Macro VS Subroutine
Cisano
Hi, I have a problem.
I created a macro for update GRP1 X coordinate. Not the positioning, but only the value.
The code is executed during vertical blank time.
Y is used inside the Macro. All works great.
ldy #0
UpdateGRP1_Macro
I tried to use the same code by a Subroutine.
ldy #0
jsr UpdateGRP1
It doesn't work good. The sprite movement is not smooth.
Is there something I don't know about these 2 way to use code?
Thanks.
Edited by Cisano
        lda FrqFrameGRPX
        and MaskOne,y
        bne .end
        lda XposGRP1,y
        cmp StartOne,y
        bne .other
        lda #1
        sta CursorSpringOne,y
        jmp .opera
.other
        ;lda XposGRP1,y
        cmp ArriveOne,y
        bne .opera
        lda #$ff
.opera
        clc
        lda CursorSpringOne,y
        adc XposGRP1,y
        sta XposGRP1,y
.end
        lda StartOne,y
        cmp ArriveOne,y
        bne exit
        sta XposGRP1,y
exit
		rts
The Macro has not the rts.
Just some generic things to look for...
1.
Jumping to the subroutine takes a few cycles.
Returning also takes a few cycles.
You said it is in the vertical blank code but is it time sensitive?
2.
Storing the return address takes a few bytes of stack.
Is the stack big enough?
3.
Some bank switching schemes trigger off subroutine calls (ie when you write/read the return address in the first few elements of the stack).
1. I set a timer and the vertical blank time is not all used.
2. yes it is
3. no bank switching for now
I just moved the subroutine in another part of the cose, upper, and it works good.
It is the normality or there are solutions?
Thanks.
Edited by Cisano
15 hours ago, Cisano said:
Penalty? You mean extra cycles?
Yup.
Always when a branch or an indexed table access crosses a 256 bytes page the instruction takes one extra cycle.
To check this during assembly I have written a simple macro:
  MAC CHECKPAGE
    IF >. != >{1}
      ECHO ""
      ECHO "ERROR: different pages! (", {1}, ",", ., ")"
      ECHO ""
      ERR
    ENDIF
  ENDM
If your branch moves backward, put this behind the branch and provide the branch address. If it is a table, put it at the end of the table and provide the table address.
Edited by Thomas Jentzsch
