Buckaroo Posted August 18, 2021 Share Posted August 18, 2021 (edited) This is an unusual one, I've had literally hundreds of Pole Position carts and never one with the POLE POSITN* end label. This has been tested and is a PAL cartridge. It has a simple dust shield which is unusual on a silver labelled cartridge. I've found an NTSC version of this cartridge listed on Atari Age here. https://atariage.com/software_page.php?SoftwareLabelID=366 I only have the cartridge, no box or instructions. Edited August 18, 2021 by Buckaroo Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted August 19, 2021 Share Posted August 19, 2021 On 8/18/2021 at 5:41 PM, Buckaroo said: This is an unusual one, I've had literally hundreds of Pole Position carts and never one with the POLE POSITN* end label. This has been tested and is a PAL cartridge. It has a simple dust shield which is unusual on a silver labelled cartridge. I've found an NTSC version of this cartridge listed on Atari Age here. https://atariage.com/software_page.php?SoftwareLabelID=366 I only have the cartridge, no box or instructions. 100% sure it's PAL? Quote Link to comment Share on other sites More sharing options...
Buckaroo Posted August 19, 2021 Author Share Posted August 19, 2021 Yeah I've played it on my PAL system and the colours are correct. 1 Quote Link to comment Share on other sites More sharing options...
Buckaroo Posted October 8, 2021 Author Share Posted October 8, 2021 On 8/19/2021 at 7:48 PM, Rom Hunter said: 100% sure it's PAL? Definitely 100% now, just dumped it using an AtariMax programmer (find it attached). Compared the checksum of this against another PAL version and it appears to be different. I'm new to this so is there a program where you can compare 2 binaries side by side to see the differences? Pole Posit'n PAL.bin Quote Link to comment Share on other sites More sharing options...
Dionoid Posted August 10, 2022 Share Posted August 10, 2022 On 10/8/2021 at 11:49 PM, Buckaroo said: I'm new to this so is there a program where you can compare 2 binaries side by side to see the differences? I'm using WinMerge (a free tool) to compare rom binaries. In this case, I see only the F8 bankswitch hotspot values differ, which kind of depends on the tool you're using to dump the rom. Btw. I've run into these "Pole Posit'n" PAL cartridges a couple of times, so I'm not sure if these are really rare. Quote Link to comment Share on other sites More sharing options...
Buckaroo Posted August 18, 2022 Author Share Posted August 18, 2022 Thanks @Dionoid I'm clueless when it comes to comparing ROMS Quote Link to comment Share on other sites More sharing options...
dwh Posted December 11, 2022 Share Posted December 11, 2022 I assume this PAL end label variant was also released in 1985 ,like it was in the NTSC areas. It took me cutting open a shrink-wrapped box to figure this out; Atari Corp sure confused everything. Quote Link to comment Share on other sites More sharing options...
Buckaroo Posted December 11, 2022 Author Share Posted December 11, 2022 (edited) 2 hours ago, dwh said: I assume this PAL end label variant was also released in 1985 ,like it was in the NTSC areas. It took me cutting open a shrink-wrapped box to figure this out; Atari Corp sure confused everything. Yes you're probably right. I've never had a PAL version with that end label and the original box but I'll probably find one at some point. I'll post back here if I do. Edited December 11, 2022 by Buckaroo Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted December 11, 2022 Share Posted December 11, 2022 11 hours ago, dwh said: I assume this PAL end label variant was also released in 1985 ,like it was in the NTSC areas. It took me cutting open a shrink-wrapped box to figure this out; Atari Corp sure confused everything. Can you show me the back of that box? Quote Link to comment Share on other sites More sharing options...
