enito Posted April 18, 2021 Share Posted April 18, 2021 Hi [emoji112] Im searching for repair this part of this 65xe pal , C38. I not sure but one reference manual say cap .01uf ceramic axial but not sure . Can help me with search of some replacement please , thx Enviado desde mi MI 8 mediante Tapatalk Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 18, 2021 Share Posted April 18, 2021 It is a .01uF ceramic axial capacitor across the power lines to the RAM chip Quote Link to comment Share on other sites More sharing options...
enito Posted April 18, 2021 Author Share Posted April 18, 2021 Thx for reply can you guide with someone? I try to search but not easy or some crossover replacement , regards Enviado desde mi MI 8 mediante Tapatalk Quote Link to comment Share on other sites More sharing options...
+Spancho Posted April 18, 2021 Share Posted April 18, 2021 https://www.mouser.com/Vishay/Passive-Components/Capacitors/Ceramic-Capacitors/MLCCs-Multilayer-Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-Leaded/_/N-bkrdjZ1yzvvqx?P=1z0wqusZ1z0z819Z1z0zls5 1 Quote Link to comment Share on other sites More sharing options...
enito Posted April 18, 2021 Author Share Posted April 18, 2021 https://www.mouser.com/Vishay/Passive-Components/Capacitors/Ceramic-Capacitors/MLCCs-Multilayer-Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-Leaded/_/N-bkrdjZ1yzvvqx?P=1z0wqusZ1z0z819Z1z0zls5 Thx a lot Enviado desde mi MI 8 mediante Tapatalk Quote Link to comment Share on other sites More sharing options...
enito Posted April 18, 2021 Author Share Posted April 18, 2021 This one can work too ?US $1.37 8%de DESCUENTO | 10 Uds KEMET C420 0,1 uF 50V 50V0.1uF 10% X7R axial condensador cerámica multicapa 100nf 50V100nF 104 50V104https://a.aliexpress.com/_m0qSw6fEnviado desde mi MI 8 mediante Tapatalk Quote Link to comment Share on other sites More sharing options...
HyperDriver Posted April 18, 2021 Share Posted April 18, 2021 (edited) Those decoupling capacitors are 0.1uF (100nF), not 0.01uF. u1 is the same shorthand as 0u1 which represents 0.1uF. If you look at the hardware manual for the 65XE the board photo shows those caps marked as 104 which is shorthand for 10 followed by 4 zeroes (in picofarads) = 100000pf = 100nF. Looks like your board has glass caps fitted. Can you see if any of those caps above the memory chips have 104 on them? Edited April 18, 2021 by HyperDriver Quote Link to comment Share on other sites More sharing options...
enito Posted April 18, 2021 Author Share Posted April 18, 2021 Hi thx again for your time I have some another photo , later I can inspect more but don't see real clear info . This one can be correct US $2.20 | 100 UDS no polares axial monolítico condensador 1nF 100nF 0,1 UF 50V 104P 102K / 104Khttps://a.aliexpress.com/_mKK5ucb Regards , Enviado desde mi MI 8 mediante Tapatalk Quote Link to comment Share on other sites More sharing options...
HyperDriver Posted April 18, 2021 Share Posted April 18, 2021 @enito Any of the caps linked to by you & Spancho will be OK. (Although make sure you pick the 104k type in your last link). Also, of course, make sure that the body of the cap fits the space of the existing solder pads. 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 18, 2021 Share Posted April 18, 2021 1 hour ago, HyperDriver said: Those decoupling capacitors are 0.1uF (100nF), not 0.01uF. My bad, mis-type they are 0.1 uF Quote Link to comment Share on other sites More sharing options...
enito Posted April 18, 2021 Author Share Posted April 18, 2021 Excelente thx a lot for the advice again , take care Enviado desde mi MI 8 mediante Tapatalk Quote Link to comment Share on other sites More sharing options...
