FastBasic 4.5 - 2021 release
Hi!
2 hours ago, Jess Ragan said:
I guess the big question is this... will this work with the Atari 5200 as well? There was a 5200 compiler, Calamari or something, but it was early and difficult to figure out.
From the README at https://github.com/dmsc/fastbasic#fastbasic---fast-basic-interpreter-for-the-atari-8-bit-computers :
The FastBasic cross-compiler supports the Atari 5200, producing cartridge images. The cross-compiler runs on Linux, Windows or OSX.
Have Fun!
  • 1 month later...
Hello, I'm back using fastbasic and have some questions about linking separate asm files.
I have 2 asm files, e.g. gen.asm and gen2.asm.
In gen2.asm is a .proc I want to call from gen.asm.
How do I do that?
I've tried following
in gen.asm:
  .import GEN2
  .export GEN
.proc GEN
  jsr GEN2::start     ; the scoped start label inside GEN2
  ;; do stuff with returned values
  rts
.endproc
With gen2.asm:
  .export GEN2
.proc GEN2
start:
  pla
  ;; ... more stuff
  rts
.endproc
The fastbasic file is simple, just doing USR to gen (test.bas):
dim d1(31) byte
x = USR(@gen, &d1, 1, 2)
? "x:"
? x
I've tried various ways to compile, but I'm getting
$ fb test.bas -X:-U gen2.asm gen.asm
BAS compile 'test.bas' to 'test.asm'
ASM assemble 'test.asm' to 'test.o'
ASM assemble 'gen2.asm' to 'gen2.o'
ASM assemble 'gen.asm' to 'gen.o'
gen.asm(10): Error: No such scope: 'GEN2'
gen.asm(10): Error: Unexpected trailing garbage characters
fastbasic: can't assemble file
I've tried it with and without the `-X:-U` parameter, and with a `-X:-DGEN2` (which errors with duplicate symbol).
What's the correct way to link the two together so procs in one asm are callable from another?
Thanks!
How do I do that?
in gen.asm:
  .import GEN2
  .export GEN
.proc GEN
  rts
.endproc
With gen2.asm:
  .export GEN2
.proc GEN2
start:
  pla
  ;; ... more stuff
  rts
.endproc
dim d1(31) byte
? "x:"
? x
Thanks!
Just guessing, but the circularity of both of them needing the other might be a problem. Have you tried putting them in the same file?
They don't need each other, gen calls gen2, but not the other way around.
I've tried them together, finding that the issue is using `jsr GEN2::start`, but in a single file just `jsr GEN2` works.
I was reading the scoping rules of ca65, and thought the ::start should work.
Got it mostly working in 1 file, but I really want to have multiple files.
Edited by fenrock
ok, after a lot of experimenting, I've got it working. The main issue was using GEN2::start as previously noted.
The second issue I had was forgetting that JSR pushed values onto the stack, which I had to deal with.
Here's a minimal functioning program using multiple asm files
test.bas
x = USR(@gen, 1, 2)
? "x:"
? x
? PEEK(x)
? PEEK(x + 1)
? PEEK(x + 2)
? PEEK(x + 3)
gen.asm
  .export GEN
  .import GEN2
.proc GEN
  ; call one proc from another
  ; it will take our current params, add 1 to each, and then return them on
  ; stack, which we then push into _p1/2, and return memory location of p1
  jsr GEN2
  ; results were pushed to the stack in GEN2
  pla
  sta _p2+1
  pla
  sta _p2
  pla
  sta _p1+1
  pla
  sta _p1
  ; return the location of the stored data in A,X for FB to use as return value
  lda #<_p1
  ldx #>_p1
  rts
_p1: .res 2
_p2: .res 2
.endproc
gen2.asm
  .export GEN2
.proc GEN2
start:
  ; save return address
  pla
  sta _ret
  pla
  sta _ret+1
  ; pull out the original parameters from the GEN call
  pla
  sta _p2+1
  pla
  sta _p2
  pla
  sta _p1+1
  pla
  sta _p1
; add one to both vars
  inc _p1
  bne no1
  inc _p1+1
no1:
  inc _p2
  bne no2
  inc _p2+1
no2:
; now save values to stack for the caller to get out (i.e. GEN)
  lda _p1
  pha
  lda _p1+1
  pha
  lda _p2
  pha
  lda _p2+1
  pha
  ; push the return address back into stack as we did JSR to here
  lda _ret+1
  pha
  lda _ret
  pha
  rts
; temporary data
_p1: .res 2
_p2: .res 2
_ret: .res 2
.endproc
Compile:
fb test.bas gen2.asm gen.asm
Output:
x:
8594
We can see the original args of "1, 2" have been incremented to 2, 3
Some useful other stuff while debugging in ALTIRRA:
$ grep GEN test.lbl
al 0022E2 .GEN
al 00228F .GEN2
# Now add breakpoints in Altirra before running test.xex in SDX:
bp 22e2
bp 228f
Edited by fenrock
fixed asm comments
Hi!
