TGB1718 Posted November 21, 2021 Share Posted November 21, 2021 I've been writing a 6502 disassembler in CC65 mainly to provide functionality that I don't see in the ones I've used. I have it producing the file segments and their sizes and tried it on a file I created for a game I was writing, the object file is 2K in size and assembled in MAC/65, my question is, is it normal for native 6502 assemblers to produce so many segments in a file, I just find it strange. This is the output:- Select Output Device Screen, Printer, Disk, Cassette Segment 1: Load:A000 End:A0FB Size:00FB Segment 2: Load:A0FC End:A1F7 Size:00FB Segment 3: Load:A1F8 End:A2F3 Size:00FB Segment 4: Load:A2F4 End:A3EF Size:00FB Segment 5: Load:A3F0 End:A4B4 Size:00C4 Segment 6: Load:A4B5 End:A5A4 Size:00EF Segment 7: Load:A5A5 End:A6A0 Size:00FB Segment 8: Load:A6A1 End:A6C1 Size:0020 Segment 9: Load:A6C2 End:A7BD Size:00FB Segment 10: Load:A7BE End:A7D8 Size:001A D5:\MAC65\CITY> I compiled the same code using MADS and although it doesn't run (still trying to find all the differences between MAC/65 and MADS) and this is just one segment:- Select Output Device Screen, Printer, Disk, Cassette Segment 1: Load:A000 End:A7DE Size:07DE D5:\MAC65\CITY> Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 21, 2021 Share Posted November 21, 2021 Possibly this was a way to avoid having to buffer large segments of the object file in RAM. Unless the assembler created an abstracted table of all segment sizes on the first pass, it won't know what to write by way of a segment header until it's reached the end of said segment. If it just arbitrarily limits segments to 252 bytes, it can get away with a 256 byte output buffer. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 21, 2021 Author Share Posted November 21, 2021 @flashjazzcat that was my thought too, but it just sort of seemed rather small, then again disk based MAC/65 may have run in 32K which wouldn't leave a lot of memory for the processing etc. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 21, 2021 Share Posted November 21, 2021 When I wrote a macro assembler (based on Charles Marslett's 'A65') I ran into this exact issue, and I just went for maximum segment sizes of 252 bytes. One could just as easily remember the file position of the start of the current segment and seek back to it once the whole thing has been written out and the segment size known (in order to write the header), but I wanted to keep it simple and I wrote a stand-alone de-segmentation tool. Such fragmentation is definitely the enemy of burst IO, though. Another way around it is to keep a table in RAM of all the segment sizes, but that could get rather large in itself. Quote Link to comment Share on other sites More sharing options...
ivop Posted November 21, 2021 Share Posted November 21, 2021 I believe this is a known "issue" with MAC/65. There are even utilities to merge the segments and defrag the file. As for cross-assembling, try ATASM. It uses MAC/65 syntax. Quote Link to comment Share on other sites More sharing options...
vitoco Posted November 21, 2021 Share Posted November 21, 2021 As @flashjazzcat said, it is MAC/65 who is "splitting" the file in those segments, but it is OK other than having extra header bytes in the XEX file. Back in those days, I wrote a small BASIC utility to "solve" that issue. Today, I use XEX Filter (option -z 0). 2 Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted November 21, 2021 Share Posted November 21, 2021 Yep, as I have read it is standard for MAC/65 and Atari Assembler (or AMAC?) to produce dozens of small segments. One may use Streamliner, PrObj or similar tools on the A8 to merge them into one single/contiguous/monolithic data segment. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 21, 2021 Share Posted November 21, 2021 As mentioned, it's also not going to help with loading speed, since the binary loader will be issuing many small IO requests even if a segment occupies a large contiguous area of memory. Quote Link to comment Share on other sites More sharing options...
VinsCool Posted November 22, 2021 Share Posted November 22, 2021 9 hours ago, vitoco said: As @flashjazzcat said, it is MAC/65 who is "splitting" the file in those segments, but it is OK other than having extra header bytes in the XEX file. Back in those days, I wrote a small BASIC utility to "solve" that issue. Today, I use XEX Filter (option -z 0). Wow I wish I knew this tool existed before today! I've done all my executable manipulations directly through an hex editor, or disassembly code I re-created, in such a way things are now very modular, but this tool would have saved me a lot of time! hahaha Quote Link to comment Share on other sites More sharing options...
stepho Posted November 23, 2021 Share Posted November 23, 2021 On 11/21/2021 at 10:54 PM, TGB1718 said: Segment 1: Load:A000 End:A0FB Size:00FB The end address or the size is off by one. Should be one of the following: Segment 1: Load:A000 End:A0FB Size:00FC Segment 1: Load:A000 End:A0FA Size:00FB Quote Link to comment Share on other sites More sharing options...
vitoco Posted November 23, 2021 Share Posted November 23, 2021 It should be this one: 5 hours ago, stepho said: Segment 1: Load:A000 End:A0FB Size:00FC $FC = 252 bytes. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 23, 2021 Author Share Posted November 23, 2021 31 minutes ago, vitoco said: $FC = 252 bytes. Thanks, still coding and testing Quote Link to comment Share on other sites More sharing options...
