GPUOBJECT w/o interrupt enabling
42bs
From what I see, the interrupt is not latched.
I have a GPUOBJECT at the end of the screen (by using BRANCH objects) and clear the latch before releasing the OP. But the bit does not get set.
I will try other interrupts.
Yes, I did hope to get rid of the 68k. I made an intro where I just check the bitmap address to know when it is done, but this does not work for reloading the OP list.
But a least it avoids flickering when I clear the screen for the next frame.
But I have an idea to use the interrupt without spending to much space.
Edited by 42bs
This is how I build a list to handle the GPUOBJECT
It only interrupts the GPU once per frame at the end of the display (VDE)
I run this with the 68k shut off.
p1..p8 addresses are phrases in memory
p1  --------
p2  -------- GPU Int Obj
p3  -------- STOP Obj
p4  -------- Br = VDE (to GPU Int)
p5  -------- Br < VDB (to Stop)
p6  -------- Br > VDE (to Stop)
p7  -------- Normal Bitmap (to Stop)
p8  --------
OP points to p4
It looks shifted down by a phrase,
this is so the bitmap object is on a double phrase alignment.
Branches can fall through to next phrase if branch not taken.
Edited by JagMod
Nice idea to jump 'backwards'. ;-) Nowhere is written that link needs always go forward.
But for the intro I run out of memory, so I did
P0 bitmap
P2 branch VC < vde => P4
P3 GPU object
P4 stop
Since the OP stops on the GPU object, there is only one interrupt.
