nicknickuk Posted November 25, 2021 Share Posted November 25, 2021 (edited) Hi all I have recently finished my Atari Flashback Raspberry Pi conversion. I have based it on the look of the Atari 2600 Vader edition. This is an Atari Flashback 6 with a Raspberry Pi 3b+ inside with Retropie. I removed the Flashback buttons and replaced them with arcade style buttons. I used black snakeskin style vinyl wrap to cover the brown wood effect front panel. I removed the old Joystick ports and added USB ports. I cut a hole in the back to add an HDMI port. Another hole was cut to add a Micro SD card reader so I can easily remove the SD card without opening up the whole case. I wired the Pi board to the power button and a white power LED. Hot glue, super glue and lots of filing was used for the project. The Pi board is currently sitting loose in the case as not a lot of room to bolt it in, but it is very secure as it is. I have converted an Atari Flashback 7800 joystick to work via USB by using a convertor. Also connected, an 8Bitdo wireless controller. Just for effect......I messed around with a couple of "free" retro wallpaper backgrounds and stuck my Flashback in the middle, which came out well. Edited November 25, 2021 by nicknickuk 1 Quote Link to comment Share on other sites More sharing options...
Draxxon Posted November 25, 2021 Share Posted November 25, 2021 That's really nice looking. You nailed it! Quote Link to comment Share on other sites More sharing options...
