method72 Posted June 14, 2021 Share Posted June 14, 2021 I know I can use REFP0 to flip my player facing left/right But what about facing up and down? Think of it like the sword in adventure sure ----> and <---- are easy enough to flip left and right.. But what about making the sword face Up or Down? I am working, and not in front of my development PC at the moment, so can't test this.. but have a curious theory and figured i would ask, before I have a chance to experiment later this evening. Could I create 4 labels, then check the direction of the joystick for player0, and based on the direction being pressed, gosub to that label to set the current player0 graphic, and f the joystick direction changes, then gosub to the applicable label to set the new graphic to represent the image for the new position of the player? Perhaps only 3 graphics are needed since the left/right can use the same one, and apply reflection I assume I can also add an additional check, for no input, and just pick whatever one I choose as default, to make sure there is always a valid graphic. I am just not sure if bB allows you to re-define p0... honestly never tried, as so far all my programs used a static player sprite... but am looking to expand that behavior now, as well as add player animations as a next step. Quote Link to comment https://forums.atariage.com/topic/321865-4-direction-player-sprites/ Share on other sites More sharing options...
+Random Terrain Posted June 14, 2021 Share Posted June 14, 2021 I made a quick example program using the sprite from Seaweed Assault that has animations for 8 directions. Here's the .bas file so you can look at the code: mini_ex_8_way_animation_2021y_06m_14d_1359t.bas Here's the .bin file to use with your favorite emulator: mini_ex_8_way_animation_2021y_06m_14d_1359t.bin It uses SWCHA instead of the usual way since that's easier when dealing with an animated sprite that moves in 8 directions. 4 Quote Link to comment https://forums.atariage.com/topic/321865-4-direction-player-sprites/#findComment-4843795 Share on other sites More sharing options...
