Sheddy Posted September 2, 2003 Share Posted September 2, 2003 @ Sheddy I think Analmux is talking about about something like this? I wasn't quite thinking along the same lines to start with, but his idea should work out better Yes, that's a bit what I mean, except, you'd need 16 kB screendata. Nice pictures you made . I thought about this method last weekend. It must be possible to do this in both directions, that's for sure. But I stepped off of this idea. It needs twice as much RAM. I'm working on a Super Mario clone, which plays in ONE load from disk with 40 big levels, so I had to minimize the amount of RAM needed for the screen. Though it's in charmode 4, I had just about 1500 Bytes left for the screen, so I'm using a different technique, which can be applied in Antic E too. It's based on some Display List hocus pocus, splitting the screen in a way you don't have to worry about the LMS bullshit. It's usable for both horizontal AND vertical scrolling. You know, when you make a scroller you MUST take care of where the graphicsline BEFORE the LMS-line ends. But I don't. I just make two identical lines in different memory locations to solve the problem. So for the exceptional lines there's always one copy somewhere else. The exceptional lines are not only lines before LMS but also at the line with the highest address, so the line after.... forget it, it's too complex , I'll make some pictures to demonstrate this soon. It's kind of a complex way, but it saves the most time AND memory. ----- mux Very intriguing Look forward to seeing how this works.. (Instantly some Q's arise...How can you avoid having almost 2 screens worth of memory set aside without having to do a large copy at some point???) Sounds clever! Hadn't really thought it all through to having double buffered software sprites...mode E - 30K - scary. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 2, 2003 Share Posted September 2, 2003 Sheddy... the clever thing in this "2 collum method" is that you don't need to do this "copy whole screen back" once... as you are actually building 2 screens... the only thing you have to do is then reset the LMSs in the dlist... very clever... damned it's so common on nintendo machines that i would have thought on that method earlier... check out on No$GB emulator f.e. mario world... and have a look on the tilemap... or get an intro with a softscroller... then you see that they do exactly the same like the discribed one... hve Quote Link to comment Share on other sites More sharing options...
analmux Posted September 2, 2003 Share Posted September 2, 2003 No Sheddy & Heaven, that's not what I mean. you'd just need 8kB and you have only ONE screen, and only ONE column to buffer the incoming graphics. You can cleverly time software sprite rendering when you paint the highest sprites (on the upper part of the screen) first, before a certain deadline. You won't need double buffering then. ----- mux Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 2, 2003 Share Posted September 2, 2003 Mux, i haven't dealt with double buffering... his method/drawing does not deal with double buffering? i was just refering in terms of horizontal scrolling in bitmap mode without the need of copying the whole screen at a certain point before you reset the LMSs... hve/tqa Quote Link to comment Share on other sites More sharing options...
analmux Posted September 2, 2003 Share Posted September 2, 2003 i was just refering in terms of horizontal scrolling in bitmap mode without the need of copying the whole screen at a certain point before you reset the LMSs... Then we're still talking about the same thing . My method uses 8 kB with one screen and some DL hocus pocus (and you still don't need to copy the whole screen once in a while), instead of 16 kB and two screens for horizontal (& vertical scrolling). The difference between the method Sheddy explained and mine differ in the amount of double mapped graphics. Sheddy's method uses a copy of the graphics on EVERY line (might be 192), and I use a copy of graphics only on the exceptional lines (might be 2,3 or 4), namely the lines that cause trouble. So my screen has appr. 196 * 40 bytes = appr. 8 kB, and Sheddy's screen has appr. 192*80 bytes = appr. 16 kB. ----- mux Quote Link to comment Share on other sites More sharing options...
