Basic sprite question
wopr67
I am experimenting with sprites, and I have a simple two-line kernel.  Every even-numbered scanline should show a solid red line (#255), while every odd-numbered scanline should show a dotted (#170) yellow line.  I want to use GRP0 for both odd and even lines.  Nothing I have tried works, and for the life of me, I can't figure out why.  Here is my kernel:
NextFrame
		VERTICAL_SYNC
		TIMER_SETUP 37
		lda #$70
		sta COLUBK
		lda #0
		sta VDELP0
		lda #0
		sta GRP0
		sta GRP1
        TIMER_WAIT
		ldx #192
LVScan
		txa
		and #$01
		beq .oddscan
.evenscan
		lda #$48	;red
		sta COLUP0
		lda #255
		sta GRP0
		sta RESP0
		jmp .join
.oddscan
		lda #$1e	;yellow
		sta COLUP0
		lda #170
		sta GRP0
		sta RESP0
.join
		sta WSYNC
		dex
        bne LVScan
		; 30 lines of overscan
		TIMER_SETUP 32
		lda #170
		sta GRP0
        TIMER_WAIT
        jmp NextFrame
Any idea what the problem is?
Thanks!
Edited by wopr67
18 hours ago, Karl G said:
I'm pretty sure the problem is the RESP0 in your kernel.
+1 . Writing to RESP0 has ... all kinds of tricky side effects. To keep things simple strobe RESP0 before you go into your display loop. This could be as simple as inserting WSYNC / SLEEP ... / sta RESP0  - before you go into LVScan. By changing the sleep value you'll be able to observe how strobing at different points sets the sprite to different horizontal positions.
It is also super helpful to use stella in debug mode and step through frame by frame / line by line to observe what's happening on each scan line.
Edited by Dave C
