Nes display. Full screen?
Hello
the other day i was testing my rgb modded nes on an ikegami crt monitor.
my question is about the display. My display does not fill the entire screen. The video looks great its just that a little of the left side isnt used. And even more of the right part of the screen isnt used?
i think i read atari’s have different displays on different tv’s
im wondering if the nintendo is similair?
i put in mario bros/duck hunt. The startup select screen is good. But when i go to play the game the video doesent take up the whole screen
and the right side has more area cut off
is there away to have my nes take up the whole screen?
It depends mostly on the geometry settings of your TV.  NES and other console games back in the day often appeared to take up the entire screen because consumer TVs were often set with a lot of overscan (that is, the picture was zoomed in so that several lines of pixels were "off screen").  The NES in particular has an actual internal resolution of 256x240, though most if not all games run at an actual resolution of 256x224 with the top and bottom 8 lines either blank (black) or full of visual garbage, depending on the game.
Nintendo documents from the time apparently initially indicated that developers should keep all important information within 224x192, but this was ignored or relaxed as time went on and consumer TVs had less and less expected overscan.
This would be more noticeable on modern TVs (or even professional grade TVs/monitors) as they are often set for little or no overscan.
Edited by newtmonkey
