macsonny Posted May 11, 2022 Author Share Posted May 11, 2022 (edited) 4 hours ago, macsonny said: I can confirm that after installing in a WST drive that it 100% works - so it's a difference between the Tandon and WST drives. I take that back. First WST drive I have is a bit touch-and-go and not a reliable unit so I took the display out of that and placed into a second WST drive I had. The issue of constantly flickering between track 01 and track 00 started again. I wonder if it has something to do with the ROMs on the drive rather than the brand/model? I was thinking about swapping the ROMs over from the flakey WST drive to the known good drive and then testing the track read out. What do people think? Edited May 11, 2022 by macsonny Quote Link to comment Share on other sites More sharing options...
macsonny Posted May 11, 2022 Author Share Posted May 11, 2022 1 hour ago, macsonny said: I take that back. First WST drive I have is a bit touch-and-go and not a reliable unit so I took the display out of that and placed into a second WST drive I had. The issue of constantly flickering between track 01 and track 00 started again. I wonder if it has something to do with the ROMs on the drive rather than the brand/model? I was thinking about swapping the ROMs over from the flakey WST drive to the known good drive and then testing the track read out. What do people think? Sigh. After yet more testing, I found that my drive that I thought was a little sus is actually fine. It's just when the track display module is installed that it has issues reading floppies. Any ideas why the display might be interfering with the drive? Note that I'm taking 5VDC to power my device from the 1050 motherboard (TP13 or 15 from emory). Might that be the issue? Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted May 11, 2022 Share Posted May 11, 2022 just a guess but are you using current limiting resistors on the input lines? if so, maybe try another rating? Quote Link to comment Share on other sites More sharing options...
macsonny Posted May 11, 2022 Author Share Posted May 11, 2022 14 minutes ago, xrbrevin said: just a guess but are you using current limiting resistors on the input lines? if so, maybe try another rating? I use the 15k and 27k to get the voltage divider per original design. Do you think I need to reduce these to a 3.3k and a 6.8k maybe? Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 11, 2022 Share Posted May 11, 2022 (edited) Normally Teensy is powered by your PC or USB hub, through a USB cable. The USB power arrives at the VUSB pin, which is connected VIN and powers the entire board. When USB power is not used, 5V power may be applied to the VIN pin. Because VIN & VUSB are connected, power should not be applied to VIN while a USB cable is used, to prevent the possibility of power flowing back into your computer. Alternately, a pair of pads on the bottom side may be cut apart, to separate VUSB from VIN Edited May 11, 2022 by Chri O. Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 12, 2022 Share Posted May 12, 2022 I've got another Atari 1050 Floppy Disk drive coming in from eBay on friday may 13. Untested, Powers on, May not work. Hopefully it's the other type so I can do some more testing. Quote Link to comment Share on other sites More sharing options...
macsonny Posted May 12, 2022 Author Share Posted May 12, 2022 (edited) On 5/5/2022 at 1:39 AM, Chri O. said: All pins on teensy 4.0 are interrupt capable. Two (NS02 & NS04) edge-triggered interrupt on RISING edge (low to high) while inside the interrupt I read the digital voltage on pin NS01 or NS03 respectively. void IRQ_NS02() { if (digitalReadFast(interruptPin_NS01) == HIGH) { Tcount ++; } else { Tcount --; } //Serial.print("T NS02 :"); // debug print //Serial.println(Tcount); // debug print } void IRQ_NS04() { if (digitalReadFast(interruptPin_NS03) == HIGH) { Tcount ++; } else { Tcount --; } //Serial.print("T NS04 :"); // debug print //Serial.println(Tcount); // debug print } By the way the serial debug printing inside the interrupts supposed to be disabled ? So got my drive working reliably now! Small gains right ? But strange track counter error now. It seems the track counter is always 1 track behind the actual track count. For example, even when going to sector 720 the track display is showing 38 instead of 39. Same for when formatting a floppy or doing the 1050 Diagnostic burn-in test. It's almost like when going to track 0, you need two tracks to increment the first track. Any thoughts? Edited May 12, 2022 by macsonny 1 Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 12, 2022 Share Posted May 12, 2022 I noticed this issue once before I think it happens on the startup when you power ON the Drive. Try this but I didn't test this yet. void loop() { noInterrupts(); if (digitalReadFast(N_TRACK00_Pin) == HIGH) { // if Track 0 sensor @5volts then set TRACK count to 0 Tcount = 0; } NewTcount = Tcount; interrupts(); if (OldTcount != NewTcount) { OldTcount = NewTcount; display.clearDisplay(); display.setCursor(10, 4); if (NewTcount < 10) { display.print("0"); } display.print(NewTcount); display.display(); } } Quote Link to comment Share on other sites More sharing options...
