Kjmann Posted March 2, 2022 Share Posted March 2, 2022 the company, LEVELHIKE has a Playstation rgb to hdmi adapter that is very easily converted to the Amiga. here is a instruction pdf that I made for doing it. it works very well. I play Battle Squadron on a regular basis and don't notice any lag to speak of. hope some people can find this useful. the color of the sync line and ground line seems to vary depending on the version of the adapter. the current version seems to be yellow for sync and brown for ground. the new version of the adapter also has a couple of new features. 1, the chips now have heatsinks. 2, the adapter now goes to sleep if no signal for two minutes (flip the aspect ratio switch to wake it back up). Here's a link to the adapter on Amazon. HDMI Cable for Playstation https://www.amazon.com/dp/B07MYVF61Y/ref=cm_sw_r_apan_glt_i_V6KV839M5JJV8MH19MM8?_encoding=UTF8&psc=1 Amiga HDMI.pdf 1 Quote Link to comment Share on other sites More sharing options...
amiman99 Posted March 3, 2022 Share Posted March 3, 2022 Do you have some Workbench/Games screenshots you can share? thanks Quote Link to comment Share on other sites More sharing options...
Kjmann Posted March 4, 2022 Author Share Posted March 4, 2022 (edited) these videos are only in 480p at 30fps. but hopefully it gives you an idea..... the actual adapter outputs at 720p. Edited March 4, 2022 by Kjmann added info.... Quote Link to comment Share on other sites More sharing options...
amiman99 Posted March 4, 2022 Share Posted March 4, 2022 Thanks Quote Link to comment Share on other sites More sharing options...
Kjmann Posted March 4, 2022 Author Share Posted March 4, 2022 23 minutes ago, amiman99 said: Thanks no problem. ? another cool thing is that the adapter will resize a pal screen to fit the TV. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted November 27, 2023 Share Posted November 27, 2023 (edited) On 3/2/2022 at 1:05 PM, Kjmann said: the company, LEVELHIKE has a Playstation rgb to hdmi adapter that is very easily converted to the Amiga. here is a instruction pdf that I made for doing it. it works very well. I play Battle Squadron on a regular basis and don't notice any lag to speak of. hope some people can find this useful. the color of the sync line and ground line seems to vary depending on the version of the adapter. the current version seems to be yellow for sync and brown for ground. the new version of the adapter also has a couple of new features. 1, the chips now have heatsinks. 2, the adapter now goes to sleep if no signal for two minutes (flip the aspect ratio switch to wake it back up). Here's a link to the adapter on Amazon. HDMI Cable for Playstation https://www.amazon.com/dp/B07MYVF61Y/ref=cm_sw_r_apan_glt_i_V6KV839M5JJV8MH19MM8?_encoding=UTF8&psc=1 Amiga HDMI.pdf 11.13 MB · 98 downloads Nice. so, mine is hooked up as: RED -> RED GREEN -> GREEN BLUE -> BLUE YELLOW -> CSYNC BROWN -> GROUND ORANGE AND WHITE -> AUDIO But what are the gray, purple and black wires signals? Edited November 27, 2023 by Shift838 Quote Link to comment Share on other sites More sharing options...
RobertB Posted November 27, 2023 Share Posted November 27, 2023 Sounds like a good solution! Truly, Robert Bernardo Fresno Commodore User Group - http://www.dickestel.com/fcug.htm Southern California Commodore & Amiga Network - http://www.portcommodore.com/sccan Quote Link to comment Share on other sites More sharing options...
