Odyssey 2 with jumbled garbage on screen
4300
I just purchased this odyssey 2 with one game.  After giving it a once over I hooked it up and get this on the screen. 20210416_160604.thumb.jpg.db23fac0afdc1a5918a74333af7d06a4.jpg
What I've done so far:
- thoroughly cleaned the cartridge port and the game contacts
- removed, cleaned and re-seated the socketed chips and sockets
- looked over the board for cold solder joints,  none that I can see
- tested the PS. It's outputting 12.6v
Interestingly,  I get this onscreen with our without a cartridge inserted.
Any ideas on what to look at next?
40 minutes ago, atari2600land said:
If you get that on screen with a cartridge, perhaps it's not recognizing there's a cartridge. that screen is normal for not having a cartridge in it.
Well that's good to know.  Maybe it just doesn't like this cart. I did slightly bend the pins outward to make sure they are making contact,  with no change. I also noticed the garbage on screen will occasionally change when I turn the console off and on, shown below, or I will get a black screen.
  • 3 months later...
Hi. Do you found the problem. Yesterday I faced same problem in my guaranteed worked early O2. I checked cartridge in the my second O2 and it works fine. I powered first O2 from LAB power source but forgot to increase current. (Used it for charging battery and set limit to 0.35A). It power down voltage from 9v to 5.5. I swithed off the console, increased current limit and switch on again. Console shown garbage on the screen. With cart and without. Does low voltage can damage console?
No,  I never did get around to working on this, unfortunately.
