jschultzpedersen Posted March 11, 2022 Share Posted March 11, 2022 Hi As a newbie - or rather a returning fan after nearly 40 years af absence - I am trying to convert an Extended Basic program for use with a FinalGrom device. The basic program has been processed to a compiled program in the Classic99 environment via ISABELLA and an EA5 type file generated for use with the Module Creator 2.0 to make an image. The file called SB52-E is in vt99 format. However, when I try to use the Module Creator program, i always get an 'Expanded line too long' error. See included screen pic. I have tried to locate the file in the root of a drive in case the path was too long, as someone suggested in a similar case mentioned on AtartAge. Any Basic program compiled and converted to vt99 that I test has this behaviour. A lot of people can make this work, so please help me to become a member of happy users of the Module Creator 2.0. regards jesper Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted March 11, 2022 Share Posted March 11, 2022 In what directory have you placed Module Creator 2.0 ? In the line that gives the error the assembler is called with an input, output and error file. So that line would be expanded to something like this: c:\wherever module creator is\xa99.exe -iC:\users\desktop\ti99 compiler\classic99\mydisk\dsk4\mm.a99 -oC:\users\desktop\ti99 compiler\classic99\mydisk\dsk4\mm.obj -lC:\users\desktop\ti99 compiler\classic99\mydisk\dsk4\mm.lst -v -r -S -s This line is about 267 characters long. Most buffers in this tool are 255 characters. What I always do/have is the directory with the Module Creator, in my case: d:\Ti994w\ModuleCreator_20\ There I create an directory for the module project, like d:\Ti994w\ModuleCreator_20\mm and in that directory I copy the program file of what I would like to create a module of, like so: d:\Ti994w\ModuleCreator_20\mm\sb52-x I am also not sure of this whole module build process like spaces in the directory and/or file names as used here "ti99 compiler". 1 Quote Link to comment Share on other sites More sharing options...
jschultzpedersen Posted March 12, 2022 Author Share Posted March 12, 2022 Hi Spot on! I relocated the Module_Creator_20 directory as c:\Module_Creator_20 and made a directory below (called c:\Module_Creator_20\e-files) for my program files. Then I could produce a .bin file with 1-4 basic programs on the menu as desired. I also tested having the program files on a D drive directory with a similar short path. That worked too. With your Module Creator 2.0 tool, and using a combination of Classic99, Ti99dir, the ISABELLA package with its compiler options, and with TiCodEd as a much improved environment for editing EXTENDED BASIC code, it seem there is a nearly perfect environment for developing programs, get them compiled and put on a format, that is optimal for the actual TI99 hardware if you have a FinalGrom cartridge. Thanks a lot for your help! Jesper 2 Quote Link to comment Share on other sites More sharing options...
