Atari Flashback Vader - Pi conversion
nicknickuk
Hi all
I have recently finished my Atari Flashback Raspberry Pi conversion. I have based it on the look of the Atari 2600 Vader edition.
This is an Atari Flashback 6 with a Raspberry Pi 3b+ inside with Retropie.
I removed the Flashback buttons and replaced them with arcade style buttons.
I used black snakeskin style vinyl wrap to cover the brown wood effect front panel.
I removed the old Joystick ports and added USB ports.
I cut a hole in the back to add an HDMI port.
Another hole was cut to add a Micro SD card reader so I can easily remove the SD card without opening up the whole case.
I wired the Pi board to the power button and a white power LED.
Hot glue, super glue and lots of filing was used for the project.
The Pi board is currently sitting loose in the case as not a lot of room to bolt it in, but it is very secure as it is.
I have converted an Atari Flashback 7800 joystick to work via USB by using a convertor.
Also connected, an 8Bitdo wireless controller.
Just for effect......I messed around with a couple of "free" retro wallpaper backgrounds and stuck my Flashback in the middle, which came out well.
  • Like 9
Thats really nice looking. You nailed it. The switches look great and the new holes you had to make are pretty clean.
the only thing that i can see that would be neat is to cover the entire front with the black vinyl and somehow print the old style logo on it????
job well done, man!
Thanks, Draxon. Yep I had considered that. I have plenty of vinyl wrap, just need to find somewhere that supplies an Atari logo sticker or something.
job well done, man!
  • 2 weeks later...
You did awesome work on this.  It looks amazing.
I'm sure you considered adding USB to 9-pin to adapters (Stelladapter, 2600-dapter-D9, etc.) to make it compatible with original controllers.  Of course that's not necessary since there are so many Bluetooth and USB options, but it could be a cool option if you ever made another one.
Thanks, Akator. Glad you like. I have a DB9 adapter attached to the Atari flashback controller so I can just plug it into the USB port when I use the joystick but I mainly use the Bluetooth 8bitdo controller. It’s a good idea of yours to add the adapter into the console although on this particular project there might not be enough room left inside.
  • 1 month later...
On 11/26/2021 at 4:41 PM, Draxxon said:
here is a mockup i made recently. I think that a vader flashback would be sweet.
With SD slot on cartridge opening and hardware based on a pi+retroarch or some kind of nes classic mini (even the chinese clone)... Android sux.
Edited by vieiraandre
