Greg Zumwalt Posted August 17, 2003 Share Posted August 17, 2003 Can't wait. Yes, I too never thought to see the day a 2600 cart would exceed such values... Have you looked at the work and tools I use for generating the CRC database? Granted, they are DOS and batch scripts, still, I think it would help... PS, Check your private messages. Quote Link to comment Share on other sites More sharing options...
Greg Zumwalt Posted August 17, 2003 Share Posted August 17, 2003 The emulator laucher is supposed to savve and launch the current ROM. It works perfectly on my system, with long filenames and without. hmmm, perhaps something as simple as adding quotes to the %path% data as well, as that minor changed resolved launching the emulator? Or, have you already done that... Quote Link to comment Share on other sites More sharing options...
Greg Zumwalt Posted August 17, 2003 Share Posted August 17, 2003 If you really wanted to get sick you might try to intigrate the code used by DiStella into the program... at the very least, make it a tool option for ROMs of appropriate size, that will dump the code, and display it along side the appropriate line. This would help in two areas... ruling out actual code from graphics data, and make clearer the code that controls colour. Just an idea. BTW Being new to the scene, if you don't know, DiStella is the program used to diassemble 2600 BINs, but it has a size limit upon hitting bank switching. While it can be used for larger roms, the process is not an easy one. Quote Link to comment Share on other sites More sharing options...
Dan Iacovelli Posted August 17, 2003 Share Posted August 17, 2003 that sounds good greg about having distella also decode the program with hom2 because it can also help with graphics ,color and also sound . Dan Iacovelli Quote Link to comment Share on other sites More sharing options...
misterx Posted August 18, 2003 Share Posted August 18, 2003 Well, i have thought of writing a new version of DiStella too... I'll get the original version, see how it works and see what i can do I could also make it work with HOM2, if you want so. The only real problem will be skipping images and stuff when disassmbling because it woulf mess up my opcode parameter length stuff (sorry can't explain it any better ) ps. if i'll make a new version of DiStella it's nopt gonna be called DiStella ][ Quote Link to comment Share on other sites More sharing options...
Dan Iacovelli Posted August 18, 2003 Share Posted August 18, 2003 Well, i have thought of writing a new version of DiStella too... I'll get the original version, see how it works and see what i can do I could also make it work with HOM2, if you want so. The only real problem will be skipping images and stuff when disassmbling because it woulf mess up my opcode parameter length stuff (sorry can't explain it any better ) ps. if i'll make a new version of DiStella it's nopt gonna be called DiStella ][ actually distella has been updated already D i S t e l l a v 3.00 Created By Dan Boris and Bob Colbert 7800 Update by: John K. Harvey Thanks to: Alex Hornby, Vesa-Matti Puro, Jarkko Sonninen, Jouko Valta ---------------------------------------------------------------------------- Quick Docs: Type DiStella at the command prompt. Differences from version 2.10: Bugs fixed (note that version 3.0 was tested on over 400 unique files): - Changed VDEL01 equate to VDELP0 in vcs.h - Fixed indirect absolute indexing output to include proper spacing. Old method: JMP($2105) // Won't compile with DASM! New method: JMP $2105 // Will compile with DASM! Granted, this problem was generally invisible on the 2600, since without external hardware, there was no RAM higher than the zero page. Although, note that the Bachelor Party ROM exhibits this problem (using distella -pafs, and no config file): STA AUDV0 ;3 JMP (L3FFE) ;5 This problem shows up in the following ROMs: a) Bachelor Party b) Mines of Minos c) Reactor - Fixed absolute,Y and ,Y indexing case for I/0 equates: STA SWCHA,X or LDA SWCHA,X or STA SWCHA,Y or LDA SWCHA,Y for any equated value numbers between 0x0280-0x0297 (so, not just limited to SWCHA). These would incorrectly disassemble, and drop the ,X or ,Y indexing. The Indy 500 ROM is the only known ROM that exhibits this problem (using distella -pafs, and no config file): LF006: STA VSYNC,X ;4 // fixed STA SWCHA,X ;5 // no ",X" in distella 2.10. INX ;2 - Fixed indirect absolute addressing for I/O equates. Though in practice, you never want to do this: JMP (SWCHA) for any equated value numbers between 0x0280-0x0297, the disassembly of this instruction returned values not contained in the equates index table. So, this has been fixed. Granted, this situation will most likely never appear in any 2600 programs, but this case is now fixed to not dump random characters of garbage into the output file, and