Sonaru Posted March 9, 2022 Share Posted March 9, 2022 How does the Super Action Controller compare to the standard Colecovision controller in ergonomics and responsiveness? I'm looking for a new controller because my only Coleco Controller has a broken up contact button so the up button no longer works. And the left trigger doesn't work even after I clean it. So I'm looking for a more reliable and comfortable controller but I'm not sure how the S.A.C. holds up. Thanks everyone. Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted March 10, 2022 Share Posted March 10, 2022 I like the design of the super action controller, with the longer stick and ball handle joystick. The buttons are a bit easier to use, plus, of course, for games that require the extra buttons. Note that whenever I get another one (it's been a long time since the last one), they seem to often need to be taken apart and the contacts cleaned. It's kind of awkward to do, and you have to be careful not to pry anything apart until you understand how it's put together, so it takes a little research and a bit of time to do. However, once I did that to mine, they have worked fine for years. I do still use a regular Coleco joystick that was modified to have a ball-style joystick and straightened cord because it's lighter and more convenient to hold for some games. 1 Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted March 10, 2022 Share Posted March 10, 2022 I never liked the Super Action Controller. It seems ergonomic visually, but it quickly becomes uncomfortable after using it for a while. This is because when you move the joystick (especially left or right) you have to tighten the handle with more force to keep the joystick straight and steady, and since you want to avoid pressing the colored fire buttons when you don't want to, you have no choice but to apply this extra squeeze with the side of your thumb and the joint point between the index and the palm of your hand. Do this long enough and your hand will get sore. The handle cover (which makes the handle thicker) helps a little, but not enough in my opinion. The design of the controller is simply flawed. 3 Quote Link to comment Share on other sites More sharing options...
+GoldLeader Posted March 10, 2022 Share Posted March 10, 2022 In a way it's a bit of a loaded question because anything is better, it seems than a standard Coleco Controller, though I loved mine in 1982, when evidently my hands were made of steel or something. I do like the SAC from time to time, but if you get a modded NES, SNES, or Genesis type pad or go absolutely First Class and just get an Edladdin you probably won't use a standard Coleco or SAC very often. 3 Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted March 22, 2022 Share Posted March 22, 2022 On 3/9/2022 at 9:24 PM, GoldLeader said: I just ordered one of these. 2 Quote Link to comment Share on other sites More sharing options...
Ruggers Customs Posted March 23, 2022 Share Posted March 23, 2022 4 hours ago, sramirez2008 said: I just ordered one of these. You won't be disappointed. I got one from Ed back in 2017 and it gets regular use. Still going strong to this day but now it's in the living room instead of my game room. It got confiscated by the family. lol 2 Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted March 23, 2022 Share Posted March 23, 2022 I have his Super Twin 78 and Supreme 78: All-Play 4/8 way joysticks. Looking forward to receiving this one. Quote Link to comment Share on other sites More sharing options...
