Calab Posted March 8, 2022 Share Posted March 8, 2022 (edited) Does anyone know the directions that the signals travel on the ACSI port of the Atari ST? Atari ----- Drive Use 1 <---> 1 D0 2 <---> 2 D1 3 <---> 3 D2 4 <---> 4 D3 5 <---> 5 D4 6 <---> 6 D5 7 <---> 7 D6 8 <---> 8 D7 9 ?---? 9 HDCS 10 ?---? 10 XHDINT 11 ----- 11 GND 12 ----> 12 RESET 13 ----- 13 GND 14 ?---? 14 ACK 15 ----- 15 GND 16 ?---? 16 A0 17 ----- 17 GND 18 ?---? 18 RW 19 ----- 19 GND Edited March 8, 2022 by Calab Quote Link to comment Share on other sites More sharing options...
ijor Posted March 8, 2022 Share Posted March 8, 2022 (edited) Have you check the official Atari docs? They are pretty clear in this regard and there is even a diagram with arrows: https://docs.dev-docs.org/htm/search.php?find=ACSI Edited March 8, 2022 by ijor Quote Link to comment Share on other sites More sharing options...
Calab Posted March 8, 2022 Author Share Posted March 8, 2022 46 minutes ago, ijor said: Have you check the official Atari docs? They are pretty clear in this regard and there is even a diagram with arrows: https://docs.dev-docs.org/htm/search.php?find=ACSI Perfect! Thank you! I had no luck finding that information. Atari ----- Drive Use 1 <---> 1 D0 2 <---> 2 D1 3 <---> 3 D2 4 <---> 4 D3 5 <---> 5 D4 6 <---> 6 D5 7 <---> 7 D6 8 <---> 8 D7 9 ----> 9 _CS 10 <---- 10 _IRQ 11 ----- 11 GND 12 ----> 12 _RESET 13 ----- 13 GND 14 ----> 14 _ACK 15 ----- 15 GND 16 ----> 16 A1 17 ----- 17 GND 18 ----> 18 R/_W 19 <---- 19 _DRQ Quote Link to comment Share on other sites More sharing options...
Chri O. Posted March 8, 2022 Share Posted March 8, 2022 This may help also as I have the ACSI hard drive Emulator for Teensy 4.1 MCU up and running. // **** // **** // **** // ****** // ** ** ** // ** ** ** // ** ** ** // A t a r i ST ACSI hard drive Emulator // for Teensy 4.1 MCU, 2021-2022 by Chris O. // Based on Jean-Matthieu Coulon ACSI2STM ver.1.0 https://github.com/retro16/acsi2stm // 19 pin D-SUB male connector at the cable. // --------------------------------- // \ 01 02 03 04 05 06 07 08 09 10 / // \ 11 12 13 14 15 16 17 18 19 / // --------------------------- // T4.1 bit pin //01 <-> GPIO6-16 19/A5 AD_B1_00 Data BIDIR Teensy Data BUS 0-7 INPUT & OUTPUT //02 <-> GPIO6-17 18/A4 AD_B1_01 //03 <-> GPIO6-18 14/A0 AD_B1_02 //04 <-> GPIO6-19 15/A1 AD_B1_03 //05 <-> GPIO6-20 40/A16 AD_B1_04 //06 <-> GPIO6-21 41/A17 AD_B1_05 //07 <-> GPIO6-22 17/A3 AD_B1_06 //08 <-> GPIO6-23 16/A2 AD_B1_07 Data BIDIR Teensy Data BUS 0-7 INPUT & OUTPUT // //09 --> GPIO6-25 23/A9 AD_B1_09 _CS Chip Select Teensy INPUT ONLY //10 <-- GPIO7-28 35 B1_12 _IRQ Interrupt Teensy OUTPUT_OPENDRAIN, (1K pullup to 5V on ATARI - Device OPEN collector output) USE SN74LS07 Hex Buffers With Open-Collector //11 --- GND GND GND Ground //12 --> GPIO7-19 37 B1_03 Reset Teensy INPUT ONLY / Reset T4.1 37 //13 --- GND GND GND Ground //14 --> GPIO7-18 36 B1_02 ACK Teensy INPUT ONLY //15 --- GND GND GND Ground //16 --> GPIO6-24 22/A8 AD_B1_08 A1_st Address bit Teensy INPUT ONLY //17 --- GND GND GND Ground //18 --> GPIO9? 33 EMC_07 R/W Read/Write Teensy INPUT ONLY //19 <-- GPIO7-29 34 B1_13 _DRQ Data request Teensy OUTPUT_OPENDRAIN, (1K pullup to 5V on ATARI - Device OPEN collector output) USE SN74LS07 Quote Link to comment Share on other sites More sharing options...
