rfunes Posted February 19, 2022 Share Posted February 19, 2022 I have two sample codes that show a simple sprite moving on a playfield with 4 openings (top, down, left, right), which are to simulate doors (like on Beserk) By using "set romsize 8k", not using Superchip, the sprite is able to move past the top and down doors as expected. By using "set romsize 8kSC", using Superchip, the sprite collides with "something" on the top, and some random crap playfield lines on the bottom (the crap lines change on each reset). Removing "set kernel_options no_blank_lines" does make the random playfield lines on the last row to disappear, but the sprite still collides with something and refuses to move past the bottom and top doors. Do you know what could be going on? Thanks ! ; Remove the comment below to not use Superchip, and everything works as expected ; set romsize 8k ; When using Superchip, there are some random crap on the last row and the sprite collides with something on the top and bottom doors set romsize 8kSC ; Removing this line hides the crap playfield lines on the bottom, but the sprite still collides with "something" set kernel_options no_blank_lines player0x = 50 : player0y = 50 player0: %11111111 %10000001 %10000001 %10000001 %10000001 %10000001 %10000001 %11111111 end COLUBK = $00 : COLUPF = $46 playfield: XXXXXXXXXXXXX.....XXXXXXXXXXXXXX XX............................XX X..............................X XX............................XX ................................ ................................ ................................ XX............................XX X..............................X XX............................XX XXXXXXXXXXXXX.....XXXXXXXXXXXXXX end ; Go to main loop on bank 2 goto __main bank2 bank 2 ;-------------------------------------------------- ; Main loop ;-------------------------------------------------- __main COLUP0 = $0E gosub __move_player drawscreen goto __main ;-------------------------------------------------- ; Moves and check playfield collisions for player0 ;-------------------------------------------------- __move_player if !joy0up then goto __skip_up temp6 = (player0x-10)/4 temp5 = (player0y-9)/8 if temp6 < 34 then if pfread(temp6,temp5) then goto __skip_up temp4 = (player0x-17)/4 if temp4 < 34 then if pfread(temp4,temp5) then goto __skip_up temp3 = temp6 - 1 if temp3 < 34 then if pfread(temp3,temp5) then goto __skip_up player0y = player0y - 1 __skip_up if !joy0down then goto __skip_down temp6 = (player0x-10)/4 temp5 = (player0y)/8 if temp6 < 34 then if pfread(temp6,temp5) then goto __skip_down temp4 = (player0x-17)/4 if temp4 < 34 then if pfread(temp4,temp5) then goto __skip_down temp3 = temp6 - 1 if temp3 < 34 then if pfread(temp3,temp5) then goto __skip_down player0y = player0y + 1 __skip_down if !joy0left then goto __skip_left temp6 = (player0x-18)/4 temp5 = (player0y-1)/8 if temp6 < 34 then if pfread(temp6,temp5) then goto __skip_left temp4 = (player0y-8)/8 if temp6 < 34 then if pfread(temp6,temp4) then goto __skip_left player0x = player0x - 1 __skip_left if !joy0right then goto __skip_right temp6 = (player0x-9)/4 temp5 = (player0y-1)/8 if temp6 < 34 then if pfread(temp6,temp5) then goto __skip_right temp4 = (player0y-8)/8 if temp6 < 34 then if pfread(temp6,temp4) then goto __skip_right player0x = player0x + 1 __skip_right return thisbank Quote Link to comment Share on other sites More sharing options...
KevKelley Posted February 19, 2022 Share Posted February 19, 2022 With SuperChip, don't you have to define the playfield resolution? Or is that just optional should you choose to go with something other than the standard kernel? Quote Link to comment Share on other sites More sharing options...
rfunes Posted February 19, 2022 Author Share Posted February 19, 2022 (edited) 2 hours ago, KevKelley said: With SuperChip, don't you have to define the playfield resolution? Or is that just optional should you choose to go with something other than the standard kernel? The documentation seems to say that if using the standard 12 rows height, pfres is optional. Either way, I tested with "const pfres=12" added to the example above, and the same behavior is still happening. Edited February 19, 2022 by rfunes Typo Quote Link to comment Share on other sites More sharing options...
rfunes Posted February 19, 2022 Author Share Posted February 19, 2022 (edited) Just to give a feedback, I was able to "fix" the two issues. For the random lines, I only fixed the symptoms, but was not able to find the cause. When using Superchip with no_blank_lines enabled, these random lines will appear below the last row. The way to remove the random lines that appear below the 11th row of the playfield is to define the 12th row of the playfield, as empty ("................................"). I still do not understand why these random lines appear only when using the Superchip with no_blank_lines enabled, and why this does not happen when not using Superchip. playfield: XXXXXXXXXXXXX.....XXXXXXXXXXXXXX XX............................XX X..............................X XX............................XX ................................ ................................ ................................ XX............................XX X..............................X XX............................XX XXXXXXXXXXXXX.....XXXXXXXXXXXXXX ................................ end The fix for the movement was to add an exception to the up and down movement code, to bypass the playfield vs player collision check using pfread. I checked the values of the temp5 variable for the up and down movement code, and noticed that when it goes below 0, it wraps around to 31, and when over the last row, it goes over 11. So I added code to check for when temp5 is greater than 10, and when so to bypass the playfield collision checking. I think this issue happened because pfread was being fed Y coordinates over 11. __move_player if !joy0up then goto __skip_up temp6 = (player0x-10)/4 temp5 = (player0y-9)/8 if temp5 > 10 then goto __move_up ; THIS FIXED THE ISSUE if temp6 < 34 then if pfread(temp6,temp5) then goto __skip_up temp4 = (player0x-17)/4 if temp4 < 34 then if pfread(temp4,temp5) then goto __skip_up temp3 = temp6 - 1 if temp3 < 34 then if pfread(temp3,temp5) then goto __skip_up __move_up player0y = player0y - 1 __skip_up if !joy0down then goto __skip_down temp6 = (player0x-10)/4 temp5 = (player0y)/8 if temp5 > 10 then goto __move_down ; THIS FIXED THE ISSUE if temp6 < 34 then if pfread(temp6,temp5) then goto __skip_down temp4 = (player0x-17)/4 if temp4 < 34 then if pfread(temp4,temp5) then goto __skip_down temp3 = temp6 - 1 if temp3 < 34 then if pfread(temp3,temp5) then goto __skip_down __move_down player0y = player0y + 1 __skip_down if !joy0left then goto __skip_left temp6 = (player0x-18)/4 temp5 = (player0y-1)/8 if temp6 < 34 then if pfread(temp6,temp5) then goto __skip_left temp4 = (player0y-8)/8 if temp6 < 34 then if pfread(temp6,temp4) then goto __skip_left player0x = player0x - 1 __skip_left if !joy0right then goto __skip_right temp6 = (player0x-9)/4 temp5 = (player0y-1)/8 if temp6 < 34 then if pfread(temp6,temp5) then goto __skip_right temp4 = (player0y-8)/8 if temp6 < 34 then if pfread(temp6,temp4) then goto __skip_right player0x = player0x + 1 __skip_right return thisbank Edited February 19, 2022 by rfunes 1 Quote Link to comment Share on other sites More sharing options...
