Global Constants
Cisano
I have this (a small part) in my code in the Bank 0
FreqFtgrGrp0
	.byte #5
ColorWall
	.byte #$f4
ColorWater
	.byte #$94
Now, in the Bank 1 I have some code uses these variables.
I don't want to re-define in the Bank 1, because I must change the name.
How can I use them in the Bank 1?
Have a master file that includes all the other files.
e.g., "main.asm" includes "zeropage.asm" and "BANK1.asm" etc.
when you assemble, you assemble "main.asm".
The vars and constants get defined, wherever, somewhere in that (or included files)... and when your banks come around, those symbols are already defined. In fact dasm doesn't need stuff to be defined before use; the assembler does multiple passes.
Does this help?
edit: I guess I misunderstood the Q!
Edited by Andrew Davie
FreqFtgrGrp0
	.byte #5
ColorWall
	.byte #$f4
ColorWater
	.byte #$94
Those are not variables or constants.  Those are tables.  Three one-byte tables.  As was said, just define them as labels.
There are legitimate reasons for having equivalent tables in multiple banks with different contents though, even though it turned out that this was not what the OP needed.
If that was the case though, you'd just need to make sure that the tables started at the same addresses in every bank, and that all the lengths matched. Only one set of tables would need labels. For the others, you could optionally write code to have the assembler validate their positions (i.e. compare the PC at the position where the label would be to the label of the original table and stop assembly in case of a mismatch).
To build upon @splendidnut's example, if you define color constants you can easily switch between NTSC and PAL builds:
NTSC    = 0
PAL     = 1
PAL60   = 2
COMPILE_VERSION = NTSC
BLACK           = $00
WHITE           = $0E
 IF COMPILE_VERSION = NTSC
GREY            = $00
YELLOW          = $10
ORANGE          = $20
RED_ORANGE      = $30
RED             = $40
PURPLE          = $50
VIOLET          = $60
INDIGO          = $70
BLUE            = $80
BLUE2           = $90
TURQUOISE       = $A0
CYAN            = $B0
GREEN           = $C0
YELLOW_GREEN    = $D0
OCHRE_GREEN     = $E0
OCHRE           = $F0
 ELSE
GREY            = $00
YELLOW          = $20   ; no real equivalent
ORANGE          = $20
RED_ORANGE      = $40
RED             = $60
PURPLE          = $80
VIOLET          = $A0
INDIGO          = $C0
BLUE            = $D0
BLUE2           = $B0
TURQUOISE       = $90
CYAN            = $70
GREEN           = $50
YELLOW_GREEN    = $30
OCHRE_GREEN     = $30   ; no real equivalent
OCHRE           = $20   ; no real equivalent
 ENDIF
Then use those constants in your code like this:
  lda #GREEN+4
  sta COLUP0
  lda #VIOLET+8
  sta COLUP1
The +4 and +8 set the LUMA value.
  lda #GREEN+4
  sta COLUP0
  lda #VIOLET+8
  sta COLUP1
You might also use constants for the LUMA :
DARKEST      = $0
DARKER       = $2
DARK         = $4
LIGHT        = $6
LIGHTER      = $8
BRIGHT       = $A
BRIGHTER     = $C
BRIGHTEST    = $E
	lda #DARKEST+GREEN
  • 4 weeks later...
