Pinball freak Posted April 12, 2022 Author Share Posted April 12, 2022 (edited) 5 hours ago, shoestring said: Happy days. So if there is a broken leg on one of the custom chips then you can solder another leg from a donor chip if it has enough metal exposed. Some people use a dremel to expose more of it if its snapped at the base of the chip. http://www.ukvac.com/forum/missing-chip-pin-tips_topic350953.html Thanks, but luckily the CIA sat in 2 other ic sockets wich had a switch so 2 pins were soldered from one socket to switch and also on the next socket, so if you switch it probably made the external drive as first boot drive. I guess.. Because when i bought it, it had a external drive. So the pin broke off from the last ic socket. Also the drive does not fit firmly in the amiga case so that is probably the reason i guess, in that time there were no goteks. But i am going to fix that. Other question, what is the best way to remove the rusty corrosion on the metal plates in the amiga, because it was on a dry place but it also was not airtight all these years, so humidity had it chanche to do it's work. I do not want to use steelwool. The guy wich i bought the other one from uses baking soda... I even want to try elektrolysis, because i have a lab psu. Edited April 12, 2022 by Pinball freak Quote Link to comment Share on other sites More sharing options...
shoestring Posted April 12, 2022 Share Posted April 12, 2022 Baking soda will work. The important thing is to paint them after cleaning or they start rusting pretty much straight away. I used PCB lacquer after wet sanding the metal plate of the a1200 keyboard. But there are better ways. https://retrohax.net/extreme-refurbishing-episode-4-vampiric-amiga-500/ Quote Link to comment Share on other sites More sharing options...
