Compile 4k+4k
Cisano
Hi. My game needs 8k.
I use Visual Studio.
Bank 0
    org  $1000
    rorg $1000
;code
    org  $1FFA
    rorg $FFFA
Bank 1
    org  $2000
    rorg $1000
;code
    org  $2FFA
    rorg $FFFA
I know how to swtch the banks, thank to 8bitworkshop.
My question.
The code must be in the same file? Because I have "Failed to create compiled file" error. No other help about the reason.
Thanks.
It might just be a typo, but org (binary file origin) should start counting from $0000, not $1000.  Also rorg (relocated "code" origin) should be within a 4k region ($1000 .. $1FFF, or $F000..$FFFA) for the start and end of each of your banks. Fixed in the following:
Bank 0
    org  $0000
    rorg $1000
;code
    org  $0FFA
    rorg $1FFA
Bank 1
    org  $1000
    rorg $1000
;code
    org  $1FFA
    rorg $1FFA
I just tried this and it worked:
;---- 8k DASM example
    processor 6502
;-- Bank 0
    org  $0000
    rorg $1000
    lda $1ff8
boot:
    ;put code here
    org  $0FFA
    rorg $1FFA
    word 0
    word boot
    word boot
;-- Bank 1
    org  $1000
    rorg $1000
goto_boot:
    lda $1ff8   ;-- switch back to bank 0 and continue execution at "boot"
    ;put code here
    org  $1FFA
    rorg $1FFA
    word 0
    word goto_boot
    word goto_boot
One last thing. From 8bitworkshop:
MAC BANK_SWITCH
.Bank	SET {1}
.Addr	SET {2}
lda #>(.Addr-1)
ldy #<(.Addr-1)
ldx #.Bank
jmp BankSwitch
ENDM
Having 2 label with the same name in the 2 banks "BankSwitch", I get "Label mismatch" error.
How to fix it?
You use:
lda $1ff8
Is it enough to use lda instruction for the switch?
Thanks for every info.
Yes, reading/writing to 1FF8 (for bank 0) or 1FF9 (for bank 1) will switch banks in the 8k/F8 bank-switching scheme.  But, you need to be careful because the bank-switching happens immediately.
The code in 8bitworkshop is quite complex.  I don't really have any experience with using techniques like that.   In PaintTheCity, I use a much simpler technique which involves defining a jump table at the beginning of each bank.  (ChaoticGrill also uses a similar jump-table technique)
Here is an example of the jump-table bank-switching technique.  This example shows a layout where Display code and Graphics data would be located in bank 0, and game logic would be located in bank 1.
F8_banking_example.asm
I've taken the decision to use the code in F8 banking example.
It works and from Bank1 pressing the fire button it goes in the Bank0 and the game starts.
I have this problem now. The Bank0 has free memory.
If I write some instuctions (it doesn't matter which) I get, just started, "invalid instruction" by Stella.
If I delete one and check, one and check, etc ... it begins to work again.
The funny thing is, that code is not executed.