Sheddy Posted September 2, 2003 Share Posted September 2, 2003 Still don't get how it could work Mux - you'll have to show us mere mortals an example! Quote Link to comment Share on other sites More sharing options...
analmux Posted September 2, 2003 Share Posted September 2, 2003 Mine writes a new column to the left and the right of the viewing window once every four frames (scrolling at a pixel a frame). My prototype NES scrolling routine works in almost exactly the same way, it seems to be the norm on the NES... =-) Is the NES screen that flexible? A nes screen is 32 chars wide, but are you saying that it has a 64 chars wide screen area in which the NES can scroll. Does the NES also has a Dlist? Or is it bound to 64 chars lines? Isn't the NES screen a perfect wrap-around with exactly 32 chars wide? It seems to me it has a colorbug on the borders. Look at Mario 3 when scrolling. In the right border the color/palette-RAM is refreshed. ----- mux Quote Link to comment Share on other sites More sharing options...
TMR Posted September 2, 2003 Share Posted September 2, 2003 Mine writes a new column to the left and the right of the viewing window once every four frames (scrolling at a pixel a frame). My prototype NES scrolling routine works in almost exactly the same way, it seems to be the norm on the NES... =-) Is the NES screen that flexible? A nes screen is 32 chars wide, but are you saying that it has a 64 chars wide screen area in which the NES can scroll. The NES screen RAM is actually four blocks of memory with optional mirroring, so you can have screens at $2000, $2400, $2800 and $2c00 arranged in a 64 by about 60 character square. As you increment the horizontal smooth scroll, the $2000 screen moves off the left and the $2400 screen arrives from the right and something similar happens vertically. Does the NES also has a Dlist? Or is it bound to 64 chars lines? No Dlist (you don't get much more than an interrupt when a Vblank occurs) but it takes care of the screen for you since there are only a couple of modes. Anything that's split screen is an evil bit of timing... =-) [isn't the NES screen a perfect wrap-around with exactly 32 chars wide? No, although if my memory serves it's possible to set the mirrors to work that way. It may even be the default for all i remember of the (sparse) docs i've found! =-) It seems to me it has a colorbug on the borders. Look at Mario 3 when scrolling. In the right border the color/palette-RAM is refreshed. That's because the tiles are 8*8 pixels but the colour attributes are 16*16 pixels and a 32*32 pixel area is represented by four bit pairs in one byte(!) so, unless you're quite careful and start working in bitpairs, that colour change over happens on visible screen - Parodius has the same at the far left for example. My own routine doesn't colour shifting yet because i'm still trying to get my head around a good way to deal with it, judging by how Journey to Silius and others look there are ways to handle it cleanly. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 2, 2003 Share Posted September 2, 2003 ok guys, here is the 1st code fragment.... it's more a riddle for you as i don't know why it distroys the displaylist and why the window is not scrolling fast... i divided the screen in 2 areas so actually scrolling area is 1st half of the screen (routine stops at scanline 96) in the 2nd half you can see how the collums are built... they are build out of random colors... the start collum number is based in the visible area of the screen just to see what is happening... i am tired now so i tried to find the logic error and the bugs but i failed...so it is more a riddle for you guys... speak to you tomorrow... hve/tqa * antic e "gba like" scroll wrapper * written by Heaven/TQA * * assembled with XASM / XBOOT * * heaven_tqa @ hotmail.com * 02/09/03 * known bugs the nasty '4k' boundary antic limitation causes gfx errors gractl equ 53277 graphp0 equ $d00d sizep0 equ 53256 hposp0 equ 53248 colbk0 equ $d01a hscrol equ $d404 dliv equ 512 dlistv equ 560 vbiv equ 546 nmien equ $d40e wsync equ $d40a si equ $b0 di equ $b2 dlist equ $5000 ;582 bytes dlist2 equ $5300 coltab equ $5800 ;pattern lookup table vram equ $6010 ;320x192x4 = 80x192 bytes = 15360 total org $4000 start jsr dlist_init jsr tab_init jsr wait_vbl * jsr fill_vram mva #0 559;switch off screen dma (screen off) mva #3 shscrol;default scroll position mwa #dlist dlistv;custom new display list mwa #vbl vbiv;custom VBL mva #$40 nmien;enable DLI + VBL mva #34 559;normal screen width loop jsr wait_vbl jsr scroll jmp loop vbl nop vbl_end jmp $e45f ;back into OS routine wait_vbl mva #1 540;will be decremented by OS every VBL wait0 lda 540 bne wait0 rts fill_vram mwa #vram di ldx #$3e ;15k to fill fill0 ldy #0 fill1 lda 53770 ;random number 0-255 sta (di),y+ bne fill1 inc di+1 ;next page dex bne fill0 rts * this routine fills the two collums fill_collum mwa #vram di ldx #192 ;192 scanlines to fill lda 53770 and #3 tay lda coltab,y;get color pattern sta fc0+1 ldy collum fc0 lda #0 sta (di),y lda di add #80 sta di bcc fc1 inc di+1 fc1 dex bne fc0 rts scroll dec shscrol beq scroll0 ;hardscroll? mva shscrol hscrol;softscroll rts scroll0 mva #4 shscrol mva #0 hscrol jsr fill_collum jsr move_window;move visible window inc collum lda collum cmp #80 ;reached the boundary? (80th collum) beq scroll1 ;reset dlist to the left boundary rts *copy back default dlist scroll1 ldx #0 mva #39 collum scroll2 lda dlist2,x sta dlist,x lda dlist2+256,x sta dlist+256,x+ bne scroll2 ;512 bytes scroll3 lda dlist2+512,x sta dlist+512,x+ cpx #72 ;+72 = 584 length of displaylist bcc scroll3 rts move_window mwa #dlist+4 movew+1 mwa #dlist+5 movew2+1 ldx #96 ;192 scanlines movew inc dlist+4 ;add +1 on each LMS adress beq movew0 movew2 inc dlist+5 movew0 lda movew+1 add #3 sta movew+1 bcc movew1 inc movew+2 movew1 lda movew2+1 add #3 sta movew2+1 bcc movew3 inc movew2+2 movew3 dex bne movew rts dlist_init mwa #vram di lda #$70 ;$70,$70,$70 jsr putline jsr putline jsr putline ldx #192 ;192 scanlines dlinit0 lda #$5e ;now generate the lms commands jsr putline lda di jsr putline lda di+1 jsr putline lda di add #80 ;80 bytes per scanline sta di bcc dlinit3 inc di+1 dlinit3 dex bne dlinit0 lda #$41 jsr putline lda #<dlist jsr putline lda #>dlist putline sta dlist sta dlist2 ;our copy of the default dlist inc putline+1 inc putline+4 beq putline2 rts putline2 inc putline+2 inc putline+5 rts tab_init ldx #0 tab0 txa and #3 tay lda patttab,y sta coltab,x+ bne tab0 rts shscrol dta b(3) patttab dta b(%00000000,%01010101,%10101010,%11111111) collum dta b(20) ;collum number [/code] demo1.zip Quote Link to comment Share on other sites More sharing options...
analmux Posted September 3, 2003 Share Posted September 3, 2003 Heaven, have you separated the display in 4kB blocks ? 4096/80 = 51.2 so max. 51 lines are showable, before getting into trouble. ----- mux Quote Link to comment Share on other sites More sharing options...
Sheddy Posted September 3, 2003 Share Posted September 3, 2003 Still don't get how it could work Mux - you'll have to show us mere mortals an example! OK - I'm beginning to get it....I think.... surely you still need LMS every line to avoid an ugly mess on the sides, rather than just a standard 40 byte screen, (one line straight after the other)? - or do we use widescreen so you don't see that? Waste some missiles to mask the sides? Or you have something more devious in mind, Mux So the 4K boundary problem crops up this way - but if you know which part of memory it's going to jump "incorrectly" to, you can have that place in memory prepared so it will look right. Way to go, Mux. Nice effort Heaven - but my brain is not in debug mode today though And those strange psuedo op codes you use in xasm confuse my poor little 6502 head when it is working Quote Link to comment Share on other sites More sharing options...
analmux Posted September 3, 2003 Share Posted September 3, 2003 surely you still need LMS every line to avoid an ugly mess on the sides? No, just the exceptional trouble lines. Let me make some demo pics soon, I've got a big load of homework now. Expect something tomorrow. It's not necessary to mask the sides. Just use a normal display, without any Missile tricks or something. ----- mux Quote Link to comment Share on other sites More sharing options...
