How to get the address of a label?
How to get the address of a label?:
As example: the following placed somewhere in the code:
label
  sta $20
  sta $21
  sta $22
;end of label
Then if at some point of the execution it's required to change the contents to nop, i.e.: all previous 6 bytes inside "label" to "ea":
  lda #$ea
  sta         ; -> but how to know automatically the address where "label" is
46 minutes ago, Harry Potter said:
Try just "sta label".  Does this work?
5 minutes ago, TGB1718 said:
        ldx #5
        lda #ea
loop sta label,x
       dex
       bpl loop
It does not work just making a "sta label", it says it's "undeclared label".
Note: the "sta label" it's being executed inside the code of a function, previously called by a jsr. Are the externals labels hidden inside the function?
You can also use a variation of the old "BIT trick" I suppose.
This allows you to easily restore the original code: you replace STA instruction opcode by BIT instruction opcode to alter and the reverse to restore.
But beware: a BIT instruction used in this way as a NOP does have effects: the flags may be modified!!
myproc  .proc
label
        sta $20
        sta $21
        sta $22
        rts
        .endp
alter_myproc    .proc
        lda #$24        ;  $24= BIT Zero Page, e.g  BIT $44
        sta myproc.label
        sta myproc.label+2
        sta myproc.label+4
        rts
        .endp
restore_myproc    .proc
        lda #$85        ;  $85= STA Zero Page, e.g  STA $44
        sta myproc.label
        sta myproc.label+2
        sta myproc.label+4
        rts
        .endp
Assemblers usually do not care about scope. I don‘t see why it wouldn‘t recognise label. Have you used it twice by any chance?
No.. in that case it'll show a "warning".
I'll try fantomas idea, but not sure if it work because in this case the more code is added (or cpu used) the more glitches appear, so I'm thinking the way to just make a "turn on/off" for a " jmp exit". It's possible to do it at the end when everything is finished and the address where it was placed is known, but I'd like a way to know the address where the statement is placed, in order to point it automatically.
Have you tried just those snippets on a different (emulated) assembler?
5 hours ago, sanny said:
what assembler are you using?
It's MADS, latest version (CRC32: 24a7ea98). (It's shown in the command line in the black screenshot).
No, I only manage its syntax...
This version that inserts a 'jmp label2' compiles with mads.
  • alter_myproc use global exit.it.is
  • alter_myproc2 use local label
But at the end it is exactly the same...
          org $2000
myproc  .proc
label
.def :exit.it.is = *
        sta $20
        sta $21
        sta $22
label2
        rts
        .endp
alter_myproc    .proc
        mva #$4C exit.it.is                        ; $4c = JMP opcode
        mwa #myproc.label2 exit.it.is+1
        rts
        .endp
alter_myproc2    .proc
        mva #$4C myproc.label                       ; $4c = JMP opcode
        mwa #myproc.label2 myproc.label+1
        rts
        .endp
1 hour ago, TGB1718 said:
just had a look at the MADS documentation it looks like you use
EQU or .DEF for global variables, have a look here for examples
https://mads.atari8.info/mads_eng.html#labels
17 minutes ago, fantômas said:
label .def :exit.it.is
Yeah, making a "  .def :label" did the trick, now it compiles and works, thank you.
It seems that everything inside a jsr is treated as local, so external labels are hidden. With the .def now is defined as global and works when calling a jsr.
The Mads documentation says:
Global labels
Each definition outside of a macro (.MACRO), procedure (.PROC), or local scope (.LOCAL) is global.
It should be required to add that a jsr is treated as local, and not global.
Edited by tane
17 minutes ago, tane said:
Global labels
I think that if your label is not global, it proves that it is defined either:
  • in a macro
  • or in a procedure
  • or in a 'local' scope
For a procedure or for a local scope, you can use the notation (with the dot) "procname". "labelname" or "localname". "labelname" to use the label globally.
If you want do call a label within a subroutine, you have to add the subroutine's name in front.
Example:
   org $2000
.local mysub
label1
   lda #$24
   sta 712
   rts
.endl
.proc main
   jsr mysub
   mva #$fe 19
@  lda 19
   bmi @-
   sta mysub.label1+1
   jsr mysub
lp jmp lp
.endp
   run main
38 minutes ago, fantômas said:
  • or in a procedure
After a look, that's right, in a procedure of 4000 lines... The .endp was almost lost at the end, and the open/close fold display was not showing properly in UEStudio because the code has many labels ended in .end, so the "close fold" didn't end in the .endp.
