_line
0000eb20 : 01f4081d 663201c0.  Bitmap
0000eb28 : 00000002 80a0b00c
0000eb30 : 00c1581d 680001c0.  Bitmap
0000eb38 : 00008000 2008806c
0000eb40 : 00c2081d 6a000340.  Bitmap
0000eb48 : 0000a000 200880eb
0000eb50 : 00c3101d 6c040440.  Bitmap
0000eb58 : 00008000 2008906c
0000eb60 : 00c2101d 6e004540.  Bitmap
0000eb68 : 0000a000 200890ab
0000eb70 : 00c4b81d 70000640. Bitmap
0000eb78 : 00008000 4010a06c
0000eb80 : 00c5181d 72040740  Bitmap
0000eb88 : 0000a000 4010a0ab
0000eb90 : 00c5201d 74040840. Bitmap
0000eb98 : 00008000 8020b06c
0000eba0 : 00c5201d 7600c940. Bitmap
0000eba8 : 0000a000 8020b0ab
0000ebb0 : 00caa81d 78000a40. Bitmap
0000ebb8 : 00008001 0040c06c
0000ebc0 : 00d1281d 7a040b40. Bitmap
0000ebc8 : 0000a001 0040c0ab
0000ebd0 : 0113681d 7c228000. Bitmap
0000ebd8 : 00000000 2000414c
0000ebe0 : 00000000 00000004. STOP
0000ebe8 : 55555555 55555555
Memory dump OP List with GPUOB
OP list 240 bytes, start at 0000eb08
0000eb08 : 0000001d 600041c3    Jump if vc < top_line
0000eb10 : 0000001d 60008f33    Jump if vc > bottom_line
0000eb18 : 00000000 00000002 	GPUOB
0000eb20 : 0115881d 663201c0 	Bitmap
0000eb30 : 00c1081d 68040290 	Bitmap
0000eb40 : 00c1081d 6a040410 	Bitmap
0000eb50 : 00c2101d 6c040510 	Bitmap
0000eb60 : 00c2101d 6e040610 	Bitmap
0000eb70 : 00c3181d 70040710 	Bitmap
0000eb80 : 00c3181d 72040810 	Bitmap
0000eb90 : 00c5201d 74040910 	Bitmap
0000eba0 : 00c5201d 76040a10 	Bitmap
0000ebb0 : 00c9281d 78040b10 	Bitmap
0000ebc0 : 00c9281d 7a040c10 	Bitmap
0000ebd0 : 0113681d 7c400000 	Bitmap
0000ebe0 : 00000000 00000004 	STOP
Edited by swapd0
  • Confused 1
Also, I've checked and I don't smash any register, the interrupt runs in the alternative register bank and the main GPU code runs in the other.
Edit:
IMO the bug is when I return from the interrupt, the GPU doesn't return to the correct address.
Edited by swapd0
There is not enough informations about how the interrupts routine is written to give a solution but, this is what i have done for my FACTS demo :
  • Main code use BANK1
  • Interrupt service code use BANK0
 Initialisation routine :
GPU_STACK				.equ	$F04000
; BANK0 :
OBJ_FLAGS				.equr	r22
vbl_counter				.equr	r26
vbl_interrupts			.equr	r27
pGflags					.equr	r28
cGflags					.equr	r29
cGstack					.equr	r30
pGstack					.equr	r31
;GPU initialisation
gpu_init:
	movei		#G_FLAGS,pGflags			;Flags GPU
	load		(pGflags),cGflags
	bclr		#3,cGflags
	bset		#7,cGflags					;enable op interrupt
	bset		#12,cGflags					;clear pending interrupt
	bclr		#14,cGflags					;select bank0
	store		cGflags,(pGflags)			;mise a jour des flags
	nop
	nop
;Stack Pointer
	movei		#GPU_STACK,pGstack			;adresse SP
	movei		#VblInterrupt,vbl_interrupts
	movei		#OBF,OBJ_FLAGS
	moveq		#0,vbl_counter
Service routine at slot 3 (GPU Object Interrupts):
gpu_int_3:
	jump		(vbl_interrupts)
	nop
	nop
	nop
	nop
	nop
	nop
	nop
GPU Object interrupt routine :
	.long
VblInterrupt:
	storew		r0,(OBJ_FLAGS)				;	Rr0		Rr22	|	-			|	-
	load		(pGflags),cGflags			;	Rr28			|	Cr22		|	-
	addq		#1,vbl_counter				;	#1		Rr26	|	Cr29		|	W(r22)
	load		(pGstack),cGstack			;	Rr31			|	Cr26		|	Wr29
	bclr		#3,cGflags					;	#3		Rr29	|	Cr30		|	Wr26
	addq		#2,cGstack					;	#2		Rr30	|	Cr29		|	Wr30
	addq		#4,pGstack					;	#4		Rr31	|	Cr30		|	Wr29
	bset		#12,cGflags					;	#12		Rr29	|	Cr31		|	Wr30
	jump		T,(cGstack)					;	T		Rr30	|	Cr29		|	Wr31
	store		cGflags,(pGflags)			;	Rr29	Rr28	|	-			|	Wr29
											;	-				|	Cr28		|	-
											;	-				|	-			|	W(r28)
In this exemple, I do those steps :
  • write to the OBF register as soon as possible to allow the OP to continue his process
  • read the GPU Flags register
  • increase the vbl counter
  • read the stack
  • clear the IMASK bit
  • correct the address of the instruction that will be executed after jumping
  • increase the stack pointer
  • clear the interrupt flag
  • jump to the new address
  • write back flags to register
Ok, this is my interrupt code. I'll have a look at your code to see what I'm doing wrong.
