sparkplug.0128 Posted February 27, 2021 Share Posted February 27, 2021 When I run this code on 8bitworkshop my sip is toward the left side of the screen (which is what i want), but when i run the code on z26 emulator it's still facing toward the right of the screen. processor 6502 include "vcs.h" include "macro.h" ;variables seg.u Variables org $80 YPosFromBot = $80; VisiblePlayerLine = $81; PlayerBuffer = $82 ;setup an extra variable seg Code org $F000 ;generic start up stuff... Start: CLEAN_START ClearMem sta 20,x dex bne ClearMem lda #$00 sta COLUBK ;start with black background lda #$08 sta COLUP0 ;Setting some variables... lda #80 sta YPosFromBot ;Initial Y Position lda #$20 sta NUSIZ0 ;Quad Width ;VSYNC time MainLoop: lda #2 sta VSYNC sta WSYNC sta WSYNC sta WSYNC lda #43 sta TIM64T lda #0 sta VSYNC Movement: lda #%00010000 ;Down? bit SWCHA bne SkipMoveDown inc YPosFromBot SkipMoveDown lda #%00100000 ;Up? bit SWCHA bne SkipMoveUp dec YPosFromBot SkipMoveUp WaitForVblankEnd: lda INTIM bne WaitForVblankEnd ldy #191 sta WSYNC sta VBLANK ScanLoop: sta WSYNC lda PlayerBuffer ;buffer was set during last scanline sta GRP0 ;put it as graphics now CheckActivatePlayer CPY YPosFromBot bne SkipActivatePlayer lda #8 sta VisiblePlayerLine SkipActivatePlayer lda #0 sta PlayerBuffer ;set buffer, not GRP0 ldx VisiblePlayerLine ;check the visible player line... BEQ FinishPlayer ;skip the drawing if its zero... IsPlayerOn lda Ship-1,x ;otherwise, load the correct line from Ship sta PlayerBuffer ;put that line as player graphic for the next line dec VisiblePlayerLine ;and decrement the line count FinishPlayer dey bne ScanLoop lda #2 sta WSYNC sta VBLANK ldx #30 OverScanWait: sta WSYNC dex bne OverScanWait jmp MainLoop Ship: .byte #%00000000 .byte #%00100000 .byte #%01111000 .byte #%11111100 .byte #%01111111 .byte #%11111100 .byte #%01111000 .byte #%00100000 org $FFFC .word Start .word Start Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted February 27, 2021 Share Posted February 27, 2021 If you use the code tag (left of the eye eye con) then you you get easier-to-read code. Will look at it soon... processor 6502 include "vcs.h" include "macro.h" ;variables seg.u Variables org $80 YPosFromBot = $80; VisiblePlayerLine = $81; PlayerBuffer = $82 ;setup an extra variable seg Code org $F000 ;generic start up stuff... Start: CLEAN_START ClearMem sta 20,x dex bne ClearMem lda #$00 sta COLUBK ;start with black background lda #$08 sta COLUP0 ;Setting some variables... lda #80 sta YPosFromBot ;Initial Y Position lda #$20 sta NUSIZ0 ;Quad Width ;VSYNC time MainLoop: lda #2 sta VSYNC sta WSYNC sta WSYNC sta WSYNC lda #43 sta TIM64T lda #0 sta VSYNC Movement: lda #%00010000 ;Down? bit SWCHA bne SkipMoveDown inc YPosFromBot SkipMoveDown lda #%00100000 ;Up? bit SWCHA bne SkipMoveUp dec YPosFromBot SkipMoveUp WaitForVblankEnd: lda INTIM bne WaitForVblankEnd ldy #191 sta WSYNC sta VBLANK ScanLoop: sta WSYNC lda PlayerBuffer ;buffer was set during last scanline sta GRP0 ;put it as graphics now CheckActivatePlayer CPY YPosFromBot bne SkipActivatePlayer lda #8 sta VisiblePlayerLine SkipActivatePlayer lda #0 sta PlayerBuffer ;set buffer, not GRP0 ldx VisiblePlayerLine ;check the visible player line... BEQ FinishPlayer ;skip the drawing if its zero... IsPlayerOn lda Ship-1,x ;otherwise, load the correct line from Ship sta PlayerBuffer ;put that line as player graphic for the next line dec VisiblePlayerLine ;and decrement the line count FinishPlayer dey bne ScanLoop lda #2 sta WSYNC sta VBLANK ldx #30 OverScanWait: sta WSYNC dex bne OverScanWait jmp MainLoop Ship: .byte #%00000000 .byte #%00100000 .byte #%01111000 .byte #%11111100 .byte #%01111111 .byte #%11111100 .byte #%01111000 .byte #%00100000 org $FFFC .word Start .word Start Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted February 27, 2021 Share Posted February 27, 2021 I would be trusting Stella to give accurate emulation results over z26. Often emulators have to deal with tricky timing and don't always get it right. The ultimate test is hardware, but Stella (and Gopher2600) are pretty close! I think z26's engine is a bit older and perhaps not quite as accurate. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted February 27, 2021 Share Posted February 27, 2021 That's just way too much logic to include in a kernely. You should search the forums for "SKIPDRAW". I'll get this sort of thing up on my tiki ASAP, to help out. http://www.taswegian.com/WoodgrainWizard/tiki-index.php?page=Woodgrain-Wizadry 1 Quote Link to comment Share on other sites More sharing options...
