+bf2k+ Posted October 1, 2021 Share Posted October 1, 2021 I was just working with my SDrive Max (1050S) a little while ago when all of a sudden the screen went blank... turned white. Any ideas? SD Card looks OK. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 1, 2021 Share Posted October 1, 2021 Reflash it, make sure everything is seated properly? Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted October 2, 2021 Author Share Posted October 2, 2021 1 hour ago, _The Doctor__ said: Reflash it, make sure everything is seated properly? I talked with the guy at VCC where I got it. He seems to think that the Arduino is toast (based on the pilot errors I made with the external power supply and the little switch on the front.) (Ouch) Is it normally flashed thru the USB port on the device? If so, where is the flasher and firmware/software available? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 2, 2021 Share Posted October 2, 2021 https://github.com/kbr-net/sdrive-max https://atariwiki.org/wiki/Wiki.jsp?page=SDrive-MAX https://atari8bit.net/tutorials/de-re-sdrive-max/ below is the historical site http://www.kbrnet.de/projekte/sdrive-max/index.html Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted October 2, 2021 Author Share Posted October 2, 2021 Yes I found it... thanks. Plugging in the device does not load the drivers so I cannot select the COM port for the flash. This makes me think that VCC is correct - the Arduino is toast. Thanks for your help. I really appreciate it. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 2, 2021 Share Posted October 2, 2021 at least a replacement duino can be dirt cheap... Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted October 2, 2021 Share Posted October 2, 2021 10 hours ago, bf2k+ said: I was just working with my SDrive Max (1050S) a little while ago when all of a sudden the screen went blank... turned white. Any ideas? SD Card looks OK. You used white out instead of delete to remove text???? Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted October 2, 2021 Author Share Posted October 2, 2021 7 hours ago, sup8pdct said: You used white out instead of delete to remove text???? Isn't that the correct method? Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted October 3, 2021 Share Posted October 3, 2021 10 hours ago, bf2k+ said: Isn't that the correct method? 'Correction' method ? 1 Quote Link to comment Share on other sites More sharing options...