	.gpu
stack		.equr r31
flagsAddr	.equr r29
flags		.equr r28
rasterAddr	.equr r0
colors		.equr r1
clut		.equr r2
op			.equr r3
col			.equr r4
	.org G_RAM
	.macro EMPTY_IRQ
	.rept 8
	nop
	.endr
	.endm
; this is the entry point of the GPU code
cpu_interrupt:
;	IRQ 0
	movei #init_raster,r0		; 3
	movei #G_ENDRAM,stack		; 3
	jump t,(r0)					; 1
	moveta stack,stack			; 1
dsp_interrupt:
	EMPTY_IRQ
timer_interrupt:
	EMPTY_IRQ
op_interrupt:
	load (flagsAddr),flags			; GPU_FLAGS
	load (rasterAddr),colors
	movei #CLUT,clut
; 0, 1, 2, 3
	loadp (colors),col
	addqt #8,colors
	storep col,(clut)
	addqt #8,clut
	storew op,(op)					; restore op
	store colors,(rasterAddr)
; rte
	load (stack),r30
    addqt #4,stack
	addqt #2,r30
	jump (r30)
	.long
_raster_ptr::
	dc.l 0
init_raster:
	movei #G_FLAGS,flagsAddr
	movei #OBF,op
	movei #_raster_ptr,rasterAddr
	bset #7,flags
    moveta rasterAddr,rasterAddr
	moveta op,op
    moveta flagsAddr,flagsAddr
    subqt #4,stack
; fall to next included file (must be gpu_events.s)
if I put this  bset #14,flags instead of  bclr #14,flags it works...
I think that my jaguar init code it's wrong, I must something missing because sometimes it works, and other times it doesn't.
init_jag:
	move.w #$2700,sr                    ; disable all interrups
    move.w #$7fff,VI                    ; vbi off
	lea stack_top,sp
	lea dummy_irq,a0
	move.l a0,LEVEL0.w
	lea _BASE,a0
    move.l #$070007,d0                  ; big endian
    move.l d0,G_END-_BASE(a0)
    move.l d0,D_END
    moveq #0,d0
    move.l d0,G_CTRL-_BASE(a0)          ; stop gpu
    move.l d0,D_CTRL                    ; stop dsp
	move.l #1<<14|%11111<<9,G_FLAGS-_BASE(a0)	; disable GPU-IRQs, bank #1
;	move.l #1<<14|%11111<<9,D_FLAGS				; disable DSP-IRQs, bank #1
	move.l d0,D_FLAGS
	move.l #%11111100000000,J_INT          ; clear and disable IRQs
    move.l #list,d0
    swap d0
    move.l d0,OLP-_BASE(a0)             ; set OP to STOP-OBJECT
    moveq #0,d0
    move.w d0,R_DAC
    move.w d0,L_DAC
    move.w d0,OBF-_BASE(a0)             ; clear OP-Flag
    move.l d0,BORD1-_BASE(a0)           ; border black
    move.w d0,BG-_BASE(a0)              ; background black
    move.l d0,PIT0-_BASE(a0)            ; stop PIT
    move.l d0,JPIT1                     ; stop JPIT1
    move.l d0,JPIT3                     ; stop JPIT2
    move.w #$1F01,INT1-_BASE(a0)        ; clear pending irqs & enable vbl
; blitter init
    lea A1_BASE,a0
    lea B_CMD,a1
.cb0:
    move.l d0,(a0)+
    cmp.l a0,a1
    bne.s .cb0
    lea 4(a0),a0    ; skip B_CMD
    lea B_Z0+4,a1
.cb1:
    move.l d0,(a0)+
    cmp.l a0,a1
    bne.s .cb1
; video init
    move.w CONFIG,d0               ; Also is joystick register
    andi.w #VIDTYPE,d0             ; 0 = PAL, 1 = NTSC
    beq.s .pal
    move.w #NTSC_HMID,d2
    move.w #NTSC_WIDTH,d0
    move.w #NTSC_VMID,d6
    move.w #NTSC_HEIGHT,d4
    bra.s .calc_values
  .pal:
    move.w #PAL_HMID,d2
    move.w #PAL_WIDTH,d0
    move.w #PAL_VMID,d6
    move.w #PAL_HEIGHT,d4
  .calc_values:
    move.w d0,d1