macsonny Posted May 12, 2022 Author Share Posted May 12, 2022 30 minutes ago, Chri O. said: I noticed this issue once before I think it happens on the startup when you power ON the Drive. Try this but I didn't test this yet. void loop() { noInterrupts(); if (digitalReadFast(N_TRACK00_Pin) == HIGH) { // if Track 0 sensor @5volts then set TRACK count to 0 Tcount = 0; } NewTcount = Tcount; interrupts(); if (OldTcount != NewTcount) { OldTcount = NewTcount; display.clearDisplay(); display.setCursor(10, 4); if (NewTcount < 10) { display.print("0"); } display.print(NewTcount); display.display(); } } I think that worked. I'll do some further testing... 1 Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 12, 2022 Share Posted May 12, 2022 Quote Note that I'm taking 5VDC to power my device from the 1050 motherboard (TP13 or 15 from emory). Might that be the issue? One more thing regarding Teensy 4.0 power. With the default 600 MHz settings Teensy 4.0 consumes approximately 100 mA current. Plus whatever the OLED screen needs ? You can change the frequency a bit 450MHz? This will drop the current. Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 12, 2022 Share Posted May 12, 2022 Oh one more thing I was playing with OLED brightness? For now I have this in: void setup() { display.begin(SH1106_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3D (for the 128x64), SH1106 addr 0x3C. display.SH1106_command(0X81); // SETCONTRAST display.SH1106_command(0); // CONTRAST VALUE 0 TO 255 ... more code. Quote Link to comment Share on other sites More sharing options...
macsonny Posted May 13, 2022 Author Share Posted May 13, 2022 Not my best work but you get the idea ? 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 13, 2022 Share Posted May 13, 2022 there are 3d extruder and resin based printer files to print bezels for these drives, no need to hack up the originals... some are posted on AA as well... some are floating around with places for updates such as these as well. A number of members here do professional quality files and even provide prints. 1 Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 14, 2022 Share Posted May 14, 2022 This is way I was thinking about going Wireless (ESP D1 mini) on my two 1050s as transmitters and perhaps have a central mcu for the screen display? Quote Link to comment Share on other sites More sharing options...
Chri O. Posted May 14, 2022 Share Posted May 14, 2022 (edited) Something similar to this: Just another project I got going. Edited May 14, 2022 by Chri O. 2 Quote Link to comment Share on other sites More sharing options...
macsonny Posted May 14, 2022 Author Share Posted May 14, 2022 On 5/13/2022 at 3:32 PM, macsonny said: Not my best work but you get the idea ? I know the mod looks a bit rough but trust me, from a distance it’s actually not too bad. I’m happy with it and I have 4 drives so can afford to have one as my “mod device”. 2 Quote Link to comment Share on other sites More sharing options...
SpicyChronos Posted October 16, 2023 Share Posted October 16, 2023 Hello all, Sorry to resurrect an older thread, but I am interested in this project, and wanted to know if there has been any more involvement with it? Thanks. Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted October 16, 2023 Share Posted October 16, 2023 The WST type 1050 drive is easily modded to do track display but the Tandon type is more complicated and had not been worked out when this thread was live. Unless you mean the SIO2mSD teensy device referred to later on? either way, @Chri O. have you had chance to make any progress? Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted October 16, 2023 Share Posted October 16, 2023 Why is the Tandon more complicated? Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted October 16, 2023 Share Posted October 16, 2023 IIRC, its something in the EPROM code that makes the Tandon mech operate using half-steps and a multi-phase stepper motor. its like the hardware wasnt fully compatible so the code was developed to make it work. I tried a simple, logical approach a while ago but was ultimately scuppered by this strange design: Quote Link to comment Share on other sites More sharing options...
Chri O. Posted October 16, 2023 Share Posted October 16, 2023 9 hours ago, xrbrevin said: @Chri O. have you had chance to make any progress? No sorry 🙂 Way too busy lately trying to start my own business for the past 6 months. Quote Link to comment Share on other sites More sharing options...
Chri O. Posted October 17, 2023 Share Posted October 17, 2023 Now you got me looking into my drive (Tandon) from the last year I end up buying and it looks like it's alive but it needs new belt or perhaps I can design some type of tensioner with my 3D printer and the small bearings I got for my RC hobby 🙂. 1 Quote Link to comment Share on other sites More sharing options...
Chri O. Posted October 19, 2023 Share Posted October 19, 2023 (Tandon) Drive is up and running 🙂 perhaps I can look into this issue when I have a bit more time I just got home. Quote Link to comment Share on other sites More sharing options...
macsonny Posted October 19, 2023 Author Share Posted October 19, 2023 21 hours ago, Chri O. said: (Tandon) Drive is up and running 🙂 perhaps I can look into this issue when I have a bit more time I just got home. Can you share what your final solution was? Quote Link to comment Share on other sites More sharing options...
Chri O. Posted October 20, 2023 Share Posted October 20, 2023 Only manage to fix my drive and I can confirm that the display does not work correctly with Tandon Drive. Will look into this later today. Quote Link to comment Share on other sites More sharing options...