This is not about FastBasic, more about 6502 assembly 🙂 ... yes, accessing results from depth in the stack is not that easy. But, there is an alternative to pop and push, use TSX to transfer the stack pointer to the X register and access from there:
	.export GEN2
.proc GEN2
start:
  ; Get stack pointer int X:
  tsx
  ; Read original parameter 2:
  lda $103,x
  sta _p2+1
  lda $104,x
  sta _p2
  ; Increment
  inc _p2
  bne no1
  inc _p2+1
no1:
  ; Store parameter 2:
  lda _p2+1
  sta $103,x
  lda _p2
  sta $104,x
  ; Or do the same in place for parameter 1
  inc $105,x
  bne no2
  inc $106,x
no2:
  ; Return
  rts
  ; temporary data
_p2: .res 2
.endproc
About the ".export" and ".proc", those are specific to CA65 assembler. In your first example, you were trying to access "GEN2::start" from outside, but that does not work because ".export" only exports the given symbol, all other local symbols are hidden from the file.
Have Fun!
Thanks @dmsc
My own noob-ishness at not thinking of tsx etc. I haven't done any real 6502 assembly in years.
I've got a further question for you.
I've just pushed a repo that adds command line args reading for FastBasic applications here: https://github.com/markjfisher/fb-args
So you can call your applications and pass args to it on the command line in spartados for example.
There's examples in the repo. It's all working as I expected except for one thing.
In my example program here: https://github.com/markjfisher/fb-args/blob/master/example/main.bas
On line 23, I have to initialise any variable name, otherwise the loop below that code fails to run correctly.
I think it's probably something to do with the asm file I include doing something funny, but can't track it down.
Building and running the main.bas file, I get the following output example:
Which looks great. Command line parsing from FastBasic 🎉
However, if I remove the line:
foo$ = ""
which has nothing to do with the rest of the application, then when I run it I get this instead:
Can you help me work out what's wrong with the application?
There's only 2 files involved:
  1. https://github.com/markjfisher/fb-args/blob/master/example/getargs-sdx.asm
  2. https://github.com/markjfisher/fb-args/blob/master/example/main.bas
so not difficult to test and reproduce I hope, assuming you have a SDX environment.
Thanks!
Edited by fenrock
Hi!
Thanks for your FastBasic examples!
9 hours ago, fenrock said:
Thanks @dmsc
The problem is in your assembly, at line 18: https://github.com/markjfisher/fb-args/blob/master/example/getargs-sdx.asm#L18
  .zeropage
ptr1: .res 1
Here, you reserved 1 byte of zeropage to store your "ptr1" variable.... but then, at line 46:
sparta:
    lda     DOSVEC
    clc
    adc     #<LBUF
    sta     ptr1
    lda     DOSVEC+1
    adc     #>LBUF
    sta     ptr1+1
You are writing to "ptr1+1", so you used two bytes. This overwrites one FastBasic pointer, messing up the code later.
The fix is simply to reserve 2 bytes for ptr1.
Have Fun!
  • 5 months later...
This is brilliant - thank you for doing this.  It solves a lot of issues I was going to have with creating and reading "drop files" to manage this exact thing.
I starred your repo.