Sheddy Posted September 3, 2003 Share Posted September 3, 2003 surely you still need LMS every line to avoid an ugly mess on the sides? No, just the exceptional trouble lines. Let me make some demo pics soon, I've got a big load of homework now. Expect something tomorrow. It's not necessary to mask the sides. Just use a normal display, without any Missile tricks or something. ----- mux Thanks - No need to rush Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 3, 2003 Share Posted September 3, 2003 sheddy... back from work (after being 2 hours in traffic jam...aaarg) so i can debug my nasty code on my own... maybe scanlines with length of 128 bytes could be an option... to make adressing stuff easier... i hope to track the errors tonight... hve/tqa Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 3, 2003 Share Posted September 3, 2003 for the confused guys here: mva will be assembled to (move value) lda sta mwa will be assembled to (move word) lda sta lda +1 sta +2 ,x+ ,y+ will be assembled to ,x inx ,y iny add will be assembled to clc adc so really no strange commands... i should show you numen source code with highly optimised XASM source (with all nasty tricks FOX can get out of XASM)... i bet you'll understand 5% as me... hve Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 3, 2003 Share Posted September 3, 2003 errors found... check the "move window" routine... the pseudo opcode might not generate the code i thought and mess up the display list. that's mainly the reason for getting messed up... next bug is putting the vram to $x010 and therefore causing 4k boundary display errors as mux pointed out...so i changed the scanline length to 128 bytes... and it seem to help a lot...still some weird pixels but now it's more visible how the whole stuff works... now imagine that the "color bars" are pure antic e gfx like mario background etc... and you got it... mux, can you give me kind of starting adress for the vram...to avoid these 4kblock restriction??? (i was never good at maths... ) hve/tqa demo1.zip Quote Link to comment Share on other sites More sharing options...
analmux Posted September 3, 2003 Share Posted September 3, 2003 Okay, here is the demopic: For simplicity consider a 3*3 charactermode display. The numbers in the grid denote the linenumber, as they are mapped in memory: 0 is mapped at f.e. $8000 1 is mapped at $8003 2 is mapped at $8006 3 is mapped at $8009 line 0 plays the role of the copy of line 3. When wrapping around, there is nothing beyond line 3, so it must have some connection to line 1, that's why line 0 is the same as line 3. You see in picture 1B how this works. Picture 1A is just a start configuration. When scrolling vertical, just move from pic 1A --> 2A --> 3A --> 1A and so on, with the lowest line not in sight to buffer new graphics on screen. When vertical buffering happens in line 0 or 3 then make a copy to line 3 or 0 respectively. When scrolling horizontal, just move from pic 1A --> 1B --> 1C --> 2A --> 2B ...... --> 3C --> 1A and so on. The LMS is only needed at the top of the screen, and a second LMS where line 0 has to be displayed. When a screen is bigger (that is: it contains more than 4 kB), you can apply the principle again. So for every screen that is smaller than size of n*4 kB, you'd need n extra/exceptional lines. And you can replace charmode to bitmapmode, with the usual 40byte-length I hope it's a bit clearer now. ----- mux Quote Link to comment Share on other sites More sharing options...