will successfully return the equated String. No known ROMs exhibited this phenomenon. - Fixed a spacing issue that is a problem when the '-s' option is enabled. In any given line, the whitespace after an instruction is added, to make any given line in the file exactly 15 characters in length. This makes the cycles appear lined-up in a column. What was done was printing 15 minus the number of characters used in the current line worth of spaces, to line things up. But, some games had lines greater than 15 characters per line, which caused "-1" spaces to be printed out. Since this doesn't make sense from a computer standpoint, it would interpret that value as a very large positive number, and print a lot of spaces in a row to make up for it. The condition has been corrected. Example: ACTIONMN.BIN BRK ;7 .byte $80 ;.NOOP;2 // fixed output. Previous output // had many lines of spaces between the NOOP // and the ;2. - Simply recompiling the source code for Distella 2.0 got rid of a few problems. a) Air Raiders, Bogey Blaster, Mines of Minos, and Star Wars: Jedi Arena did not show the full amount of used TIA equates. b) Riddle of the Sphinx and Shootin' Gallery incorrectly display the "INTERRUPT:" start address, even though the interrupt flag is not set. - For some ROM files, if the code is doing something unconventional (like a BRK that never has a corresponding RTI (i.e. because of manual stack manipulation), then it's possible to accidentally start disassembling segments that contain data or graphics instead of code (this is covered in more detail at the end of this file, in the "Limitations" section). In these situations, it's possible that a range of addresses that reaches to the end of a file could be marked for disassembly. In these cases, the bug was that this range of addresses would not be disassembled appropriately. At most, the first and last instruction in the segment would be disassembled, missing all of the code in-between. So, a fix is in place to handle this. ROM files affected by this are: a) Alien's Return b) Bachelorette Party c) Col 'N' (HomeVision) b) Diagnostic cartridge, serial # MA017600 e) Homerun f) Knight on the Town g) Lady in Wading h) Lost Luggage Also, as a subset of this problem, the last byte (or 2) of the code in these situations will be disassembled as code. Normally this is ok, but if these particular bytes are translated to multi-byte instructions ( like a "BMI", for example), there is a problem. In these instances, a second byte (and possibly a third) byte is created to complete the multi-byte instruction. For now, this byte (or bytes) is believed to be made up from a random number. This unfortunately causes any recompiles to make the end file size become a byte or two greater than it was when it was disassembled. It also can cause distella to think that another piece of code is referenced, and it could even try to disassemble code at that address (i.e. in a graphics data area)! This problem has the potential to affect games where the second-last byte is translated to a 3-byte instruction, or where the last byte is translated to a 2- or 3-byte instruction. Known ROMs affected: a) Bachelorette Party b) Homerun c) Knight on the Town d) Lady in Wading e) Lost Luggage Changes for Atari 7800 support: - added command line flag -7 for Atari 7800 support (please read more information under "options" below) - Added command line flag -k for POKEY sound equates (7800 mode only, please read more under "options" below) - Added command line flag -b, and changed the definition of the -i flag (for more information, please read the "options" section below) - Optimized memory allocation to be dynamic instead of static for mem[] and labels[] arrays What is it? Distella is a disassembler specifically for the Atari 2600. Since its creation, it has been modified to disassemble Atari 7800 code as well. It creates source code that is usually recompilable without any human intervention. It examines the code and performs some basic tracing routines which allow it to accurately distinguish data from code. Features: o Written in portable ANSI C - source code is included. o Very fast o Distinguishes data from code o Uses labels for Atari 2600/7800 register locations o Allows user to override or disable auto data determination o Optionally includes 6502 cycle times as comments o Freeware - Use it, Love it, Live it! Command format: Distella [options] romimage [> sourcefile] Distella puts the sourcecode generated to standard output, so to put it in a file, use the '>' redirection. Unlike Distella 1.0, the .bin suffix is not assumed, and you must use the -c flag to tell DiStella the name of a config file if you choose to use one. Options: -7 -> Allows for MARIA equates and MARIA I/O equates tables to be loaded instead of the Atari 2600 VCS Equates and 2600 VCS I/O