hansdc Posted July 15, 2021 Share Posted July 15, 2021 hi, I need a new connector for the controller ribbon, 14 pins. can someone tell me where to order this connector please? Quote Link to comment Share on other sites More sharing options...
hansdc Posted September 8, 2021 Author Share Posted September 8, 2021 nobody has an idea? Quote Link to comment Share on other sites More sharing options...
Stephen Moss Posted September 9, 2021 Share Posted September 9, 2021 I presume it is for the forint panel button membrane in which case it is an FCC (Flexible Circuit Connector) type. Try searching of 14 way FCC connector, you should be able to get them from most large component suppliers. However you need to workout the pitch of the connections, usually the wider the pitch the bigger the connector so you could go on connector size but just measure the number of connections over a 1 or 2cm or 1 inch and divide to get the pitch on mm or inches. If I can I will post a pitch later. Quote Link to comment Share on other sites More sharing options...
Stephen Moss Posted September 14, 2021 Share Posted September 14, 2021 Sorry, I forgot to check but the connector are on a 0.1 inch (2.54mm) pitch. Quote Link to comment Share on other sites More sharing options...