analmux Posted September 3, 2003 Share Posted September 3, 2003 Some additional notes: when the screen is actual in configuration 1B then in vertical scrolling you'd have to move from 1B --> 2B --> 3B --> 1B and over and over. Or just the other way around, when scrolling in a different direction. The main thing to worry about is the computing of the buffer-addresses, for hor/vert update of screendata. When you write somewhere in line 3 then you must write to line 0 (with the same offset) at the same time. The horizontal buffer is still a column at the most right of the display. I'll make some ASM-proc soon to show this in Antic 4. It will be the screenmanager for my mariogame (I just found out this method last weekend, so it's even not totally clear for me ) You see, there is never a time you need to copy the whole screen. Just (parts of) a line in vertical scrolling. You'd also only need one extra line of memory (40 extra bytes per 4kB Block you're using for the screen). The minimum amount of LMSs is an advantage too, because in f.e. Heaven's routine you still need to update 100 or 200 bytes in the DL every 4th pixel. @ Heaven. Do you want to make the scrolling full-screen? Then why not keep a 80byte wide display? As I wrote before, 4096/80 = approx. 51, so 192 lines would need 4 parts. Just let every part of 51 lines start at the first address of a 4k block. So: First part: line 0: $8000 line 1: $8050 line 2: $80A0 line 3: ..... ..... line 50: $8FA0 Second part: line 51: $9000 line 52: $9050 ..... ..... etcetera. ----- mux Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 4, 2003 Share Posted September 4, 2003 @mux... why are complicated things sometimes simple? i am scrolling horizontal and steve wanted to have an antic e wrapper... that's the reason why i am dealing with highres... antic e would be more ideal imho as you have to deal with less data.... i will split tonight the copy routines in 4 chunks to avoid the 4k limitation as you mentioned (every 51th scanline). unfortunatly i seem to need 192 LMS commands or is there a way to avoid that? but i do not know how you will then work with 80 bytes scanlines... if everything works smooth then we can talk about optimasations like - putting copy routines into zeropage - using 256 byte length scanlines ($c000 vram!). easier for sprite copy routine and you can have 4 screens for double buffering on the same line: vram1 (0-79) vram2 (80-119) vram3 (120,159) vram4 (160,199) - scheduling the work more proper for less CPU usage per frame: 4 frames will be scrolled per hardware scrolling...so 4 full frames are free to build the next "stripes". so the "copy_collum" can be divided into 4 portions... or we even scroll full 16 pixel with hardware to gain more... hve Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 4, 2003 Share Posted September 4, 2003 of cours i ment "antic 4" to deal with less data... btw... strange... look on your keyboard...the "e" is below the "4"... did jay miner had this in mind when designing the modes??? hve ps... now back to work on the highway... Quote Link to comment Share on other sites More sharing options...
ndary Posted September 4, 2003 Share Posted September 4, 2003 Haven, have you notice that your scroll routine jitters in NTSC computers?.. i just wonder if there is a way to find a unique scrolling timing that will work on both NTSC & PAL computers.. 1 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 4, 2003 Share Posted September 4, 2003 i guess the scrolling isnt smooth as the softscroll routine is not perfect (again ages when done the last one... ) and mainly right now taking too much time so it's not in sync with VBL... (that's why i haven'T put the scroller into "real" vbl...) and i haven't tried it out on real hardware just in emulator... hve Quote Link to comment Share on other sites More sharing options...
analmux Posted September 4, 2003 Share Posted September 4, 2003 unfortunatly i seem to need 192 LMS commands or is there a way to avoid that? but i do not know how you will then work with 80 bytes scanlines... You can't avoid it. Only if you make 40bytes scanlines, like my scroller will allow for. By the way .. sounds great about an antic4 display with 256 byte rows, but isn't that overkill?? The more bytes you're using, the slower things get. By the way 2. I played Feud last night, and indeed doesn't scroll at all. It even has a miserable animation rate of 15 frames/sec. or something , AND the worst part: it isn't full screen (like I seem to remember). ----- mux Quote Link to comment Share on other sites More sharing options...
analmux Posted September 4, 2003 Share Posted September 4, 2003 Great idea to move copy routines to zeropage. Then you won't need indirect postindexed addressing anymore. ----- mux Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 4, 2003 Share Posted September 4, 2003 i am sure that dealing with 256 bytes long scanlines gain more speed due to less calculations... think on copy sprite data f.e. which you will do in general a lot in a game... and the "overhead shadow bytes" in each scanline can be used for tables, variables, etc... so it's just another kind of organisation of RAM... and if you use the PRO loader of XBOOT than you have a lot of RAM as the OS is switched of... ok... might be an overkill but maybe you don't need 192 scanlines maybe just 128 for your shooter... but if you are using antic 4 (for your mario...) then i would even try to go for 256 bytes scanlines as you might gain cycles because of the clever moving/positioning routines... vram[xpos+ypos*256] which is ideal... isn't it? hve ps. and 256 bytes scanlines is standard on the 7800... Quote Link to comment Share on other sites More sharing options...