tables. Also, with this option, supported 7800 file sizes can be 16K, 32K, and 48K (or 128 bytes greater for each size, if a correct 7800 header is appended at the front, which are a78 formatted files). Files larger than 48K are currently not supported, since they use bankswitching techniques (just like distella will not support Atari 2600 8K disassembly, since these files are bankswitched). To disassemble files larger than 48K, you will have to disassemble each bank (whether they be 16K or 32K) separately. This is nontrivial, but instructions to do this can probably be found on the world wide web. -a -> Disables the printing of the letter 'A' for opcodes in which the A register is implied. Some assemblers don't like the 'A' and others require it. Example: LSL A would be just LSL -b -> DiStella will read the address indicated in the last 2 bytes of the ROM file - the BRK vector - and trace through it to help determine data areas. Not all programs use the BRK vector. The best thing to do is try disassembling the image without this flag and see if the last two bytes point to an area that is not disassembled. If that is the case, try the flag and see if the interrupt routine contains valid code. It should be noted that a majority of games do not use the interrupt. This is true for both Atari 2600 games and Atari 7800 games. -c -> Defines a config file to use for disassembly. The name of the file must follow the c immediately without any spaces. See the section called "Config File" for more details about the config file. -d -> Disables automatic code determination. When this flag is used, DiStella is "dumb" and thinks everything is code unless told specifically otherwise in the config file. -i -> DiStella will read the address indicated in the last 6th-last and 5th-last bytes of the ROM file - the interrupt vector - and trace through it to help determine data areas. This is only a valid option if the `-7' flag is set, since this vector is only used in Atari 7800 mode. Usually, access to this vector is triggered by a Display list interrupt set in the 7800 DLL. Note that not all programs use the interrupt vector. The best thing to do is try disassembling the image without this flag and see if the 6th-last and 5th-last bytes point to an area that is not disassembled. If that is the case, try the flag and see if the interrupt routine contains valid code. For 7800 games, most games use the interrupt vector. -k -> Enables support of the POKEY equates. There are only 2 actual released games that use these equates, which are Ballblazer and Commando. For the rest of the games, this flag is probably not very beneficial, as it could translate any bankswitching access as POKEY equates (i.e. stores/loads in the 0x4000-0x400F range would be identified as POKEY equates, when in reality, they may contain bankswitching logic). Also, note that if using an a78 file, this is overriden by header byte 54 (zero-based)'s least significant bit value. -o# -> ORG mnemonic variation. o1 -> ORG $XXXX o2 -> *=$XXXX o3 -> .OR $XXXX -r -> Relocate calls out of normal address range. Only the lowest 13 bits in an address are significant in the 2600, so $1000 is equivalent to $f000. Unfortunately, some ROM images use these addresses interchangeably. If this flag is NOT used, a section of code may look like this: LF000 lda $D004 ; this actually refers to LF004 rts LF004 .byte $3c If this flag IS used, the same code would look like this: LF000 lda LF004 ; ahh! This is a little clearer rts LF004 .byte $3c It is important to note that if the -r flag is used, the code will recompile fine, but the ROM image will be altered. If you want your source to recompile into an exact copy of the original ROM image, do not use this flag! -s -> Includes the cycle count for each instruction. It only includes the basic cycle count, and does not adjust for page boundries (YET). Config File The config file is a very simple text file that defines various parameters for disassembly. Each line in the config file defines either a range of addresses or the ORG. The addresses should be 4 digit hex numbers and there should be only 1 space between the command and each address. The valid config commands are as follows: ORG XXXX Defines where the ROM image should be disassembled to. Distella automatically determines the origin of the ROM image. It takes into consideration the start address (the address specified in lo/hi byte format starting from the 4th byte from the end of the ROM image), and the length of the image. The ORG command will override DiStella's automatic determination. Be careful, if you are wrong, you won't get much in the way of code on your output! CODE XXXX XXXX Defines an address range as being code. Distella is not perfect, and can mistake code for data. The most common way that this happens is when Absolute Indirect addressing