rsiddall Posted August 28, 2021 Share Posted August 28, 2021 (edited) Figured I'd see if I could get it working and then maybe move it over to the multi-sprite kernel. Anyhoo...here's what I have so far. EDIT: Titlescreen/Last version can be found in first post (here.) FTP_Toasters2021.bas.bin Edited September 26, 2021 by rsiddall 2 Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/ Share on other sites More sharing options...
rsiddall Posted August 28, 2021 Author Share Posted August 28, 2021 (edited) Is there another way to write: if collision(playfield,player0) then P0posX = startP0x:P0posY = startP0y For some reason, I can't get it to work in the multisprite kernel if I'm using more than player0 and player1 sprites. So, no way to get my toasters and toast to return to starting positions once they've hit the playfield. THIS Is it possible to flicker sprites in the standard kernel? If so, would someone be able to provide an example? Or add additional sprites (not through NUSIZ) to fill more of the space with toasters/toast. Added music to the latest version. Flying-ToastersUPDATEDrev2.bin Edited August 29, 2021 by rsiddall Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4894956 Share on other sites More sharing options...
rsiddall Posted August 29, 2021 Author Share Posted August 29, 2021 Made some progress in the standard kernel. ? toast-test-rev3.bin Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4895512 Share on other sites More sharing options...
rsiddall Posted August 30, 2021 Author Share Posted August 30, 2021 (edited) Ehhh...flickering just didn't look nice (to me). Figured out another solution to keep speed and "solid" look. New reversion attached! Updated toasters, too. Flying-ToastersUPDATEDrev3.bin Edited August 30, 2021 by rsiddall 1 Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4895961 Share on other sites More sharing options...
+ZeroPage Homebrew Posted August 31, 2021 Share Posted August 31, 2021 On 8/30/2021 at 11:01 AM, rsiddall said: New reversion attached! Updated toasters, too. The new version looks great! I'll be featuring it on the news section of ZPH tonight. ? - James 1 Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4896759 Share on other sites More sharing options...
rsiddall Posted August 31, 2021 Author Share Posted August 31, 2021 1 hour ago, ZeroPage Homebrew said: The new version looks great! I'll be featuring it on the news section of ZPH tonight. ? - James Awesomeness! I look forward to watching. ? 1 Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4896816 Share on other sites More sharing options...
chewy Posted September 2, 2021 Share Posted September 2, 2021 id take slow toasters, no sound - for a screensaver, if that could be an option 1 Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4897549 Share on other sites More sharing options...
rsiddall Posted September 2, 2021 Author Share Posted September 2, 2021 (edited) 2 hours ago, chewy said: id take slow toasters, no sound - for a screensaver, if that could be an option I can slow the toasters down...had them moving quite slow but after a few rounds, some of the toasters drop out. Not sure if that's my code or something else? I've got a version (haven't posted it here, yet) that is running 10-12% slower without a hitch. It seems to happen when you get down past a certain percentage. Current version has fire button to 'reset' and 'select' button to change P1 toast color. Have another version that uses the fire button to change P0 toast color and 'select' button to change P1 toast color. I'm working on setting up the color/bw switch to turn sound on/off. Lots of tweaks planned - need to get what I think most people would enjoy/ease of use. Also looking to replace music with flapping sound (like Joust)...just need a good sound effect/sound. Edited September 2, 2021 by rsiddall Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4897616 Share on other sites More sharing options...
chewy Posted September 2, 2021 Share Posted September 2, 2021 13 hours ago, rsiddall said: I can slow the toasters down...had them moving quite slow but after a few rounds, some of the toasters drop out. Not sure if that's my code or something else? I've got a version (haven't posted it here, yet) that is running 10-12% slower without a hitch. It seems to happen when you get down past a certain percentage. Current version has fire button to 'reset' and 'select' button to change P1 toast color. Have another version that uses the fire button to change P0 toast color and 'select' button to change P1 toast color. I'm working on setting up the color/bw switch to turn sound on/off. Lots of tweaks planned - need to get what I think most people would enjoy/ease of use. Also looking to replace with flapping sound (like Joust)...just need a good sound effect/sound. oh noooo my tv bw/color switch is rubberbaded to the power switch on my 6'r to keep the power switch on in place and its nearly impossible to use it Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4897924 Share on other sites More sharing options...