    asr.w #1,d1                   ; Width/2
    sub.w d1,d2                   ; Mid - Width/2
    add.w #4,d2                   ; (Mid - Width/2)+4
    sub.w #1,d1                   ; Width/2 - 1
    ori.w #$400,d1                ; (Width/2 - 1)|$400
    move.w d1,HDE
    move.w d2,HDB1
    move.w d2,HDB2
    move.w d6,d5
    sub.w d4,d5
    move.w d5,VDB
    move.w #$FFFF,VDE
    move.l #0,BORD1                ; Black border
    move.w #0,BG                   ; Init line buffer to black
    move.w #PWIDTH4|CSYNC|BGEN|RGB16|VIDEN,VMODE-_BASE(a0)  ; Configure Video
	rts
dummy_irq:
    move.w #$101,INT1		; clear vbl interrupt and enable it
    move.w #0,INT2			; restore interrupts ***
    rte
Edited by swapd0
Small update, I'm using this code instead of bset & bclr to initialize the GPU and it's more stable, at least it works always the same way but it crashes when I draw the sprites with the GPU, but never if I use de 68000 with GPUOBJ.
	movei #G_FLAGS,gpuFlagsPtr
	; init gpu
	movei   #(1<<7)+(1<<14),r1			; enable OBJ, reg page 1
    store r1,(gpuFlagsPtr)
Edited by swapd0
Another small update.
I have a test program that draws several sprite with different bitmap depth, also I can scale some sprites. This is the part of the routine that check the sprite scale. if I remove this code, it it's more stable (It doesn't crash so often). So I think that with the GPUOBJ/OP Interrupts enabled, if there are some kind of pipeline stall it can break the code.
	movei #$2020,r0
	cmp r0,scale
	jr EQ,continue_build_sprite
	moveq #31,tmp			; branch op
; check alignment
	and dst,tmp				; check 32bytes alignment
	movei #align_last_sprite,r20
	jump NE,(r20)
	bset #SCALE_BIT,fields	; branch op
continue_build_sprite:
Edited by swapd0
The code is a mix of C/68000 asm/GPU ams, without the toolchain you won't be able to compile it and it's a bit big. Although I'm doing the test with a small program, not the game, the library it's big.
Tomorrow I'll try something different, run the sprite engine with the 68000 with GPUOB interrupt and execute some "random" code in the GPU.
Edited by swapd0
Ok, I got an event system running on the GPU, when I write an address into a GPU RAM location, starts to execute the functions written in that array, it's something like.
gpu_queue[0] = gpu_draw_sprite;
gpu_queue[1] = x;
gpu_queue[2] = y;
gpu_queue[3] = sprite_frame;
gpu_queue[4];
run_gpu_queue();		// something like gpu_queue_ptr = gpu_queue
If I load this code (gnu_shit_code) into the GPU and call it, it works fine without the GPUOB interrupts, but when I insert a GPUOB into the sprite list it hangs, sometimes very quickly sometimes it takes a while, I've to move the sprites with the joypad or it never hang.
If I don't tell the GPU to execute this code, it works (it's in a busy wait). So I think that my event system that I've been using in all my projects (4 in total) has some bugs. Looking at the code it could be done in a better way, more simple and without move pc, rx... , maybe this instruction is messing around.
