SpaceHunter Posted January 3, 2022 Share Posted January 3, 2022 According to the documentation... DEF FN func = RAND % 10 DEF FN screen_off(row, col) = (row * 20 + col) DEF FN resetsprite(number) = SPRITE number,0 Allows to define functions with any number of arguments. Notice that these are processed like macros: The arguments are replaced as-is and the text of the function is inserted as-is after argument replacement. (because of that are included the extra parenthesis in the screen_off expression) For example, the two functions screen_off and resetsprite could be called as: A = func PRINT AT screen_off(4,8),"HELLO!" resetsprite(0) Please note that although it's possible to reuse internal function names, when called the internal functions have priority over DEF FN (DEF FN is ignored) It does not described what type the arguments can be. For instance, I would like to pass an array. I presume this is not supported since I get an error when calling the MACRO when compiling the code. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted January 3, 2022 Share Posted January 3, 2022 (edited) 14 minutes ago, SpaceHunter said: According to the documentation... DEF FN func = RAND % 10 DEF FN screen_off(row, col) = (row * 20 + col) DEF FN resetsprite(number) = SPRITE number,0 Allows to define functions with any number of arguments. Notice that these are processed like macros: The arguments are replaced as-is and the text of the function is inserted as-is after argument replacement. (because of that are included the extra parenthesis in the screen_off expression) For example, the two functions screen_off and resetsprite could be called as: A = func PRINT AT screen_off(4,8),"HELLO!" resetsprite(0) Please note that although it's possible to reuse internal function names, when called the internal functions have priority over DEF FN (DEF FN is ignored) It does not described what type the arguments can be. For instance, I would like to pass an array. I presume this is not supported since I get an error when calling the MACRO when compiling the code. The arguments can be anything at all -- any IntyBASIC expression. The compiler takes the arguments, as is, and interpolates them in-line into the macro. Then the entire thing -- the statement with the composed macro -- is evaluated as any other statement. If the array argument is causing an error, it could be that an array is not valid in the resulting expression. Perhaps a syntax error. Can you offer an example of what you are trying? dZ. Edited January 3, 2022 by DZ-Jay Quote Link to comment Share on other sites More sharing options...
SpaceHunter Posted January 3, 2022 Author Share Posted January 3, 2022 I have a simple sort macro... DEF FN swap(arr, xp, yp) = \ temp = arr(xp)\ arr(xp) = arr(yp)\ arr(yp) = temp DEF FN sort(arr, n) = \ FOR i = 0 TO n - 1\ FOR j = 0 TO n - i - 1\ IF arr(j) > arr(j+1) THEN\ swap(arr, j, j+1)\ END IF\ NEXT j\ NEXT i This compiles fine, no errors or warnings. However, when I call it with an array with integers... sort(myArray, length) ' ...rest of code I get a strange error complaining about the following statement thereafter, after the macro has been invoked. If I comment out the sort call, I'm back with a clean compilation. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted January 3, 2022 Share Posted January 3, 2022 31 minutes ago, SpaceHunter said: I have a simple sort macro... DEF FN swap(arr, xp, yp) = \ temp = arr(xp)\ arr(xp) = arr(yp)\ arr(yp) = temp DEF FN sort(arr, n) = \ FOR i = 0 TO n - 1\ FOR j = 0 TO n - i - 1\ IF arr(j) > arr(j+1) THEN\ swap(arr, j, j+1)\ END IF\ NEXT j\ NEXT i This compiles fine, no errors or warnings. However, when I call it with an array with integers... sort(myArray, length) ' ...rest of code I get a strange error complaining about the following statement thereafter, after the macro has been invoked. If I comment out the sort call, I'm back with a clean compilation. Your problem is that you are using "\" to concatenate all statements together. It's like if you've written: FOR i = 0 TO n - 1 FOR j = 0 TO n - i - 1 IF arr(j) > arr(j+1) THEN ... which is obviously not valid syntax. Since the macro forces you to define everything on a single line, you need ":" in between statements to separate the commands. dZ. 1 Quote Link to comment Share on other sites More sharing options...
SpaceHunter Posted January 4, 2022 Author Share Posted January 4, 2022 (edited) 1 hour ago, DZ-Jay said: which is obviously not valid syntax. Sure would be nice to have the compiler flag it then. Quote Since the macro forces you to define everything on a single line, you need ":" in between statements to separate the commands. Ah yes, I forgot the colons, however, you can define a macro on multiple lines using backslash. Edited January 4, 2022 by SpaceHunter Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted January 4, 2022 Share Posted January 4, 2022 (edited) 51 minutes ago, SpaceHunter said: Sure would be nice to have the compiler flag it then. Ah yes, I forgot the colons, however, you can define a macro on multiple lines using backslash. Yes, but all the backslash does is escape the newline -- that is, it ignores the carriage-return and concatenates the two lines. It does not separate the statements. In a macro, you only use the newlines to format your commands as multiple lines, for legibility. You still need the colons in between separate statements. Put another way: A macro supports exactly one line of code. That line of code may contain multiple statements separated by colons. That line of code may further be formatted into multiple lines, for the sake of legibility, using the backslash. -dZ. Edited January 4, 2022 by DZ-Jay 1 1 Quote Link to comment Share on other sites More sharing options...