rsiddall Posted September 3, 2021 Author Share Posted September 3, 2021 On 9/2/2021 at 12:08 PM, chewy said: oh noooo my tv bw/color switch is rubberbaded to the power switch on my 6'r to keep the power switch on in place and its nearly impossible to use it LOL...I'm sure I can work something out. Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4898706 Share on other sites More sharing options...
chewy Posted September 4, 2021 Share Posted September 4, 2021 (edited) On 9/3/2021 at 10:11 AM, rsiddall said: LOL...I'm sure I can work something out. Edited September 4, 2021 by chewy Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4899411 Share on other sites More sharing options...
rsiddall Posted September 4, 2021 Author Share Posted September 4, 2021 (edited) I've skipped a few revisions to get, what I think, the best set-up for this screensaver. Up on the joystick (Joy0) will change some of the toast colors. Down on the joystick (Joy0) will change the rest of the toast colors. This allows for several color combinations. Pressing the fire button will reset the screensaver (colors and toasters will revert to original starting positions). In this version, I have dropped the song in favor of flapping wings. This can be turned off with the B/W switch and turned back on with the Color switch. Added a hi-res title screen, and toasters have been slowed down 30%. 10-04-21 Flying-ToastersUPDATEDrev9.bin Edited September 4, 2021 by rsiddall 1 Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4899555 Share on other sites More sharing options...
rsiddall Posted September 4, 2021 Author Share Posted September 4, 2021 On 9/1/2021 at 8:38 PM, chewy said: id take slow toasters, no sound - for a screensaver, if that could be an option Here's slower toasters and no sound...enjoy! Flying-Toasters_NoSound.bin Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4899556 Share on other sites More sharing options...
chewy Posted September 5, 2021 Share Posted September 5, 2021 19 hours ago, rsiddall said: Here's slower toasters and no sound...enjoy! Flying-Toasters_NoSound.bin 4 kB · 4 downloads love it my guy, hey can we dial it back even a little more to match the speed of After Dark 2.0? Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4900040 Share on other sites More sharing options...
rsiddall Posted September 5, 2021 Author Share Posted September 5, 2021 2 hours ago, chewy said: love it my guy, hey can we dial it back even a little more to match the speed of After Dark 2.0? Can't go much slower...animation is totally hosed after a certain percentage. Looks like toasters shuffling (rather than flying). The animation just doesn't work when the percentage is slowed past a certain amount. Slow_Toast.mov Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4900133 Share on other sites More sharing options...
chewy Posted September 6, 2021 Share Posted September 6, 2021 2 hours ago, rsiddall said: Can't go much slower...animation is totally hosed after a certain percentage. Looks like toasters shuffling (rather than flying). The animation just doesn't work when the percentage is slowed past a certain amount. Slow_Toast.mov ah! well i love it!!! you added to the VCS defintely! 1 Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4900214 Share on other sites More sharing options...
rsiddall Posted September 6, 2021 Author Share Posted September 6, 2021 14 hours ago, chewy said: ah! well i love it!!! you added to the VCS defintely! Found a way to get a slower animation without it "sliding" down the screen...see if this is closer to what you were thinking. ? I'm still working a few more options...stay tuned! Flying-ToastersSLOW.bin Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4900523 Share on other sites More sharing options...
chewy Posted September 6, 2021 Share Posted September 6, 2021 8 hours ago, rsiddall said: Found a way to get a slower animation without it "sliding" down the screen...see if this is closer to what you were thinking. ? I'm still working a few more options...stay tuned! Flying-ToastersSLOW.bin 4 kB · 3 downloads ITS FLIPPING PERFECT! Fantastic work-- i love this i love this! 1 Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4900793 Share on other sites More sharing options...
rsiddall Posted September 9, 2021 Author Share Posted September 9, 2021 (edited) Definitive version of Toasters-Flying attached - all the previous bells and whistles with better flapping sounds. Have included another iteration with music data (can't turn song off). And another surprise that can be found here: Toasters-AD.bin Toasters-Valkyries.bin Edited September 9, 2021 by rsiddall 1 Quote Link to comment https://forums.atariage.com/topic/324353-flying-toasters-screensaver/#findComment-4902180 Share on other sites More sharing options...