is used. See the Limitations section for more information. The CODE command overrides DiStella's automatic DATA determination, but is overridden by all other config commands, so if there are any conflicts with DATA or ORG commands, the range in question will not be handled as code. GFX XXXX XXXX Defines an address range as being graphics. This causes each byte to be displayed visually in a comment, along with the address of each byte to the right of the graphic display. Here is an example from Pacman: .byte $38 ; | XXX | $FDB5 .byte $7C ; | XXXXX | $FDB6 .byte $FE ; |XXXXXXX | $FDB7 .byte $E0 ; |XXX | $FDB8 .byte $FE ; |XXXXXXX | $FDB9 .byte $6C ; | XX XX | $FDBA .byte $38 ; | XXX | $FDBB .byte $7E ; | XXXXXX | $FDBC .byte $E0 ; |XXX | $FDBD .byte $C0 ; |XX | $FDBE .byte $E0 ; |XXX | $FDBF .byte $6C ; | XX XX | $FDC0 .byte $38 ; | XXX | $FDC1 Note that the graphics are upside down, this is common in games because of the way the code is written. The GFX command overrides the DATA command. DATA XXXX XXXX Defines an address range as being data. Up to 16 bytes will be put on each line. If an address is reached that is referenced somewhere else in the code, a new line will be created with its own .byte mnemonic. Here is an example from Pacman: LFF06: .byte $20,$40,$80,$60,$01,$05 LFF0C: .byte $00 LFF0D: .byte $00,$00,$01,$00,$00,$01,$06,$05,$04,$03,$02,$01 LFF19: .byte $00,$02 Limitations: DiStella does a good job at determining the difference between code and data. There are a couple of instances that may cause DiStella to confuse code for data and visa-versa. Absolute-Indirect Addressing: DiStella traces the code in the ROM image starting at the reset vector. Each time it sees a relative branch, it puts the branch address in a queue only if that address hasn't been traced already. It continues on until it reaches an RTS, RTI, or JMP. It then gets an address from the queue and traces it repeating the process until no more addresses are in the queue. Unfortunately, an absolute-indirect JMP - jmp ($ZP) - doesn't provide enough information for DiStella. It is possible that an entire section of the ROM image will be determined to be DATA when it is really CODE. The best thing to do is to look at the code that loads $ZP and $ZP+1 with the address to jump to (usually there is a list of address like .byte $00,$f0,$20,$f0,$30,$f0) and use the CODE command in a config file to force that area to be disassembled. Relative "Unconditional" Branches: Well, as you may or may not know, the 6502 processor does not have a relative unconditional branch. Programmers can cheat and use a relative branch as an absolute branch when they know the status of one of the status register bits. For example, if this code is executed: LDA #$01 BNE LF034 LF030 .byte $10,$20,$30,$40 LF034 RTS LF030 will never be reached because 1 is never equal to zero! DiStella isn't that smart! If you get a large section of code that is unreadable, look for a relative branch directly before the unreadable section. Chances are that the data starts directly after that relative branch. You would need to use the DATA command in a config file to fix this problem. RTS Ending An Interrupt Routing: Usually a BRK initiates an interrupt and the code pointed to by the interrupt vector is executed. The proper way of exiting an interrupt is to execute an RTI. A problem occurs when an RTS is executed instead. This is because an RTS pulls the return address off of the stack and then adds 1 to it, where an RTI does not. What does this mean to you? Well, look at the following code: LF000 LDA #$01 BRK .byte $03 ;.SLO LF004 TAX This is an example of what the code might look like if an RTS is used in the interrupt routine instead of RTI. If an RTI was used, the code would look like this: LF000 LDA #$01 BRK LF003 TAX The extra byte in the first code segment could cause DiStella to get off sync, which has numerous side effects. Here it didn't, but keep in mind that it is possible. That's it! Have fun, and report all bugs and errors to: Bob Colbert - rcolbert@novia.net http://www.atari2600collector.com Dan Boris - dboris@comcast.net http://www.atarihq.com/danb For version 3.0 and Atari 7800-related errors, contact: John K. Harvey - jkharvey@voyager.net http://www.cs.wisc.edu/~harvey/7800 so if your going to upadte it more, you should contact the people mentioned above. Dan Iacovelli Quote Link to comment Share on other sites More sharing options...
misterx Posted August 18, 2003 Share Posted August 18, 2003 Heh, ok... So i will not write DiStella ][. Actually i think that a project like that would've been a little too big for my current 2600 knowledge I would've had to rummage through all kinds of articles and tuts to make it... But hey! That's what i call fun Back to HOM2....... Quote Link to comment Share on other sites More sharing options...