_gpu_shit_code::
;    movei #$a0000,r0
;    load (r0),r0
.loop:
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
;rts
    moveq #4,r0			; skip 1 parameter
	load (r31),r1
	jump (r1)
	addqt #4,r31
Edited by swapd0
My even dispatcher code:
; GPU events queue
; ptr to function [data]*
; 0
; if a function has data, it must be read from r0 pointer
;    .include "jaguar/jaguar.inc"
    .globl _gpu_events_list
    .gpu
list_ptr    .equr r19
event_list  .equr r18
event       .equr r17
return      .equr r16
_gpu_events::
    movei #_gpu_events_list,list_ptr
    moveq #0,event                  ;
    store event,(list_ptr)          ; clear event list
.wait_list:
    load (list_ptr),event_list
    or event_list, event_list
    jr EQ,.wait_list
    nop
; execute events
.execute_event:
    load (event_list),event
    or event,event                  ; ptr == null, end of list, go to wait event list
    jr EQ,_gpu_events
    addqt #4,event_list             ; point to next event or data
    store event_list,(list_ptr)     ; save for next event
    move event_list,r0              ; parameters address
; jsr to routine
    movei #.l0,return
    subqt #4,r31
	jump (event)
	store return,(r31)
.l0:
; r0 will have number of words to skip
    movei #.execute_event,event
    jump (event)
    add r0,event_list               ; skip parameters
    .long
_gpu_events_list::
    dc.l 0  ; pointer to events list
My gpu interrupt code:
;	include "jaguar/jaguar.inc"
	.gpu
gpuFlagsPtr	.equr r29
flags		.equr r28
rasterAddr	.equr r1
colors		.equr r2
clut		.equr r3
opFlags		.equr r4
col			.equr r5
	.org G_RAM
	.macro EMPTY_IRQ
	.rept 8
	nop
	.endr
	.endm
cpu_interrupt:
;	IRQ 0
	jump t,(r0)					; 1
	nop							; 1
	nop							; 1
	nop							; 1
	nop							; 1
dsp_interrupt:
	EMPTY_IRQ
timer_interrupt:
	EMPTY_IRQ
op_interrupt:
	load (gpuFlagsPtr),flags			; GPU_FLAGS
	movei #CLUT,clut
; 0, 1
	load (colors),col
	addqt #8,colors
	store col,(clut)
	addqt #4,clut
	storew r0,(opFlags)				; resume OP
; rte
	load (r31),r30
	addq #2,r30
    addqt #4,r31
	jump (r30)
	store flags,(gpuFlagsPtr)			; restore interrupt
	.long
_raster_ptr::
	dc.l 0
init_raster:
	; init gpu
	movei #OBF,opFlags
	moveta opFlags,opFlags
    moveta gpuFlagsPtr,gpuFlagsPtr
Test code that does nothing.
_gpu_shit_code::
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
;rts
    moveq #0,r0			; skip 0 parameter
	load (r31),r1
	jump (r1)
	addqt #4,r31
Main code that tells the GPU to execute something.
		wait_gpu_idle();
		for ( int i = 0; i < 10; ++i )
			wait_gpu_idle();
			gpu_queue[0] = (uint32_t)&gpu_shit_code;		// fn
			gpu_queue[1] = 0;
//			gpu_queue[2] = 0;			// with this uncommented takes more time to crash the code...
			run_gpu_queue();
			wait_gpu_idle();
If I uncomment the gpu_queue[2] it takes more time to hang the jaguar, this means that r0 got some weird values so the event loop code fails? No, I'm testing the value of r0 after the execution of the event and is always 0.
Maybe I can try to port this code to a small 100% asm test code.
Edited by swapd0
Ok, I think that I've found the bug. I call the GPU code from 6800 like this way. It hangs the Jaguar even if the loop it's executed only one time, but If I remove the last wait_gpu_idle(), it looks that never crashes.
Looks like you can't hammer a gpu address from the 68000 and the GPU at the same time, isn't it?
			wait_gpu_idle();
			gpu_queue[1] = 0;
			run_gpu_queue();
			wait_gpu_idle();
_run_gpu_queue::
	move.l #_gpu_queue,_gpu_events_list
	rts
_wait_gpu_idle::
	lea _gpu_events_list,a0
.wait:
	moveq #127,d0
	divu #3,d0
	move.l (a0),d0
	bne.s .wait
	rts
	.long
_gpu_queue::
	ds.l 128
Edited by swapd0
The 68000 writes to the GPU RAM in 16-bit segments, so two writes for a longword.
The GPU reads as 32bit, and is clocked higher.
It's reading only half the address (the high half)
You should be setting a sempahore flag, and checking that, not the actual pointer value.
.wait_list:
    jr EQ,.wait_list
    nop
That is your problem.
