DaveM Posted April 27, 2021 Share Posted April 27, 2021 Is anyone able to help test out a new homebrew on actual PAL60 hardware? Just need to know if the colors are similar to the NTSC version, and the game's speed is good as well. I've tested it on Stella, and it looks ok there, but would like to get an actual hardware test before we start making cartridges. Thanks! If you haven't some across this game in the Programming forum before, I've attached both the PAL60 and NTSC ROMs below, as well as the text draft of the game manual. The original development thread can be found here: Mr_Yo-Yo_PAL60_FINAL_DIGITAL.bin Mr_Yo-Yo_NTSC_FINAL_DIGITAL.bin Mr Yo-Yo Game Manual_TEXT_DRAFT.docx 2 Quote Link to comment Share on other sites More sharing options...
Voxel Posted April 27, 2021 Share Posted April 27, 2021 I'm in the UK, will be happy to test it. 1 Quote Link to comment Share on other sites More sharing options...
DaveM Posted April 27, 2021 Author Share Posted April 27, 2021 34 minutes ago, Voxel said: I'm in the UK, will be happy to test it. Thank you! 1 Quote Link to comment Share on other sites More sharing options...
Dionoid Posted April 28, 2021 Share Posted April 28, 2021 (edited) Hi, this is a fun game! Reminds me of Fishing Derby ? I noticed that pushing RESET brings you back to the menu screen, which isn't standard behavior for Atari 2600 games. Usually, the SELECT button is used to go back to the menu/select screen, and the RESET button is used to (re)start the game. Just check some classic games like Pac Man, Asteroids, Berzerk or Space Invaders, and you'll see that they use SELECT to let you select the game options. This also goes for homebrew games like Draconian, Galagon, Fall Down, Assembloids, etc. Edited April 28, 2021 by Dionoid 1 Quote Link to comment Share on other sites More sharing options...
Voxel Posted April 28, 2021 Share Posted April 28, 2021 Here is a comparison of the NTSC and the PAL ROM on a PAL 2600 Jr (long rainbow) on a CRT. Could test on an LCD TV if required. 1 Quote Link to comment Share on other sites More sharing options...
DaveM Posted April 28, 2021 Author Share Posted April 28, 2021 11 hours ago, Dionoid said: I noticed that pushing RESET brings you back to the menu screen, which isn't standard behavior for Atari 2600 games. Usually, the SELECT button is used to go back to the menu/select screen, and the RESET button is used to (re)start the game. Thanks. I'll make a note of that for future games. The way the code is currently structured, this would be too difficult a change to make at this point. 4 hours ago, Voxel said: Here is a comparison of the NTSC and the PAL ROM on a PAL 2600 Jr (long rainbow) on a CRT. The PAL colors are looking good! The NTSC colors are messed up, but I'm assuming that's expected from playing an NTSC format game on a PAL tv. 4 hours ago, Voxel said: Could test on an LCD TV if required. If you could, just to make sure they're the same colors you're seeing on the CRT. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
Voxel Posted April 29, 2021 Share Posted April 29, 2021 16 hours ago, DaveM said: The NTSC colors are messed up, but I'm assuming that's expected from playing an NTSC format game on a PAL tv. Agreed. 16 hours ago, DaveM said: 21 hours ago, Voxel said: Could test on an LCD TV if required. If you could, just to make sure they're the same colors you're seeing on the CRT. Thanks! Will do. Quote Link to comment Share on other sites More sharing options...
Voxel Posted May 2, 2021 Share Posted May 2, 2021 PAL CRT and LCD comparison below. 1 Quote Link to comment Share on other sites More sharing options...
Voxel Posted May 2, 2021 Share Posted May 2, 2021 Forgot to add the colours are the same. In the bottom right image for the LCD the colours were cycling as I pressed pause, where as in the CRT images I did not pause the game. The game speeds appear similar between the CRT and NTSC. 1 Quote Link to comment Share on other sites More sharing options...
Bomberman94 Posted May 2, 2021 Share Posted May 2, 2021 Here are some pictures taken from my TV (B&O MX4000) and unmodified Atari 6 switch with your latest Pal60 bin-file: 1 1 Quote Link to comment Share on other sites More sharing options...
DaveM Posted May 2, 2021 Author Share Posted May 2, 2021 Fantastic! Looks like we're good! We'll go ahead then, and hopefully we'll have a cartridge ready for purchase in the AA Store sometime in the fall! 3 Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted May 11, 2021 Share Posted May 11, 2021 I did some test on PAL 7800, colors, gameplay all are good 1 Quote Link to comment Share on other sites More sharing options...
DaveM Posted May 11, 2021 Author Share Posted May 11, 2021 7 hours ago, lucifershalo said: I did some test on PAL 7800, colors, gameplay all are good Great! Thanks! Quote Link to comment Share on other sites More sharing options...