Greg Zumwalt Posted August 18, 2003 Share Posted August 18, 2003 Posted Aug 17, 2003 2:10 am Anyways, i'll post the next version in a min. Or two. AAACCCCKKKKK!!!! 2,135 minutes and counting... need fix soon uuughhhh. On a more serious note, yes, reinventing the wheel is not fun or needed in this case. Simply implimenting DiStella as a modular tool (simular to the emulator feature) and having the dumped output displayed side by side with the rest of the HOM2 display would be great. Or, perhaps a method by where the entire code is displayed, but upon clicking a graphic block or entering the BIN/HEX value box, the list would jump to the appropriate source point... Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 18, 2003 Author Share Posted August 18, 2003 Wow! HOM2 is going to be one of the best programs out there since it keeps improving so fast. Within a year, it will be able to mow our lawns, wash and dry and fold our clothes, and cook supper. Thanks for the constant improvement misterx. HOM2 is giving me a chance to do things I thought I'd never be able to do. Flip sure is a useful feature, thanks again for adding it. Quote Link to comment Share on other sites More sharing options...
Brad2600 Posted August 18, 2003 Share Posted August 18, 2003 I might play around with HOM2 a little bit later on. I want to tweak my hack of E.T specifically. Quote Link to comment Share on other sites More sharing options...
misterx Posted August 19, 2003 Share Posted August 19, 2003 Posted Aug 17, 2003 2:10 am Anyways, i'll post the next version in a min. Or two. AAACCCCKKKKK!!!! 2,135 minutes and counting... need fix soon uuughhhh. When i say a few minutes it means "when i have time" Quote Link to comment Share on other sites More sharing options...
StanJr Posted August 28, 2003 Share Posted August 28, 2003 Ok, so I've read this thread and with all the updates and talking and this and that, I'm left a bit confused. What EXACTLY do I need to hack a game? Is all I need HOM2? Or are there other programs that I will need as well? Quote Link to comment Share on other sites More sharing options...
Big Player Posted August 28, 2003 Share Posted August 28, 2003 The only other programs you need Stan are some ROM files and an emulator to test out your work. Quote Link to comment Share on other sites More sharing options...
StanJr Posted August 28, 2003 Share Posted August 28, 2003 Thanks, BP! I'm off to hack and hack and hack! This hacking crap is hard. When the grid is only so wide and the images that you want to hack are wider, its like totally impossible to figure out how they match up or what you are hacking around with. For instance, I want to hack Boxing, but who the hell can tell what images are the boxers or how to modify them! Is there anything I can do to make this easier? Or am I too big a moron for hack-o-matic and I should just leave it to smarter folks? Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted September 20, 2003 Share Posted September 20, 2003 Anyone know if there is a mac version of HOM2?? If so, is there a site available?? Cheers Quote Link to comment Share on other sites More sharing options...
misterx Posted September 20, 2003 Share Posted September 20, 2003 At least i haven't made a Mac version of it and doubt that i ever will because i don't have any experience on Mac programming. Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted September 21, 2003 Share Posted September 21, 2003 I downloaded a script off this site ...http://prdownloads.sourceforge.net/tcl/ for the first version of HOM. Just wondering if any other mac user out there was able to come accross an updated version of it! Quote Link to comment Share on other sites More sharing options...
raindog Posted September 27, 2003 Share Posted September 27, 2003 Someone at the mini.net tcl wiki (sounds kinda dirty...) posted their own version of HOM that (while it doesn't have HOM2's features) is a lot faster than mine. So if you can find that, I'd recommend that for non-x86 users. I'll be using HOM2 under Wine myself, if I ever need a bitwise editor again... Quote Link to comment Share on other sites More sharing options...
gambler172 Posted January 9, 2005 Share Posted January 9, 2005 Hello i tried to hack any games with AHD.It works very well.But there are only a few ahd files included.How can i change a bin file in ahd?Or how or where can i get ahd files? greetings Gambler 172 Quote Link to comment Share on other sites More sharing options...
