+Al_Nafuur Posted October 25, 2021 Share Posted October 25, 2021 I am trying to do something similar to a trick @Karl G did with the standard kernel: https://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#easy_way_to_set_player_graphic_to_number I want to use the same definition for multiple sprites of the multisprite kernel, but it doesn't fully work. test.bas.bin bB code: includesfile multisprite_bankswitch.inc set kernel multisprite set romsize 16k const _Small_Plane_down_high = >Small_Plane_down const _Small_Plane_down_low = <Small_Plane_down bank 1 player1x = 75 player1y = 75 _COLUP1 = $D6 COLUBK = $96 ; bB player graphics hack player1pointerlo = _Small_Plane_down_low player1pointerhi = _Small_Plane_down_high player1height = 6 ; assembler version /* asm LDX #<Small_Plane_down STX player1pointerlo LDA #>Small_Plane_down STA player1pointerhi LDA #6 STA player1height end */ Mainloop player1y = player1y - 1 if player1y = 255 then player1y = 88 drawscreen goto Mainloop bank 2 bank 3 bank 4 asm ; align 256 end data Small_Plane_down %00011000 %01111110 %01111110 %10011001 %00111100 end Quote Link to comment Share on other sites More sharing options...
+Karl G Posted October 25, 2021 Share Posted October 25, 2021 I'm really not sure what's going on. You can get rid of the garbage on the left of the screen by defining player0 and getting it out of the way. The issue with the graphic not working towards the top of the screen is a mystery to me, though. Oddly, it only happens with a bankswitched ROM. I can "fix" it by making it 4k: ; includesfile multisprite_bankswitch.inc set kernel multisprite ; set romsize 16k const _Small_Plane_down_high = >Small_Plane_down const _Small_Plane_down_low = <Small_Plane_down ; bank 1 player1x = 75 player1y = 75 _COLUP1 = $D6 COLUBK = $96 ; bB player graphics hack player1pointerlo = _Small_Plane_down_low player1pointerhi = _Small_Plane_down_high player1height = 5 ; assembler version /* asm LDX #<Small_Plane_down STX player1pointerlo LDA #>Small_Plane_down STA player1pointerhi LDA #6 STA player1height end */ player0: end player0y = 100 ; offscreen Mainloop player1y = player1y - 1 if player1y = 255 then player1y = 88 drawscreen goto Mainloop ; bank 2 ; bank 3 ; bank 4 /* asm align 256 end */ data Small_Plane_down %00011000 %01111110 %01111110 %10011001 %00111100 end 1 Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted October 25, 2021 Author Share Posted October 25, 2021 27 minutes ago, Karl G said: I'm really not sure what's going on. You can get rid of the garbage on the left of the screen by defining player0 and getting it out of the way. The issue with the graphic not working towards the top of the screen is a mystery to me, though. Oddly, it only happens with a bankswitched ROM. I can "fix" it by making it 4k: I fumbled around with it in the 1942 project and somehow it works now with 16K. I am not sure what "fixed" it, if you like you can have a look at the code here: https://github.com/Al-Nafuur/PlusROM-Hacks/blob/main/bBasic/1942/1942 HSC.bas Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 3, 2021 Share Posted November 3, 2021 I'm going to start my own investigation as to what works and doesn't in your sweet new sprite data technique. My hunch is that when it doesn't work somehow the label for sprite data isn't available in the bank your sprite pointer assignment code is run. But, I am a pretty clueless programmer. I don't know if this is related but I have to ask: what does this code near your sprite data do? asm if (<*) > (<(*+8)) repeat ($100-<*) .byte 0 repend endif end Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted November 3, 2021 Author Share Posted November 3, 2021 6 hours ago, Gemintronic said: I'm going to start my own investigation as to what works and doesn't in your sweet new sprite data technique. My hunch is that when it doesn't work somehow the label for sprite data isn't available in the bank your sprite pointer assignment code is run. But, I am a pretty clueless programmer. The player data have to be in the same bank than the bB kernel. 6 hours ago, Gemintronic said: I don't know if this is related but I have to ask: what does this code near your sprite data do? asm if (<*) > (<(*+8)) repeat ($100-<*) .byte 0 repend endif end This asm code (or dasm macro) checks if there is enough space in the current page for the sprite data, if not it fills the rest of the page with zeros and the sprite data begins in the next page. So the kernel will not have the extra cpu cycle when reading the sprite data across a page boundary. 1 Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted November 3, 2021 Author Share Posted November 3, 2021 I have investigated this a little bit further and it looks like the kernel don't likes sprite definitions within the first "90" (decimal) bytes of the page. So the this macro is placed before every sprite: if (<*) > (<(*+(SpriteDataLength-1))) repeat ($100-<*) .byte 0 repend endif if (<*) < 90 repeat (90-<*) .byte 0 repend endif If I do the same it seems to work in my 1942 code now 1 Quote Link to comment Share on other sites More sharing options...
